TL072 Pre-amp with 3 band EQ
Started by nikolozj, September 10, 2012, 04:32:32 PM
nikolozj
Hi everybody,
I've just built this pre-amp, called "Tonemeder", found on this website here with it's sample tests and stuff...
http://www.runoffgroove.com/tonemender.html
Here's the schematics they have on website:
when I tested it, it was going mute when I would turn MID and BASS potentiometers all the way...
so this is fixed version of diagram:
works fine now...... BUT!!
I would like to modify it more, instead of simple switches of LOW MID and HI MID, I want to have individual potentiometers doing that....
can anyone suggest how that would work?
Pollinator95
Do you mean the Mid shift switches? I imagine you could use a voltage divider, the same way as a volume control. Assuming that works, it would probably alter the frequency response a bit because of the added resistance.
Edit: BTW, those switches are both halves of a DPST switch, so they're thrown at the same time. You'd need a ganged pot for what I said.
WARNING: I AM A NOOB
It is an exact (almost) copy of a classic Fender tone control, which also "went dead" if all three knobs were turned-down.
So don't turn all the knobs all the way down.
Shifting the cap-values is not easily done with a pot. Consider a rotary switch.
