Building an ABY pedal
Started by thedavidbeam, July 23, 2012, 10:24:16 PM
thedavidbeam
Hey guys. I'm curious, how would I go about wiring an ABY pedal with LEDs using a 2PDT switches?
pappasmurfsharem
I don't know if this is helpful but this is a schematic for a Morley ABY pedal from their website
http://www.morleypedals.com/abyes.pdf
Mike Burgundy
thedavidbeam
thanks guys. Definitely not looking for anything too complicated. I have a Morley A/B/Y that I was rehousing, and I had to throw out the circuit board, so just trying to figure out how to wire the switches. The only wiring diagrams I have found thus far did not include LEDs.
hmmmm...i  was messing around with a similar idea a while back for an AB...never got round to trying it out though...
but heres the idea i had..might be bad, might be good.....who knows!!!...not an ABY but hey ho... :)
pappasmurfsharem
Quote from: deadastronaut on July 25, 2012, 04:16:54 AM
It's only missing the Y but that looks simple enough.
What did you use to draw that up BTW?
thedavidbeam
awesome! no how would I add the Y? lol
mwynwood
I can't remember where I got this pic from... but it works fine :)
This one works great too - but no LEDs:
Marcus Wynwood
My Build Blog
MarcusGuitar.com
^ cool.
@papasmurf:  i used inkscape, with a pdf of pedalparts from my gallery....pedal vectorpack, click on download..... ;) very handy for designing..
http://www.aronnelson.com/gallery/main.php/v/chickpea/?g2_page=4
mwynwood
Here is one I've drawn up in DIYLC.
I hope it's useful for someone  :icon_smile:
Marcus Wynwood
My Build Blog
MarcusGuitar.com
mwynwood
Thanks Rob - it's pretty basic, but I've learnt so much in the last 12 months here that I though I'd start trying to give a little back!
DIYLC is a fun bit of software too :)
Marcus Wynwood
My Build Blog
MarcusGuitar.com
yep sure is, very handy, i do all my layouts with that now..nice n easy.
btw have you built the diagram above?
mwynwood
#13
Yeah, I've been jamming with it tonight... going from my JetCity to my Vox... and then BOTH... and back again! haha
Marcus Wynwood
My Build Blog
MarcusGuitar.com
cool, i need to make one of these too ...always handy.....excellent.  8)
do both leds come on when in 'Y' mode?
mwynwood
Yeah, both LEDs come on when it is "A AND B"
The trick is remembering which output was active when you go back to "A OR B" mode.
It'd be cool to have some sort of indication of that... hmmm...
Marcus Wynwood
My Build Blog
MarcusGuitar.com
gotcha...cool..yeah with my brain that extra indicator would be handy... :)
mwynwood
I just made a quick change... does this look right?
Marcus Wynwood
My Build Blog
MarcusGuitar.com
mwynwood
Hmmm... I just build the ABY Box with 3 lights above... and the LEDs don't seem to work correctly.
The middle LED (BOTH) only briefly flashes on and off when it's supposed to be on.
The 2 LEDs off the OR footswitch (OUT1 and OUT2) work as expected.
I'm not sure why it's not working  ???
Any ideas anyone?
Marcus Wynwood
My Build Blog
MarcusGuitar.com
Give the both LED its own current limiting resistor. Running two LEDs off one resistor doesn't work reliably, because one LED will turn on at a lower voltage than the other, that one will light up and the voltage is then too low to turn the other one on. Both OR LEDs sharing a resistor is fine because only one is on at once.
