PUNCH - 1W amplifier
Started by tca, September 24, 2012, 06:07:22 AM
S_DANILO
Quote from: tca on September 23, 2013, 01:32:23 PM
Quote from: S_DANILO on September 22, 2013, 04:01:24 PM
Hello everybody! Newbie needing help!
I've chosen the Punch Amp to be my first DIY project, and I actually think I was successful since I had never used a soldering iron before, but the thing is the amp is not working (as expected from a newbie!)...
What is the chip that you are using TDA7052 or TDA7052A?
I'm actually using the TDA7052B
tca
#161
Quote from: S_DANILO on September 23, 2013, 02:49:08 PM
Funny  ;D
That is the problem: the TDA7052B also has DC volume control! Can't see the differences between version A and B?!? Have to check the datasheet.
Cheers.
P.S. (edit)
More gain for the A, less noise... I'm guessing but it seems that the A version is a "deluxe" B version ;).
chromesphere
Didnt even know there was a B!!
Are you sure you havent messed up your layout Danilo?   You said your new to this.  That would be the biggest margin for error and most likely cause if you ask me.
Paul
Pedal Parts Shop                Youtube
S_DANILO
Just downloaded the B version datasheet and saw the DC volume... Thanks for the input Tiago!
As Paul suspected, I have also committed a few other "crimes" when I was assembling it, so I'll just buy a vero board and start all over again.
Anyway, I have to mention that I really enjoyed to do this project, even that it didn't work... :)
Thanks a lot for all the help you guys provided!
Cheers
Sergio
Quoteso I'll just buy a vero board and start all over again.
Etching is easier than vero. Perf is easier than vero. Proto-board is easier than vero. Point-to-point is easier than vero. Anything is easier than vero!  ;)  Seriously, some people here are wizards with the stuff, but it's really easy to get a solder bridge over a strand of copper flailing astray from drilling the 'cuts', among other reasons. It's never too soon to start trying to make your own PCBs. Or leave those leads on and start perfing.
S_DANILO
Quote from: garcho on September 24, 2013, 12:36:55 AM
@garcho, thanks a lot for the input!
Cheers.
Sergio
Quote from: S_DANILO on September 23, 2013, 09:03:48 PM
Cheers
Sergio
thats the spirit.. 8)
you'll get there in the end.. ;)
therealfindo
#167
Hi.. I'm looking to make this project (on vero) with a couple of bookshelf speakers I've got lying around. But a couple of questions still (having read through the entire thread)
a) How would I incorporate the volume and tone control to this circuit? (Edit: I found this variant - http://i.imgur.com/URTeFuF.png?1 which has a volume pot - could I simply add a tone pot like the one in a guitar setup, with a cap going to ground? If so, which values?)
b) Did anyone figure out how to add a headphone output as well?
chromesphere
Hey, the volume control is a feature of the tda7052a <-- note the a suffix, and is connected to pin 4 of the chip.  The tda7052 doesnt have a volume control so make sure you get the right one.
Only thing i could think of for tone control is an input cap blend tone control.
for the headphones, no special requirement.  Just plug them in.  Pretty sure the MCL feature of the chip automatically adjusts its current when headphones are plugged in.  I should say, i have tested it and its fine with my set up.
Hope that helps.
Paul
MaxPower
Is the TDA7052 pretty common? Mouser only has the surface mount version. Should probably check mammoth and i see if they carry them....
What lies behind us and what lies before us are tiny matters, compared to what lies within us - Emerson
chromesphere
You can get them on ebay if you get stuck.  Just make sure you get the TDA7052A if you want the volume control option.
quick ?
will this kill a 9v battery..or  6 x 1.5 AA's  rapidly?...anyone tried it yet?.
i just fancy a seperate little amp to go with my roland micro cube...so i can jam to backing tracks when camping, holiday etc..
my roland lasts up to 20 hours on 6 AA's.. :icon_eek:
so just wondered how this would fair
chromesphere
Someone was saying the punch amp ran down quickly because it should be ran at 6v instead of 9v.  Might be worth giving it a test run?  Havent ran mine on batteries so no idea.
chptunes
Concerning the use of a 9v Battery.. I documented a little experiment, back on page 4 of this thread.  This little Perfboard Punch remains in the corner of my Family Room.. I use it for unscripted jams every week.. original battery still installed.
Here is the quoted reply:
Quote from: chptunes on February 28, 2013, 08:14:20 AM
Quote from: Gurner on February 27, 2013, 05:46:47 AM
BTW I wasn't saying the TDA7052A is any more or any less efficient than others (though in IMHO, most small audio ICs you see in stompbox type circuits are much of a muchness - if you seek efficiency, then a class D' audio IC is the way to go ....but try finding one of those puppies that you can solder easily in a through hole package!)...I was just pointing out that for battery purposes,  at high volumes into an 8 ohm speaker, the TDA7052A will drain a 9V battery in very short order (cos like all BTL amplifiers it gives double the voltage swing across the speaker vs. a single ended amp like the LM386)
So.. I did a real-world test.
I have built several Punch Amps.. they are fun to build and easy to apply in different situations.  The Punch that I used for this test is on Perfboard, with an on-board 100k Volume Control (Trimmer).
Here are images of the test amp:
I opened a fresh Alkaline.. measured 9.48vDC.  Connected the battery to my test amp, with Volume Trimmer set at 100k ['just above conversation-level' output with dry guitar (single-coils)].  Current draw at idle measured 10.7mA.
Played random notes/phrases/chords for approximately 5 minutes...
Inserted my AMZ Tweed Stack Preamp and enjoyed sweet overdriven tones for approximately 10 minutes...
Unplugged my guitar, but kept the guitar lead plugged in with the test amp still 'On'.  Current draw measured 10.7mA.. went to bed...
Woke up after 7-7.5 hours, and measured voltage at 8.28vDC.  Plugged my guitar in and enjoyed 'just above conversation-level' output for approximately 10 minutes...
Unplugged from test amp.
Conclusions:  Into a 12 Ohm load, with 100k Ohms on Pin 4, battery power is very feasible for the purpose of casual 'living room' use and pedal auditioning.  Don't leave it 'On' while you sleep.   ;)
Food-For-Thought:  My Punch still sounds fine at 8vDC.. the TDA7052A chip will operate down to 6vDC.
-Corey
cool....sounds good to me then, , cheers, 8)
therealfindo
Quote from: chromesphere on September 30, 2013, 08:26:14 PM
Hope that helps.
Paul
Thanks for that Paul!
*googles "input cap blend tone control"*  ;D
Cheers.
chromesphere
Quote from: therealfindo on October 01, 2013, 04:45:45 PM
Cheers.
YOu can see an example here (the 'blend' control):
http://www.generalguitargadgets.com/pdf/ggg_ff5_sc_easy.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
easy to implement just make sure you put the lower and higher values around the right way otherwise the control will have no effect.
Paul
smurfedelic smurfberry
here's my enclousure... abs plastic, aluminium tape covered inside..
I like it, it's a bit "thin" when it comes to the sound, but it's awesome. I guess the 5w Sparky is the next amp i build haha
Hi! My name is Petter and I'm from Sweden. This is my blog: http://ptelectronics.tumblr.com
kingswayguitar
Quote from: smurfedelic smurfberry on October 04, 2013, 10:35:10 PM
cool papa smurf
couldn't get your weblink to work though
