Problem with Bluesbreaker
Started by Joseeduardosn, June 09, 2012, 08:39:55 PM
Joseeduardosn
Hello people. I armed Tonepad version of this pedal and there is a problem in the operation of the pots. I wonder if any of you have also made ​​them the pedal is the same. What happens is that both the tone pot as the pot also gain work, apart from performing its function determined, as volume pots. And the pot volume, in turn, also functions as a gain. Bone, with all pots half rings. But I turn up the gain, as part of the gain up, so does the volume. And with the maximum gain and maximum tone and volume to the average cane sounds good, but if you climb to the maximum volume pot also, further increases the gain. In the two plucked up Tonepad same thing happens, and I am surprised because the first one I built, which was the version of Aron Nelson, if I recall, there was no problem. One thing more is that I used a pot to the tone 50kohms when shown in the layout that should be 25k.
