Ts 9 rehousing
Started by Dallass612, June 20, 2012, 01:04:22 PM
Dallass612
 I'm looking to rehouse my ibanez ts 9. Could anyone tell me what parts I might need for it?
Pollinator95
Enclosure, rubber feet, jacks, 3PDT switch, 9V socket, possibly pots and knobs, LED, 4k7 resistor and LED bezel, battery snap if you're going to use one, wire. I think that's everything, but it depends how thorough your rehouse is going to be (might not need everything).
WARNING: I AM A NOOB
CurtisWCole
Read the "technology of boss/ibanez style switching" at geofex.com if you're going to use a 3pdt. You have to make the pcb always on to do that ( sorry if you already knew that ) otherwise you can get a momentary spst switch in place of the old one and mount it.
Curtis
Composers shouldn't think too much - it interferes with their plagiarism.
Howard Dietz
Dallass612
Thanks! This helps out a lot.
Sorry if this sounds like a noob question, but would I need a 3mm LED or a 5mm? Or does it even matter?
ghostsauce
Doesn't matter, it's literally just how big it is. I like the 5's.
