Quick help with TL082 based 4 Channel Mixer Schematic. (Issue: WAY TOO QUIET.)
Started by aeiou, October 03, 2012, 10:09:12 PM
aeiou
http://s13.postimage.org/lrquzmihh/4chmixer.jpg
I've put together this mixer and my issue is this: It is mixing the 4 signals together, but it's way too quiet, regardless of how many instruments are plugged into the inputs. I have my keyboard turned up way past the point where it would make my little practice amp run into overdrive. However, run into this mixer it sounds clean, but at an extremely low level.
I'm sure I've just made a silly mistake here - Can someone quickly point it out for me?
THANK YOU!
aeiou
http://www.me.umn.edu/labs/hmd/lab/electronics/images/lf412.jpg
Here's the pinout for the TL082.
Additionally -- It's not simply an error in my build from this schematic as its a transcription by me of my personal project.
You need a capacitor and resistor in series between each of the inputs and pin 2, and a resistor between pins 1 and 6. Try 100k for the resistors, that will make the output the same volume as the input.
aeiou
ah ok.. -- those are the only apparent issues?
what value capacitors do you recommend?
THANKS!
Gurner
Quote from: aeiou on October 04, 2012, 10:54:32 AM
To my eyes no! You should take the output of the circuit from pin 1 to the cap rather than have pin 1 feeding the output cap via a 100k resistor (that 100k resistor is gonna act like a potential divider in conjunction with whatever follow on resistance there is ...end result, loss of signal magnitude).
A high value pull down resistor to ground wouldn't go amiss on the right hand side of the output cap either.
aeiou
http://s16.postimage.org/y7s4jk1kz/4chmixeredit.jpg
Very well -- here are the edits to my schematic based on your suggestions. i've not yet made these changes to the build on my desk.. does this look right?
gritz
A couple little things:
1) You've wired the output of the mixer amp to the output of the second amp, rather than to it's inverting input via a 100k resistor.
2) The 10n caps at the mixer inputs will cause a rolloff of the signal below 159Hz (the input impedance of an inverting opamp is equal to it's input resistor). 100n will take you down to 16Hz, so the audio band will be essentially flat. Even 47n would be ok if that's all you have.
Nearly there.  :icon_razz:
Gurner
Personally, I'd disconnect everything presently connected to pin 6 & 7, then short pin 6 to pin 7. (& get rid of the 100k resistor that was feeding pin 6)
aeiou
Gurner
Quote from: aeiou on October 05, 2012, 04:42:11 PM
http://s7.postimage.org/jycvqm2h5/4channelv11.jpg
OK - here are my edits at your suggestions.
Not quite, here's what I suggested...
Quote from: Gurner on October 05, 2012, 06:44:17 AM
all you should have for pin 6  & pin 7 is them shorted together, with nothing else connected   .....but you keep persisting in wanting to connect the output of the first opamp (pin 1) to these pins!
aeiou
http://s9.postimage.org/oehoagpml/4chmixfin.jpg
MY BAD -- now I THINK that I geddit. -- Pardon the myopia, this is my first ever self (now group) designed schem.
aeiou
I've updated my build to the latest revision of that schematic and it still isn't working -- it's mixing, but still super quiet. any advice?
Gurner
Quote from: aeiou on October 06, 2012, 05:10:09 PM
At this point, I'd say to measure your DC voltages on all the opamp pins
aeiou
sorry to make such a huckadoo -- maybe someone can sort out a confirmed working schematic for me. I've tried a few i've uncovered online to little success. here's yet another I found --
http://lh5.ggpht.com/-ySuv8zhUr2M/TzxP-LngCAI/AAAAAAAABQw/ZC5-Dy2ZKGg/s1600-h/image%25255B2%25255D.png
That will work just fine. Ignoring the pots, if you'd made the changes to your original circuit that I suggested that's what you would have got.
If your last version doesn't work properly then there must be something wrong with how you've built it, like Gurner said post some voltages, that will help debug it.
I've built a couple of small mixers using this schematic.  Works fine.
