PUNCH - 1W amplifier
Started by tca, September 24, 2012, 06:07:22 AM
tca
I would like to share with you my latest build. A 1W amplifier  using the TDA7052. In my opinion it sounds much better than any LM386 it has a much better frequency response (only one capacitor on the signal path). It works with batteries but preferable with 1.5V AA in series.  I usually power it with a 9V power source.
Comments, suggestions?
Cheers.
tca
Yes, very clean, wonderful to plug in any effect!
cool, might have to knock this up as part of my grandsons xmas prezzie... (he wants a guitar) :icon_twisted:
i'm making him a spitfire distortion, so he'll be stoked with a liittle amp too..cool.
might have to whack an headphone on it too though...to keep his mum happy.. ::)
B Tremblay
I just looked through my chip amp notes and found a schematic using the 7052. It appears that I found that the chip had less pleasing overdrive tones than the 386, but I was feeding it with a FET gain stage rather than a buffer. I may have been clipping the FET and the chip was innocent. I did put in a low pass filter ahead of the chip, so it must have been a little bright to my ears.
Thanks for sharing your work.
B Tremblay
runoffgroove.com
J0K3RX
#5
Here's another nice one and really loud 3W runs anywhere from 6v to 15v and very small...(TDA7267) I run it from 9v and it drives a 4x12 @ 8ohms and loudly!
http://www.velleman.eu/downloads/0/illustrated/illustrated_assembly_manual_k8066.pdf
Sounds great with guitar!
^ 3watts...nice!
my little roland cube is 2watts and is loud enough to annoy people....so 3 is even better!...nice one. :icon_cool:
I gather these chips are typically found in small plastic add-on speakers for computers or MP3 players?
John Lyons
Have to try the punch amp, thanks for posting.
Can someone please email me the TDA7267 (Velleman kit) schematic please?
I keep getting errors trying to download it. And the one on line is tiny...
John
Basic Audio Pedals
www.basicaudio.net/
haveyouseenhim
this it what i made with the velleman kit. (they sell the kit at radioshack for about $20)
tca
Just made a PCB. Going to test it tomorrow.
Cheers.
tubelectron
Quote from: deadastronaut on September 24, 2012, 06:19:04 AM
cool, is it very clean?
Quote from: tca on September 24, 2012, 06:28:00 AM
That's a good point, indeed. I made some trials with the LM386 and none of them were satisfactory for a reasonably audible clean power on guitar, even if I noticed that the speaker had an important influence on the result - I speak about small/miniature speakers, not guitar speakers, indeed !
Here's what I tried for guitar. it wasn't interesting... nor in power, nor in tone... I also tried the Smokey amp : it was the less bad, but not worth...
Conversely, I could derive from it an excellent battery-powered stereo monitor for my PC, very good sounding and powerful, with a volume and a tone control, using 2xLM386 (= 1 per channel) :
But connecting a guitar on that monitor gives inexplicably bad results : saturation, low power output...
A+!
http://guilhemamplification.jimdofree.com/
^ nice builds though bruno/mike..
@tca:  might be worth adding a tone control, and headphone on it too..
tca
#14
Quote from: deadastronaut on September 25, 2012, 03:57:29 AM
I just wanted an plug-in-and-play amp with a small part number and I usually don't play with headphones (it makes me dizzy). But a tone control could be a nice thing. I didn't also put a volume control because I use a L-Pad (8Ohm attenuater) between the amp and the speaker and this works fine as a master volume.
BTW, the LM386 does not like this L-Pad, it reacts strangely  to it, but it works great with the TDA7052.
Cheers.
tca
#15
@tubelectron I've made also stereo monitor for my PC but using two class A mosfet (IRF610) amplifier.
It works fine with a booster but due to the power source (9V/100mA) it is some what muddy when used with a guitar. These class A configurations works better with higher currents and higher voltages, but nevertheless it is the amp that I use to listen to music from my PC.
Cheers.
P.S.
The bulbs are  the drain load for each of the mosfet.
tca
#16
@tubelectron I've build a few Rubys and usually the speaker that I use is something like this double cone speaker:
Freq. range: 50 - 12.000 Hz,
Sensitivity: 90 dB, 1 W/1 m
It is this speaker that I plug in the punch amp.
You can buy them in Portugal for about 15 eurs.
Cheers.
bancika
that sounds expensive, you can almost get a "real" guitar speaker, like jensen mod 6 or mod 8
tca
Quote from: bancika on September 25, 2012, 10:55:17 AM
You are quite right, but I can't find them with that price in Portugal (or online + mail), and I do like the sound of these speakers that I just mention.
Cheers.
Jaicen_solo
I'm going to pick up one or more of these to knock up a cheap bass amp. I'll be running the output of a Bass Pod through it, so I don't need tone controls etc. Looks perfect, but any suggestions what speaker I should use?
This is very much 'bedroom' use so I don't want it to be loud, but I want to hear the lows a little more than my current ValveJnr with the 8" speaker ;)
