obsidian vs vulcan vs blackfire
Started by jogina111, October 10, 2012, 11:45:45 PM
jogina111
anyone who has built or heard those 3 of Joe's designs? Which one is like pantera's awesome tone?
seedlings
Quote from: jogina111 on October 10, 2012, 11:45:45 PM
Pantera's awesome tone may be gone with Dimebag.  I've only built the Vulcan, and it's very amp-dependent.  What kind of amp are you going through?
CHAD
jogina111
just a diy tda 2003 power amp.. I havent recieved the tiny giant package yet. But would be my own amp..any recommendations for a good simple metal pedal to build and goes well with a tiny giant amp?
jogina111
its been decided! Im a go for a good ole metal simplex and mod it... Anyone got a pcb layout/transfer of the metal simplex? I googled some pics but I only got breadboard layouts...
^ i think you mean vero/stripboard layouts.
to be honest its such a small circuit you may as well use a piece of vero...you could build it in an hour.. ;)
if you really want a pcb design of the metal simplex i could knock up a quick layout for you ok..... ;)
WGTP
I have tried all of those designs and think they are great.  Not sure why the Vulcan would be anymore amp dependant than anything else.  I wouldn't write them off.  Currently my breadboard has a distortion with 3 stages: Obsidian/Jfet Vulcan/BJT Vulcan and it's great.  I reduce the bass content thru the distortion and boost it at the end with a BMP type tone control.   :icon_twisted: :icon_wink: :icon_mrgreen: :icon_cool:
Stomping Out Sparks & Flames
jogina111
#6
yeah Rob, I really want one. Got no veroboard so I'm using pcb's... What other high gain distortion for metal could I build using some 2n3904?
seedlings
Quote from: WGTP on October 12, 2012, 10:13:44 AM
Sounds very different (worse) through the crate SS amp than the cathode-bias jtm-45ish tube amp.  But, yes, you're right - no more so than most other pedals, and that is an important point.
CHAD
I've made a Blackfire, but none of the others.  Pretty intense.  Not really my style so the components have found other homes.  But a very decent design, with GOBS of output that will handily survive whatever passive tonestack you want to stick on the output.
Quote from: jogina111 on October 12, 2012, 12:35:09 PM
ok here ya go...unverified, but looks ok.....as always socket the transistors ;)
https://dl.dropbox.com/u/7464107/HOWIESLAYOUT1.pdf
https://dl.dropbox.com/u/7464107/HOWIESPCB1.pdf
not sure on other 3904 distortions...i prefer fets j201's for that.. :icon_twisted:
jogina111
what circuits for the j201's? Just the easy ones.
jogina111
there's a 100uf cap in your layout, what does that do?
its for power filtering..smoothing.
common on most schematics.... ;)
jogina111
ah,I see. What about the red electrolytic cap on the layout? It doesnt have a label. What should I put in there?
c16 should actually be 100uf...not 1uf...  :)
c1 = 1uf
c6= 22uf...
jogina111
I built the metal simplex but skipped the tone and volume pot  but it got low output .not very low output but just the same volume with clipping.. must I expect some volume  increase? Is this because of the lack of volume pot?
jogina111
