Author Topic: PUNCH - 1W amplifier  (Read 123198 times)
tca
Re: PUNCH - 1W amplifier
« Reply #100 on: July 08, 2013, 07:24:11 AM »
g 1.7
s 9v
d 1.3v
That can not be right! Drain should be 9V and Gate 0V (1M to ground)?
P.S.
Pot volume?!?!? Are using the TDA7052 chip? Or the TDA7052A...?
« Last Edit: July 08, 2013, 07:31:19 AM by tca »
chromesphere
« Reply #101 on: July 08, 2013, 07:44:07 AM »
hmmm...maybe the transistor is knackered!
Yep, its the 7052A
Paul
Pedal Parts Shop                Youtube
tca
« Reply #102 on: July 08, 2013, 07:59:31 AM »
Yep, its the 7052A
Paul
Or badly connected (check pins labels). Are you using chptunes TDA7052A version?
« Last Edit: July 08, 2013, 08:15:31 AM by tca »
chromesphere
« Reply #103 on: July 08, 2013, 08:11:20 AM »
Yeah, using this one except without the resistor on the load (added the resistor made no difference really).
Rock_on
« Reply #104 on: July 08, 2013, 08:41:16 AM »
Is this enough to fill in our classroom (about one normal living room) and the gymnasium in our school (yeah i know it's big but we're just few people gathering for a bible study)
And is this transparent? I mean very clean?
Rock_on
« Reply #105 on: July 08, 2013, 08:41:48 AM »
Sorry for many postings
« Last Edit: July 08, 2013, 08:47:21 AM by Rock_on »
Rock_on
« Reply #106 on: July 08, 2013, 08:42:13 AM »
« Last Edit: July 08, 2013, 08:46:16 AM by Rock_on »
Rock_on
« Reply #107 on: July 08, 2013, 08:59:52 AM »
tca
« Reply #108 on: July 08, 2013, 10:37:35 AM »
It is very clean if you power it with a wall wart.
I think it will work in a classroom nicely. I guess the gym is just a gathering place, all of you will be closed packed around near the amp, it would work too.
Cheers.
P.S.
Please try to avoid repeated posts.
Electron Tornado
« Reply #109 on: July 08, 2013, 11:41:06 AM »
How is it working with a 100k linear pot for the volume control? The datasheet calls for a 1M ohm pot. Just wondering.
OK, where's the data?
"Top hole. Bally Jerry pranged his kite right in the how's your father. Hairy blighter, dicky-birdied, feathered back on his Sammy, took a waspy, flipped over his Betty Harper's and caught his can in the Bertie."
chromesphere
« Reply #110 on: July 08, 2013, 08:15:03 PM »
Hey Electron,
I didnt design that schematic check back at, i think its on page 4.
I was going to ask, anyone know if you can replace that 2n5457 with a j201 and the buffer will still work?  I think i read ages ago, you can essenitally use any jfet for a buffer?
I'm going to try replacing that transistor tonight.  I know that for about 5-10 secs i reverse polaritied the circuit.  Wondering if i blew it.   Everything was going so well...not sure how i managed to mess up something so simple, so serverly :)
Paul
Electron Tornado
« Reply #111 on: July 08, 2013, 09:04:47 PM »
Hey Electron,
OK, but have you built it with the 100k linear pot? If so, I'm just wondering how it worked for you.
chromesphere
« Reply #112 on: July 08, 2013, 09:08:45 PM »
Hey Electron,
LOL forgot to mention that!  :)  I used a 500k linear pot for mine, what i had lying around.  I think you might get extra volume with a 1meg pot.  Not sure why the schematic has 100k?  Maybe 100k+ distorts...idk...but im pretty sure you want an log pot anyway, not a linear.
Paul
Electron Tornado
« Reply #113 on: July 08, 2013, 09:20:05 PM »
OK, thanks. I was just wondering. I built one using a 1M log pot: http://www.diystompboxes.com/smfforum/index.php?topic=100717.msg911855#msg911855
It works well, but I think it will sound better with a preamp, although my first try at a preamp sounded awful. The chip gets mighty hot, though, so it's got a heat sink.
tca
« Reply #114 on: July 09, 2013, 04:09:04 AM »
Yes!
Rock_on
« Reply #115 on: July 09, 2013, 06:56:38 AM »
The repeated postings are caused by a bug in my phone
When i selected post it would load then sometimes the wifi will turned off causing the page not to load to the new page which would make me click the post again
chromesphere
« Reply #116 on: July 09, 2013, 07:32:29 AM »
Yes!
Replaced it.  Bang, we're back in business.
So here's my REAL REVIEW of the punch amp.  Now that I have one actually working properly.
I've learnt a valuable lesson about power and speakers.  1watt can drive 2x12inch loudspeakers.  The speakers have a huge bearing on how much volume you can get out of an amp.  I was getting a decent output from just a 6inch hifi speaker (in a cabinet), decided to plug it into my 2x12 fender twin (70's not a reissue) and...what can I say?  Its "I need to turn this down cause my ears hurt" loud.
Its very clean and has quite a pleasing tone.  I would be happy to practice with this amp any time!
Thank you TCA for sharing this, you've turned my unhappy amp experience into a good one!
Paul
tca
« Reply #117 on: July 09, 2013, 09:12:23 AM »
^ I'm glad you like your build! It is a wonderful little amp.
earthtonesaudio
« Reply #118 on: July 09, 2013, 10:18:16 AM »
Paul
I have an old Crate 2x12 open-back cab.  With a quiet drummer I can get by using a 1/2W Noisy Cricket derivative on 9V power.
With a loud drummer, I need to switch to at least my 150W amp and turn it up most of the way.  :icon_eek:
chromesphere
« Reply #119 on: July 09, 2013, 06:11:42 PM »
lol, yeah I don't think its going to replace my bad cat or fender twin as far as volume goes, but im totally amazed how much volume you can get out of 9v's an IC and 5-6 components.  I was quite shocked!  I'd read about this sort of stuff a million times but yeah...just didn't expect it to be so loud!  You could seriously annoy the neighbours with this, its bloody loud! Great stuff!
Paul
« Last Edit: July 09, 2013, 10:55:27 PM by chromesphere »
