Tonepad MXR Envelope Filter
Started by musiclikscreams, July 10, 2012, 10:26:09 AM
musiclikscreams
Can someone help make sense of the 3 mods for me? http://www.tonepad.com/getFile.asp?id=113
I can't for the life of me understand them. I'm mostly interested in the reverse sweep but I would like to do the other 2 as well. Thanks
Govmnt_Lacky
If you are gung ho on building this then... by all means.
I found the envelope effect on this build to be very weak. The wah is not very pronounced.
If you want something that is subtle, this is it. I would look elsewhere if you want something that really kicks!
musiclikscreams
Damn I had no clue. It was a board I had gotten a years ago from here.
I've been gettin into vero builds, got any suggestions for a good filter with a vero layout?
I've made several and they work just fine.
musiclikscreams
Quote from: Mark Hammer on July 10, 2012, 12:56:15 PM
Can u send me a gut shot to help me understand what's going on in these mods? Schematics really make little to no sense to me
Nocaster Cat
Quote from: Govmnt_Lacky on July 10, 2012, 10:37:29 AMI found the envelope effect on this build to be very weak. The wah is not very pronounced. If you want something that is subtle, this is it. I would look elsewhere if you want something that really kicks!
Really? I may be wrong but I think the forbidden forum figured out that the EMMA DiscumBOBulator was the MXR with the Tonpad mods. If that's the case, I've owned the EMMA and would not consider it to be weak at all.
Govmnt_Lacky
Quote from: Nocaster Cat on July 10, 2012, 02:24:08 PM
When I built my clone I only did the reverse sweep mod. The other mods may make it a stronger effect.
Quote from: musiclikscreams on July 10, 2012, 01:16:25 PM
I recently restarted this project and some day may actually finish. First time round it never worked, TI chipset, blow off the dust, dated June 2003, is that possible?  Always found that diagram for the sweep mod confusing but this is my take on it. Take your DPDT On/On switch and jumper between a pair of the outside terminals. Points 'G and 'H' represent the middle terminals of your switch so run a wire from each of those switch terminals, and i use different colours to help me keep things sorted, to the corresponding pad on the board. Points 'C' and 'D' represent the two remaining terminals on your switch so run wires from those terminals, matching wire colours C/G, D/H, to the corresponding pads on board.
For the Filter mod, points 'B' and 'I' are the center two terminals of a second DPDT (On/On), run different coloured wires from them to the board. A and J are an outside pair of terminals, run wires from those to the board making sure the switch will connect B->A and I->J when closed, the last pair of terminals on the switch are ignored.
For the Emphasize control  a wire is run from pad 'E' or 'F' on the board to the wiper of a 500k pot and a wire is run the remaining pad to one of the outside legs of the 500k pot and i can never rememember the correct arrangement but in the end it doesn't really matter. Green twisted pair in picture.
dave
chromesphere
Quote from: Govmnt_Lacky on July 10, 2012, 03:10:18 PM
I agree, definitely a weak filter effect for me too.  I'm comparing this to the FSH.  Infact for an envelope filter, id just bypass the MXR and go straight for an FSH.  That thing kicks a$$.  Heres mine:
Paul
Pedal Parts Shop                Youtube
musiclikscreams
Wow... now I wanna drop the mxr all together and make an fsh. Don't be surprised to see my half populated mxr board on the for sale thread in the future haha
chromesphere
Quote from: musiclikscreams on July 11, 2012, 09:59:20 AM
Do it :)
