DIY Stompboxes => Building your own stompbox => Topic started by: rocket8810 on December 26, 2013, 10:11:10 PM
Title: EM Drive Problem/Debug Help (solved)
Post by: rocket8810 on December 26, 2013, 10:11:10 PM
Just built the EM drive, and put it into a 1590a box. It's my first 1590a build and I got something odd that I can't figure out.
When the pedal is engaged I get nothing but static, but I can control the volume. I checked continuity, and noticed that when the pedal is engaged there is no connection between input and output. But, by mistake I touched the box while testing continuity of the output and I got continuity, so it seems that the output jack is grounding. I've checked all the wiring, and board and can't find anything wrong. I'm going to make an audio-probe to further check, but not sure what to look for with it.
(http://i909.photobucket.com/albums/ac293/rocket8811/Em-Drive-with-trimmer_zpsd73ddaaa.png) (http://s909.photobucket.com/user/rocket8811/media/Em-Drive-with-trimmer_zpsd73ddaaa.png.html)
Everything is wired as it says, the only thing I did a little differently then normal was run the volume to ground directly to the switch as opposed to the output jack. Also, I used Marks offboard layout, as I always do.
(http://i909.photobucket.com/albums/ac293/rocket8811/Offboardwiring_zpsad406f95.png) (http://s909.photobucket.com/user/rocket8811/media/Offboardwiring_zpsad406f95.png.html)
Here's some pictures of the enclosure & board
(http://i909.photobucket.com/albums/ac293/rocket8811/IMG_2843_zpsbf0a9f28.jpg) (http://s909.photobucket.com/user/rocket8811/media/IMG_2843_zpsbf0a9f28.jpg.html)
(http://i909.photobucket.com/albums/ac293/rocket8811/IMG_2842_zps3e2daf03.jpg) (http://s909.photobucket.com/user/rocket8811/media/IMG_2842_zps3e2daf03.jpg.html)
(http://i909.photobucket.com/albums/ac293/rocket8811/IMG_2841_zps6e6872bd.jpg) (http://s909.photobucket.com/user/rocket8811/media/IMG_2841_zps6e6872bd.jpg.html)
(http://i909.photobucket.com/albums/ac293/rocket8811/IMG_2840_zpsd01236e1.jpg) (http://s909.photobucket.com/user/rocket8811/media/IMG_2840_zpsd01236e1.jpg.html)
Any ideas where or how this is happening? Any and all help will be much appreciated, i can't believe that such a small circuit would give me trouble like this.
Title: Re: EM Drive Problem/Debug Help
Post by: pappasmurfsharem on December 27, 2013, 01:07:39 AM
In the bottom image, the long red wire that goes by the switch.
Is that your ground? Hard to tell
Where that that connecting too?
Post by: rocket8810 on December 27, 2013, 01:05:03 PM
the red wire goes to the cathod of the led.
Post by: Hemmel on December 27, 2013, 01:28:38 PM
I think the problem might be with your switch.
Look at the last picture.
Not turning the picture, let's say the 9 lugs are
G H J
D E F
A B C
Why are lugs B and C connected ? That means that when you hit the switch one way, then B and C are connected, hit the switch again and now A, B and C are connected.
I would suggest you cut the connection between B and C.
Post by: nocentelli on December 27, 2013, 02:17:23 PM
It looks like IvIark's standard switch wiring: B,C and F are all connected to ground. This means B/C grounds the LED when the circuit is "on" (LED negative is connected to A), and F grounds the circuit input (E) in bypass. OP says he's got this switching system to work in the past.
Post by: Hemmel on December 27, 2013, 02:26:31 PM
Yeah I didn't notice the 2nd pic.
Disregard my post.
Post by: Ice-9 on December 27, 2013, 02:37:25 PM
Have you checked that the transistor is in the correct way around, I would check that the effect works without all the bypass switching, ie remove it and just connect the jacks to the in and out connections.
I can't see properly in the picture, but it looks like your PSU jack is a 3 prong switched version, is this correctly wired ?
Post by: rocket8810 on December 27, 2013, 02:49:44 PM
Thanks guys for the help, I really appreciate it.. the transistor was in correctly, but I did find the mistake. I kept thinking there was something wrong with my grounding, so I traced the whole grounding setup and found the problem. I'm embarrassed to say, but I screwed up the dc jack wiring. I had the ground attached to the positive lead, which would have been used by the battery if there was one. I totally feel like such a noob, but it happens.
Post by: nocentelli on December 27, 2013, 03:19:36 PM
Quote from: rocket8810 on December 27, 2013, 02:49:44 PM
.....it happens.
All the time, even if you've been building for years.
Title: Re: EM Drive Problem/Debug Help (solved)
Post by: rocket8810 on December 27, 2013, 04:27:23 PM
totally, and the worst part about it is that it was something that was so easy to overlook, which made this so much more annoying.
