Dueling transformers
Started by Govmnt_Lacky, October 13, 2012, 05:57:01 PM
Jdansti
Would using a TL783 be a viable option?  It's variable from 1.25V to 125V and rated at 700mA.  I don't mean to steer the thread in a different direction, but thought I'd just mention it to at least learn more about the pros and cons.
http://www.ti.com/lit/ds/symlink/tl783.pdf
Govmnt_Lacky
Quote from: R.G. on October 15, 2012, 04:56:30 PM
It's really, really close. I make it 37.096Vdc before the regulator (Q6) to make 35Vdc. That's certainly not impossible. I'd say go for it with one on a test basis. You may be OK. If not, you can add the other trannie or make a voltage doubler.
Thanks RG and John.... I really appreciate all the help.
So, if I decide to try this with just one transformer.... Should I still use FWB1 and run the AC through it? I am assuming so.
Also, RG... you elude to Q6 as a regulator. I thought that Q6 was an NPN transistor in the Ludwig  ???
Finally, when I do try the single transformer... where would I check for the defining voltage to ensure I am getting what I need?
Quote from: Govmnt_Lacky on October 15, 2012, 07:19:52 PM
Yes. Put in the link to use the bridge rectifier as a full wave bridge rectifier, and connect the transformer secondary leads to the two "AC" pads on the PCB.
QuoteAlso, RG... you elude to Q6 as a regulator. I thought that Q6 was an NPN transistor in the Ludwig  ???
Q6 is an NPN transistors that is used as a voltage regulator, albeit a crude one.
QuoteFinally, when I do try the single transformer... where would I check for the defining voltage to ensure I am getting what I need?
Check the voltages to ground on all three leads of Q6. The collector should be 36V or more, the base 35.7 or more, and the emitter 35+/- half a volt.
Govmnt_Lacky
Thanks again RG  ;)
I must admit that I am quite a ways away from actually testing my Ludwig as I am still awaiting parts to show up  :-\
Once I get the build up finished and try out these transformers, I will post back with results.
BTW..... PM coming your way RG  ;)
Govmnt_Lacky
#24
OK....
I mocked up the PS section of the Ludwig on breadboard using all of the called-for components (TIP112 for Q6) and my transformer.
I ended up getting 34.25VDC at Q6 Emitter  :'(  A bit low.
Is there anything I can do to bump it up a bit? Perhaps some adjustments with R26 or R23. Will 34.25V with no load suffice in the circuit?
Thanks for the assistance  ;)
Jdansti
Quote from: Govmnt_Lacky on October 23, 2012, 01:59:04 PM
OK....
As for whether 34V will work or making some changes to get a little more voltage, I'll leave that to R.G.
If you need a DC/DC booster, the UC2577-ADJ might work, but it's not cheap at around $18.
http://www.ti.com/lit/ds/slus216a/slus216a.pdf
From the data sheet: "The UC2577-ADJ device provides all the active functions necessary to implement step-up (boost), flyback, and forward converter switching regulators. Requiring only a few components, these simple regulators efficiently provide up to 60V as a step-up regulator, and even higher voltages as a flyback or forward converter regulator."
"The UC2577-ADJ features a wide input voltage range of 3.0V to 40V and an adjustable output voltage. An on-chip 3.0A NPN switch is included with undervoltage lockout, thermal protection circuitry, and current limiting, as well as soft start mode operation to reduce current during startup. Other features include a 52kHz fixed fre- quency on-chip oscillator with no external components and current mode control for better line and load regulation."
http://www.mouser.com/Search/m_ProductDetail.aspx?Texas-Instruments/UC2577T-ADJ/&qs=/ha2pyFaduggwaU7%252bB8sFQLVDZIYB1n2MLatPrsmyLw=
Govmnt_Lacky
Fixed some not-so-obvious wiring issues on the breadboard  :icon_redface: And re-measured (this time without the transformer getting toasty  :icon_eek:)
Q6-
Base: 35.75V
Collector: 37.25V
Emitter: 35.70V
It was explained to me that in an "ideal" situation, you want the Collector at 3-6V higher than Emitter. This is obviously lacking (only 1.5V higher)
So the question now is... Can I run with this setup (with or without possible PS resistor value adjustments) -OR- do I need to look at running 2 transformers in series to bump up the voltages to get a larger seperation between Q6 Collector and Emitter voltages  ???
Hmmmmm.... help for the clueless please  ::)
Any chance you have a wall wart around that puts out 16vac to 18vac?
That would be about right to try a doubler on.
Govmnt_Lacky
Quote from: R.G. on October 24, 2012, 01:14:28 PM
Dont have any of those  :icon_cry:
I would really like to get these transformers into the Ludwig. I have 2 just begging to be used. If it is a matter of voltage being insufficient, I could always try running the 2 in series.
In the end, if I cannot get this to work within reason I will probably just go ahead and purchase the recommended wall wart but I would like to try Plan A first.  ;D
Thanks for all your help with this!!
The only thing I have against two 24Vac transformers in series is that they're likely to cause about 5W of heating in Q6. If you go that way, you'll need something similar to this:
http://www.mouser.com/ProductDetail/Aavid-Thermalloy/507302B00000G/?qs=%2fha2pyFaduguOHMd%2fQeWiVI5mWG%252bm0yKQkNwV4yhhPywG40xOa5m3g%3d%3d
