Old Tremulus Vero
Started by Moustache_Bash, June 11, 2012, 03:59:20 PM
Moustache_Bash
Hey guys I found this vero layout in an old thread, and the system told me if I want a reply I should make a new topic.  Sorry if I'm doing this wrong...
So here's the layout I'm following.  All I want to ask is, does anyone know how the electrolytics are supposed to be orientated?  All anodes on top, I'm assuming?
reverberation66
yup, anodes on top, is the layout verified?
midwayfair
Quote from: Moustache_Bash on June 11, 2012, 03:59:20 PM
If you can see the subtle gray shading, that's the - side.
If you aren't certain, always check the schematic. The + side also always goes toward the side facing the power source, and the - to the ground (in a negative ground pedal, that is).
Moustache_Bash
Thanks, guys.
Quote from: reverberation66 on June 11, 2012, 04:12:28 PM
I'll let you know tonight :icon_wink:
Moustache_Bash
Well, I built it.  And it doesn't work, but that may not be the layouts fault.  The only thing I'm not sure about is if lug 1 of speed and spacing aren't used.  I built to where they're not used.
I'll keep dinking around with it, though.
Moustache_Bash
Bah, I can't get the stinker to work.
I don't even get sound bypassed. But, when the effect is engaged I get a kind of thump that sounds like the trem is trying to do something.  I'm sure I probably messed up something.  I bet someone with a better understanding of electronics could figure out what's what with this circuit.
