Hi everyone..
I have watch some videos about op-amp comparison for drive pedal and they sound slightly different.
I have built a distortion with 3 stage gain with BOSS MT-2-like tone control. using 6 TL072 and it sounds monster.
Any best recomendation for good sounding opamp?
Imma looking for some bold and high gain opamp.
thanks
The most expensive ones. Duh!
Oh the irony........
If it sounds monster, leave it monster.
6 op amps. Did you use a TL074? its a qaud TL072.
Well, its easier for me to design the layout with dual op amp
(http://www.relatably.com/m/img/get-real-memes/bro-for-real_zpsa8cdedd1.jpg)
>Imma looking for some ...high gain opamp.
If you can find an op-amp that is not high gain, then I will be very impressed.
Ahh come on guys, I just want to try different op amp
ANY Op Amp (even μA702 or μA709) will give you HIGH gain in open loop arrangement..!! :icon_biggrin:
To be more serious, you have to search and validate some data sheet parameters, like Large Signal Voltage Gain, Slew Rate, CMRR, Bandwidth product, Signal to Noise Ratio e.t.c.
After spending many hours, enough amount of coffee (strongly recomended..), pencils & parer, parabolic stencil rulers (essential for Nyquist plots..) you'll result to grab any general purpose Op Amp is available in your junkbox and place it on your breadboard... :icon_wink:
P.S.
Start with LM1458 (do I hear some guys laughing..??) pass to TL072/TL082 then to OPA2134 and then to a discreat OP Amp of your own design taste..
Quote from: antonis on February 10, 2017, 06:13:05 AM
P.S.
That was really helping, thanks
Quote from: Agung Kurniawan on February 10, 2017, 06:45:35 AM
All the above answers should also be helping to you..!!! :icon_wink:
(maybe they didn't provide you the desipher code..) :icon_biggrin:
I generally stick to TL072, but here are some choices that often find their way into overhyped pedals*:
LF353, JRC4558D, NE5532
Otherwise, just take a look at what smallbear stocks and try a bunch of them.
*I do occasionally build pedals with these "magical" parts. Sometimes that's part of the fun. :icon_wink:
When it comes to high-gain distortion, sometimes what you really want is an op-amp with limitations. If a person was making a mic-preamp for sampling acoustic instruments, the you'd probably want something that was ultra low-noise (2nv/root-hz) and had a high slew rate (10V/usec), capable of handling 15khz content with ease.
But if the goal is to make a humbucker-equipped guitar really grind and sustain, then you're not interested in high-frequency content. A slew rate of 0.5V/usec is perfectly acceptable. And if the open-gain bandwidth shows serious rolloff above 5khz with gains greater than 200x, so much the better. The op-amp might be a little hissy, but then you're going to have lowpass filtering in there anyway to round the edges off the tone and tame all that added harmonic content. So don't underestimate the "poorly-dressed cousins" like the LM741, LM1458, and LM308.
6 dual opamps? why not string one of each in there, and have something really unique? it might take a bit of swapping/testing, but you could have an LF353 followed by a LM1458, a TL072, a TL022, an LM833, an LM358 [how many is that? we haven't even started on the NJM series].
Quote from: Mark Hammer on February 10, 2017, 08:32:40 AM
I still have a big pile of poorly-dressed 741s just waiting to get invited to rock out. Not sure if I'll let them directly into my signal path, but I should probably make
something out of them.
You'll never find a topic R.G. hasn't explored and explained first. :icon_smile:
Read through this, particularly under the heading, "The Opamp":
http://www.geofex.com/Article_Folders/TStech/tsxfram.htm
Poor old 741. It's kind of down there with the 555 as a "meh, that old crap". It's time will come again, oh yes. Wait 'till they've all been thrown out of the component drawers, just like we did with those crappy germanium parts - and that stupid vacuum tube stuff...
Long ago, I had an amazing (at the time) solid state amp - the H|H IC100S. The S stood for Sustain, which was a wicked gnarly distortion. Saw a schematic recently and am amazed that the overdrive "sustain" feature had no clipping diodes. +/-16v supplies and it was all done by clipping a 741. It was all based on 741's, even the discrete power amp has one as the driver stage.
Still open for someone to make a pedal of this. I'll have a go at it some day...
Was poking around in a Behringer BDI21, which is a "clone" of the long serving Sansamp bass D.I. Behri' have used a TL074 in the drive/presence boost section. If clipped, it sounds pretty nasty (not in a good way). I think I've tamed it by fitting LED soft clipping to the gain stages. I don't think TL07x like a big input - ok if only the output clips, but not if the input range is exceeded.
Again, if one was aiming for pristine, low-distortion, wide-bandwidth sound with a 90db S/N ratio, you'd steer clear of the 741. But this is rock and roll, folks, not studio processing, or sound reinforcement.
If you're making macaroni and cheese, you don't use the $13.95/100g stuff from France, you use the good old cheap bright orange stuff, because absolutely NONE of the nuances of the better cheese will be detectable, or yield the degree of comfort that the "old familiar" does.
+1 on the cheap bright orange cheese. Love that stuff! :icon_lol:
I just need to find a way to keep the cheap, bright orange cheesiness of the 741 from making a mess of everything near it. Maybe a g(r)ated effect of some kind, or perhaps using it in a LFO.
EDIT: From a brief amount of research, I apparently owe it to myself to build an MXR Distortion Plus.
I was working in this "casual" restaurant in New Orleans. We made this five cheese baked macaroni thing that was pretty incredible. Probably the best thing on the menu and was literally the thing that kept people coming back day after day. The place got bought. New owners sees the guy making the mac and how much cheese actually went into it and how much that added to in food cost and complained. The cook sarcastically says "Well you could just buy a bunch of boxes of Kraft, I guess." Next day, new owner comes in with a whole flat of the cheapest generic knock off of the old standard. :/
Quote from: EBK on February 10, 2017, 11:48:16 AM
It's an OK pedal, but it makes a lot of folks happy. Most of what is annoying about a 741 will be taken care of when you roll off the treble to keep the fizz out. In other words, yes, its noisy, but the filtering needed to optimize the tone is going to remove most of the audible hiss.
Currently on my BB sits a gray-spec OD-250, sounds cool, I plan on actually building it. I used half of a 1458, been wondering if it's worth the few cents to get a 741 and go full-on "correct" with it. I have to order an enclosure, pots and a footswitch anyway, so I might. Haven't tried the D+ yet, but I will in the next few days. My guess though is that I won't prefer the Ge clippers, this 250 doesn't seem to want any additional mushiness.
No idea if there's a sonic difference between a 741 and a 1458 in these circuits, surely very small if any. Analogman seems to think the 1458 has a bit more hiss. Dunno. But yeah, I guess my point is, I'm new to the 250/D+ experience myself, but I'm impressed. Sounds pretty refined for such a simple circuit. Try it out for sure, takes just a few minutes to BB it.
Quote from: deadastronaut on February 10, 2017, 06:32:14 AM
Why in gods name would he blend test with 40-50% clean? It really makes no sense if you what to study the sound of the
opamp in detail. It's like looking at the details of a painting from 30 feet away instead of 15 feet.
Dual & Quad versions can differ in sharing supply/bias networks. You would expect it would be done in a way that doesn't change specs compared to the Single, but read the fine print in the data! That said, I'd think it matters more that you have good supply decoupling close to the power pins to avoid interaction between the amps - assuming more than one in the package is in use. Of course, the unused ones must also be tied off as unity buffers as per best practice.
The LM747 is a "true" dual 741 in that each half has the offset null pins, and this is a headline from the datasheet...
QuoteThe LM747 is a general purpose dual operational amplifier. The two amplifiers share a common bias network and power supply leads. Otherwise, their operation is completely independent.
And the 1458, also dual 741 but without offset pins...
QuoteThe LM1458 and the LM1558 are general purpose dual operational amplifiers. The two amplifiers share a common bias network and power supply leads. Otherwise, their operation is completely independent.
Quote from: thermionix on February 11, 2017, 01:56:38 AM
The essential difference between the D+ and 250 is the clipping diodes used. D+ uses germanium, which will have a lower clipping threshold, hence more clipping at identical gain settings and hence less output. The 250 won't clip quite as much, but the hotter output level will push the amp harder. Depending on how much of your preferred level of grind comes from your amp or your pedal or the interaction of both, I can see where a person would prefer the D+ or the 250. An optimal arrangement might be a string of diodes to ground and appropriate toggle wiring to achieve the two sorts of outcomes. So, for instance, a back-to-back pair of Ge, in series with two back-to-back pairs of Schottky type (e.g., BAT46, 1N5817), and a 3-position toggle would yield the functional equivalent of the D+, the 250, and something in between.
Anyone here have a good e-book or link to read about opamp? I want to learn about opamp more deeper
Quote from: Agung Kurniawan on February 11, 2017, 09:25:12 AM
Search Google for a PDF of Op Amps for Everyone. 400+ pages of good stuff. :icon_biggrin:
to my ear, they all sound the same. expensive, cheap. the biggest factor for me is noise.
i tend to like 5532/34's (single or dual) a lot and use them, but mainly cuz an engineer friend gave me a big sack of 'em.
my best advice is socket and plug 'em in til ya like them.
the peripherals around them matter far more.
like... i built a rat the other day. first one. never got to it. i tried good chips, i tried bad chips, i tried the correct chip, the lm308 even.
didn't matter, still sounded like a freekin rat to me.
in the end i went with an lm301 in the mojo style (the round case ic) just cuz it had a little less hiss to it, but really, a 741 sounded just as good.
tlo61/71 didn't really change the tone for the better.
same thing with dual or quad op amps. the only real diff i've noticed is in the background noise. and that tends to vary from circuit to circuit.
so i'd say its more important to use flameproof resistors... less his and crackle than carbon comps
and if ya need low noise, i just use cheap chicklets for caps, or general, i just use ceramic.
the best sounding of the dirt boxes i've built were built with the cheapest crap. seriously. i built a klon with nothing but ceramics and electros and that thing sounded better than all the others.
the colorsound diphonizer (madbean's honey dripper ) same thing. ceramic sounded better.
so don't get too hung on components. use sockets and your ears.
I think most of the time spent worrying about mojo differences between op-amps would be better spent reading a good introduction to the op-amp, like the op-amp chapter in Horowitz and Hill's "Art of Electronics." (You can now get a used copy of the 1st edition cheaply on Amazon, at least in the US. Bonus - because the 1st ed is old, it lists some old parts like the LM308 and 741 in its table of op-amp specs!) A quote from that chapter:
QuoteOperational amplifiers have enormous voltage gain, and they are never used without feedback. Think of an op-amp as fodder for feedback. The open-loop gain is so high that, for any reasonable closed-loop gain, the characteristics depend only on the feedback network. Of course, at some level of scrutiny this generalization must fail.
As H&H allude, there are differences between op-amps, but they have to do with things like input impedance, bias current, and noise, that might make one type of op-amp work better in a circuit, but they aren't likely to produce mojo differences in tone. I don't know whether to find it amusing or bothersome that the idea of op amp mojo has gotten so much traction. To first order, the op-amp is a black box that does one thing very well (drive its two inputs to the same voltage), and the feedback network of the op-amp is what controls the circuit behavior.
Quote from: Mark Hammer on February 11, 2017, 09:19:08 AM
Just to update this parallel aside, I tried Ge clippers in my 250 breadboard project, didn't care for them. Sound got really trashy, splatty. Yes more gain but a difference in tone too. I'll go back to the 1N914s.
YMMV, yadda yadda yadda.
Anyone trying to get distortion from an op amp should realize that op amps are characterized for linear operation. All of their spec characteristics are defined for linear operation. If you are trying to push the signal level beyond the common-mode input range, different op amps will have different characteristics, for example, the LF356 will go hard over to a rail if pushed outside of the common-mode range.
For an LF356, exceeding the negative common-mode limit on either input will force the output to a high state, potentially causing a reversal of phase to the output. Exceeding the negative common-mode limit on both inputs will force the amplifier output to a high state. In neither case does a latch occur since raising the input back within the common-mode range again puts the input stage and thus the amplifier in a normal operating mode. This would make for an unpleasant non-musical distortion.
Exceeding the positive common-mode limit on a single input will not change the phase of the output however, if both inputs exceed the limit, the output of the amplifier will be forced to a high state.
The most important thing is that the unspecified characteristics of an op amp are not defined and therefore, they could be different for different manufacturers or even different factories. I had 15 Fairchild µA2240 devices at one time but some were Korean and some Malaysian. One national source worked, the other didn't in a circuit for an octave generator for an organ. The device is a 555-type oscillator connected internally to an 8-bit counter/divider with open-collector outputs (a very useful device as an octave generator or a sequencer). This is a largely digital part. How much more susceptible would a completely analog part be?
A more typical situation would be using a µA741 as an output buffer for a distortion. A 741 has such low open-loop gain at high audio frequencies that it would sound "warm" because it would eliminate the high-frequency "fizz" that comes from added distortion for any gain of about 5 or more. But some 741's may be better than others for gain, so the sound would be different.
I am in favour of using devices within published characteristics such that any device from any manufacturer could be substituted without a change in sound and without temperature sensitivity. Anything else is not suited for production.
Where do you guys study about op amp or any IC?
University? High school?
Quote from: Agung Kurniawan on February 12, 2017, 11:39:30 PM
I had some exposure to op amps during high school through independent tinkering, but I really learned most of what I know about op amps in college, mainly in my Sophomore year introduction to circuits course (while in pursuit of an electrical engineering degree). I remember thinking of op amps as quite magical due to their relative simplicity and amazing versatility. 20 years later, I
still like to think of them as magical. :icon_biggrin:
diystompboxes.com :)
