Trimpot Help
Started by soupbone, July 21, 2012, 05:50:47 AM
soupbone
I've used trimpot's in circuits,but only to set the voltage to transitors.I'm going to try using one in my crybaby to adjust the trimpot,so i can set it to where i like it.One question is,If the middle lug is on the bottom,and the outer 2 legs are on the top,Does it matter which leg of the outside top 2 ties to the middle leg?
digi2t
Using it as a variable resistor, the only reason it should matter would be to have a logical sense to what the trimmer is doing i.e, raise/lower, louder/softer, etc. when turning to the left or right. I tend to test first with my DMM to decide which legs I'm going tie together, so that when I'm adjusting, I know which way to turn the trimmer to achieve the desired effect.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
soupbone
Quote from: digi2t on July 21, 2012, 07:34:24 AM
Ok gotcha.Thanks!
