DIY Stompboxes => Building your own stompbox => Topic started by: J0K3RX on June 08, 2014, 12:31:26 AM
Title: DIY Pickup Winding machine built on an ATmega8
Post by: J0K3RX on June 08, 2014, 12:31:26 AM
Stumbled onto this project, thought some might be interested... Schematic, source and hex compiled for ATmega8 @ 8Mhz
http://davidegironi.blogspot.gr/2014/05/a-pickup-winding-machine-built-on.html#.U5PhwXJdXK1
https://www.youtube.com/watch?v=gNgywx7ITok
Title: Re: DIY Pickup Winding machine built on an ATmega8
Post by: greaser_au on June 08, 2014, 08:09:27 AM
One wonders why do a complicated uP design when a very simple glue logic design will do the job. If it was completely automagic (as in set it up & walk away), then I could see the value.   All that said,  I suppose it would be a lot less wiring than a few counters & 7-segment displays - but (I expect) a LOT more effort in code - especially in a high-level language like C*. There was a time, not all that long ago, when a nice veeder-root mechanical counter would have been cheaper still :)
david  (transformer/coil winder from WAY back!)
*I designed, built and coded a coin rejector programmer for electronic coin mechs using an 8031 and 2x16 row display (in 8051 assembly) about 20 years ago.
Post by: Mac Walker on June 08, 2014, 07:32:25 PM
Looks like an analog output to control the speed, the DC motor has it's own PWM controller?
If you are going to take the leap to a micro-controller, I would think it would be easier to get a stepper motor from an old printer, and use a few digital outs, with transistors to step up the currents/voltages, and run the stepper motor directly...
Then a simple counter accumulates your # turns (scaled for steps/revolution).
Using an analog output requires a properly scaled integration function over time to accumulate the  # turns, especially when using a ramp up function.
The alternative is a handlheld drill, and LCD counter, a magnet, and a reed switch.....the last three can be had from China these days for about $12....
Post by: PRR on June 08, 2014, 11:11:24 PM
Instead of an actual counter, you can use the *cheapest* calculator. (Does not work on better calcs.)
Wire your switch across the "=" key.
Press "1" then "+".
Turn. Each pulse does a "+1" and the count goes up.
Post by: haveyouseenhim on June 08, 2014, 11:33:09 PM
Quote from: PRR on June 08, 2014, 11:11:24 PM
Press "1" then "+".
I saw a YouTube video where a guy used a calculator and a sewing machine to wind pups. He wired a momentary on the sewing machine to a calculator. Then used the machines footpedal to control the speed.
That's the way I would wind a pup. Seems like a simple effective way to do it.
