DIY Stompboxes => Building your own stompbox => Topic started by: natron_mn on August 03, 2017, 03:59:20 PM
Title: Add Standard Negative Tip DC Jack to ProCo Rat
Post by: natron_mn on August 03, 2017, 03:59:20 PM
Wondering if I'd be able to install a normal negative tip DC jack in a ProCo Rat? I'm not sure if switching from a positive tip to a negative tip would require a total reconfiguration of the circuit, or if it is a simple swap?
Title: Re: Add Standard Negative Tip DC Jack to ProCo Rat
Post by: vigilante397 on August 03, 2017, 05:00:16 PM
It's a simple swap. Take the positive connection from the original jack and connect it to the barrel (sleeve, whatever you want to call it) connection on the new jack, and the negative connection from the old will go to the center connection of the new. Piece of cake, and now you can use one of the greatest pedals ever created (in my humble opinion) with any standard power supply 8)
Post by: Kipper4 on August 03, 2017, 05:12:24 PM
Don't forget to relabel.
Post by: jimilee on August 03, 2017, 07:15:28 PM
Quote from: vigilante397 on August 03, 2017, 05:00:16 PM
I'm pretty sure there's more to it than that. Don't you have to reverse all of your polarity caps?
Sent from my iPhone using Tapatalk
Post by: Tony Forestiere on August 03, 2017, 10:40:31 PM
(http://3.bp.blogspot.com/-GAkpj045db8/Vp4PpEmEZ5I/AAAAAAAACKk/276nST3AcIw/s640/PROCO-RAT-white-face-1985-3.jpg)
Shoot. Looks like an old EHX style 1/8" plug. Easily adaptable. No cap flipping needed. If you are using a daisy chain, I have found this to be less trouble: (http://truetone.com/wp-content/uploads/2015/11/c35.jpg)
But then, I am lazy.
Yup.
Post by: vigilante397 on August 03, 2017, 10:58:16 PM
Quote from: jimilee on August 03, 2017, 07:15:28 PM
Absolutely not. You're not changing the polarity of the whole pedal, just the jack. The circuit board will not notice any difference. You will still be getting +9V where you should have +9V and ground will still be ground. You're just changing the jack.
Post by: thermionix on August 04, 2017, 02:12:13 PM
^Yes.  Assuming the new DC jack will be isolated from the enclosure.
Post by: natron_mn on August 04, 2017, 02:24:19 PM
Quote from: thermionix on August 04, 2017, 02:12:13 PM
What do you mean? Put a plastic spacer between the jack and the enclosure so as to not create a ground loop?
Post by: thermionix on August 04, 2017, 02:46:37 PM
Most new "2.1mm" DC jacks you'll see are plastic on the outside, and already isolated.
http://smallbear-electronics.mybigcommerce.com/2-1-mm-all-plastic-round-dc-jack/ (http://smallbear-electronics.mybigcommerce.com/2-1-mm-all-plastic-round-dc-jack/)
or
http://smallbear-electronics.mybigcommerce.com/dc-power-jack-all-plastic-unswitched-2-1-mm/ (http://smallbear-electronics.mybigcommerce.com/dc-power-jack-all-plastic-unswitched-2-1-mm/)
You don't want one that's going to connect + to the enclosure (ground), if you have one that's metal on the the outside (threaded part) you'll need to isolate it with nylon washers or something.
Post by: bloxstompboxes on August 04, 2017, 04:59:17 PM
I built my first pedal and tube screamer with a metal dc jack that I had to wrap in electrical tape to isolate from the enclosure. Hated it the whole time. Finally shoved that mess that was in a 1590BB into a 1590B and I am so much happier. Swapped out the jack too, of course.
Post by: vigilante397 on August 04, 2017, 06:04:05 PM
An excellent point, I would definitely recommend a plastic jack as linked above instead of a metal one. Do you already have a new 2.1 mm jack you were planning to use?
Post by: ashcat_lt on August 05, 2017, 02:05:06 PM
Quote from: natron_mn on August 04, 2017, 02:24:19 PM
Not ground loop, dead short that could kill a poorly-protected wallwart.  I don't know that it will hurt the Rat itself any, except maybe to burn the jack.
Post by: natron_mn on August 07, 2017, 11:06:01 AM
Quote from: vigilante397 on August 04, 2017, 06:04:05 PM
I have a few all plastic dc jacks. I do not have a RAT, though. I was going to purchase one if I could add a standard jack to it, and it sounds like I can!
Post by: thermionix on August 07, 2017, 04:02:59 PM
What is this "purchase" you speak of?
Post by: natron_mn on August 07, 2017, 04:17:29 PM
The purchase was in reference to a RAT. I was going to buy a used RAT on Reverb or something, but first wanted to know if the dc jack was a simple swap.
Post by: Tony Forestiere on August 07, 2017, 05:39:14 PM
Quote from: thermionix on August 07, 2017, 04:02:59 PM
I think you (OP) are being goaded into rolling a Rat of your own.  ;D
Post by: vigilante397 on August 08, 2017, 12:23:50 PM
Owning a RAT is super cool, but it's true the RAT is not a very complicated build. I stopped counting how many I've made  ::) but the RAT will always have a place on my pedalboard.
Post by: natron_mn on August 08, 2017, 12:24:37 PM
I've built a couple of RATs too, and I should just order another pcb to build one.
