Output from Pedal is Too Quiet
Started by tristanplaysguitar, June 03, 2012, 10:17:37 PM
tristanplaysguitar
Quote from: Jdansti on June 21, 2012, 01:21:32 AM
Two things look suspicious, but it might just be the way the photo looks.
R3 looks like it might be connected to pin 3 instead of pin 2 of the IC.
The other thing I can't verify is the little circuit containing R5, R6, R7, C6, and C8 and how they are connected to pins 6 and 7.  You might want to double check these.
Well, I double checked that stuff, everything hooked up correctly. Do you know what that little circuit does?
Any other ideas?
Thanks,
Tristan
<a href="http://tristan-smith.bandcamp.com">My Music</a>
Guild Bluesbird, Guild GAD-25, THD BiValve
Built: LPB-1, Bazz Fuss, BYOC Analog Chorus
Jdansti
My uneducated guess is that it is part of the tone control.
One thing is to double check your resistor values against the schematic. It's easy to grab the wrong resistor and put it in the circuit. I've done it and I've seen others do it.
Also, check your grounds across the breadboard. With the battery disconnected, check for continuity between the negative side of the battery clip to both ground busses on the breadboard and to the vol and tone pots and the jacks.
I just noticed that the tone pot is the only path from IC1A to IC1B on the schematic. It seems that it would greatly affect the signal on its path to the output. Maybe one of the other guys can comment on this.
