DIY Stompboxes => Building your own stompbox => Topic started by: acehobojoe on February 05, 2015, 12:57:09 PM
Title: 2n5457 static protection diode
Post by: acehobojoe on February 05, 2015, 12:57:09 PM
Do I need to put a static protection diode in my circuit? The 2n5457s seem to keep dying on me. :O I don't know what to do... it's all good until the popping. then more popping.. then it won't work.
Title: Re: 2n5457 static protection diode
Post by: armdnrdy on February 05, 2015, 01:25:40 PM
Joseph,
I think you should probably post a schematic for the circuit in question.
JFETs don't just "die"  :icon_wink:
Post by: acehobojoe on February 05, 2015, 01:57:54 PM
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/1016856_10155174993965553_1754072877014126956_n.jpg?oh=79a9d7de8e33d3139cdcb3abbd8d25fa&oe=5566E23B&__gda__=1432922987_dc437205203eb88fe6197b99835f77e7
The circuit works fine on the breadboard, but I may have messed it up on my brd file.
https://www.dropbox.com/s/9a0zcneeqvkubwx/live1.brd?dl=0
Post by: armdnrdy on February 05, 2015, 02:13:08 PM
What circuit is this?
You use dropbox so you can post the images directly to the post.
The Eagle file:
Many members that can offer help don't use Eagle so...they can't open the file.
Save the board image as a PDF and post that with dropbox.
Post by: acehobojoe on February 05, 2015, 02:26:44 PM
(https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/10445514_10155175111770553_3906698798036129445_n.jpg?oh=0198e40ff33c355a7786ed34aef04eff&oe=55550D0B&__gda__=1432952942_2abeceb097ba0fd2ee8e6d0f205c27c4)
Post by: acehobojoe on February 05, 2015, 02:50:59 PM
could it be that i did not solder the top of the solder pads? perhaps?
Post by: acehobojoe on February 05, 2015, 02:51:53 PM
https://www.youtube.com/watch?v=Sp6DiVB7QnU
Post by: armdnrdy on February 05, 2015, 03:04:15 PM
Anywhere that the bottom trace and the top trace comes together at a pad...the component lead has to be soldered on the top trace to connect the signal, power, gnd, etc, traces together.
You cannot do this with capacitors. (C3) You have to add a Via to connect the two board sides.
How is C1 and C2 soldered if you didn't solder the top pads?
Post by: armdnrdy on February 05, 2015, 03:06:43 PM
If I may make a suggestion...
Make the board a little larger and spread out the components.
Your traces are way too close to the component pads.
Post by: acehobojoe on February 05, 2015, 03:07:54 PM
I just soldered the bottom.
Post by: acehobojoe on February 05, 2015, 03:10:08 PM
Yea, I'll do that. This is my first pcb attempt, so it's a bit redundant and not very neat, but I'll make some new ones.
I'd still like to try to get this one to work.
So anytime you have traces on the top layer it must be soldered on the top?
Post by: armdnrdy on February 05, 2015, 03:23:59 PM
Quote from: acehobojoe on February 05, 2015, 03:10:08 PM
If it is a place where the top and bottom traces connect at a component lead....yes.
As I stated...that is how the top and bottom traces are connected.
You might want to start with a single sided board.
Double sided boards are very difficult...and not good for your first board.
There are people that have been etching their own boards for years that won't even attempt a double sided board!  :icon_wink:
Post by: acehobojoe on February 05, 2015, 03:30:03 PM
oh.... no, this is a fabbed board. I didn't bother etching.
It really looks great. just don't know if it has errors.
Post by: armdnrdy on February 05, 2015, 03:48:13 PM
Eagle has commands to check for errors.
ERC & DRC
Look them up on the net and learn how to use them.
Post by: anotherjim on February 05, 2015, 05:06:34 PM
So the holes are "thru plated", then you don't need to solder top as well as bottom, unless the thru's has failed. But a simple continuity check with the DMM can prove all of them.
Here's what I do, before even powering up, with a clean copy of the circuit, check each component as a separate item and write a check mark thru it on the drawing. A process I know as "correlation"
It gets a check when it's...
Present.
Correct value and rating.
Correct orientation.
...next each connection to that component is confirmed with a DMM continuity test.
Each line connection on the scheme gets a check when...
DMM proves it connects to the other parts of the circuit that the scheme shows that it should.
DMM proves it does not connect to any adjacent pin/trace that it should not connect with.
All checked -  now you can power it up.
BTW, if the design started on a breadboard, when you create the final schematic, use the check method to confirm the scheme shows what you have on the breadboard. Many a slip happens at this point.
Post by: acehobojoe on February 05, 2015, 05:07:46 PM
Thank you very much for those tips!
Post by: armdnrdy on February 05, 2015, 06:27:55 PM
Jim's correct about the through hole vias.
I had it in my head that this was a DIY board.
I took a quick look at the board...and beside the fact that there are traces that are much too close to other traces and pads...
I marked a few areas that look like they are touching in the image.
(https://dl.dropboxusercontent.com/u/53299166/DIYstompboxes/Board%20Bad.jpg)
Post by: karbomusic on February 05, 2015, 07:25:22 PM
Definitely need to download some design rules and use use 'em to check everything before submitting for fabbing if you made this yourself. There are some really good Eagle tutorials around here somewhere. I'd go through all nine or ten of those.
Post by: alanp on February 05, 2015, 07:31:31 PM
Pretty small holes and pads for components, there.
Post by: acehobojoe on February 06, 2015, 12:27:03 AM
transistors were backwards in the library too.. .
Post by: italianguy63 on February 06, 2015, 02:59:58 AM
Traces at Q1 are all cramped too...  MC
Post by: antonis on February 06, 2015, 11:50:27 AM
Quote from: alanp on February 05, 2015, 07:31:31 PM
And super extra tiny traces... :o
(risky for toner transfer and waste of etching solution and time...)
@ acehobojoe: You have to "play" a little with your own custom settings...
Post by: acehobojoe on February 06, 2015, 01:46:37 PM
what is a good pad size and hole size for average components?
Post by: armdnrdy on February 06, 2015, 02:34:47 PM
Quote from: acehobojoe on February 06, 2015, 01:46:37 PM
It depends on how component "busy" your board is. Same with trace size.
There are tutorials on the web..and R.G. wrote a book on the subject: PCB Layout For Musical Effects
http://www.goodreads.com/book/show/15747109-pcb-layout-for-musical-effects
http://smallbear-electronics.mybigcommerce.com/pcb-layout-for-musical-effects/
Post by: bloxstompboxes on February 06, 2015, 05:05:35 PM
I have R. G.'s book and can vouch for its excellence. Really educates or reminds you of the stuff you learned in school and the stuff you didn't. I use .08in outer diameter for my pads and .02in width on traces. I etch though so you could go smaller on the trace width for fabbed boards, and maybe even on the pad diameter. I just use that size diameter so I can drill most pads with a #59 bit and not have worry about whether the leads on a component will fit or not. I hate changing to a lot of drill bits throughout a project.
Post by: acehobojoe on February 06, 2015, 10:32:13 PM
I'm getting that book! I must have it.
Post by: acehobojoe on February 06, 2015, 10:39:09 PM
Where do I find it?
Post by: bloxstompboxes on February 06, 2015, 10:49:57 PM
Steve should have it at smallbear. http://smallbear-electronics.mybigcommerce.com/pcb-layout-for-musical-effects/
A bit expensive but I guarantee you'll like it and learn a lot. It is a little dated as far as the enclosures it talks about and software available but it's still awesome.
