DIY Stompboxes => Building your own stompbox => Topic started by: Bassaholica on March 27, 2018, 05:58:59 AM
Title: Fading leds Crybaby GCB-95
Post by: Bassaholica on March 27, 2018, 05:58:59 AM
 Hi, I would like to add 2 leds to my crybaby that will fade and brighten when I'm using the pedal. Would anyone be able to help mute with this as I don't know if it's possible?   Thanks all.
Title: Re: Fading leds Crybaby GCB-95
Post by: Kipper4 on March 27, 2018, 12:27:23 PM
Hi and Welcome Bassaholica.
Do you mean like a light plate with flashing leds when the wah is engaged?
Post by: vigilante397 on March 27, 2018, 02:20:03 PM
I'm picturing more like heel position -> dim lights, toe position -> bright lights and fading between the two depending on position of the wah. Am I getting that right?
Post by: thermionix on March 27, 2018, 10:44:45 PM
Dual-ganged wah pot?
Post by: bluebunny on March 28, 2018, 02:52:34 AM
Quote from: vigilante397 on March 27, 2018, 02:20:03 PM
Hmmm...  Seems like some kind of "visual sound" arrangment?  I dunno... sounds kinda crazy, but you never know - someone might think it's worth running with...  ;)
Post by: Bassaholica on March 28, 2018, 09:37:09 AM
Yes, that's exactly what I'm looking for. I'm assuming it would have to be connected to the pot but I wouldn't know where to start.
Post by: Kipper4 on March 28, 2018, 10:03:41 AM
Well as someone suggested a dual pot might be easiest. Make the led pot into a voltage divider to supply the led.
Trouble with that is, finding a dual  pot with a wah taper.
Show us the schematic please.
Post by: italianguy63 on March 28, 2018, 10:11:04 AM
Quote from: Kipper4 on March 28, 2018, 10:03:41 AM
I recall someplace in the recess of my mind, that somebody did that once, and bonded the shafts of 2 pots together....
MC
Post by: deadastronaut on March 28, 2018, 10:28:44 AM
MUTE warning.... ::)
or a pair of these....with ldr's  (front/back of wah..)
Post by: italianguy63 on March 28, 2018, 10:33:11 AM
Quote from: deadastronaut on March 28, 2018, 10:28:44 AM
Thanks Rob.  For a moment I thought I might start to RAVE.
Post by: deadastronaut on March 28, 2018, 10:38:47 AM
yeah i always mute , why the bloody rave crap...and is always effing loud... :icon_rolleyes:
Post by: Kevin Mitchell on March 28, 2018, 10:42:51 AM
With my somewhat unconventional ways of getting around things...
To keep the original wah taper you could wire it to a dual resistor photocell - such as the VTL5C3/2 or a home-brew version with 2 LDRs and an LED to the wah taper. You'd have to add a resistor in series to get the right min and max resistance from it (0ohms to 100k ohms). You could add a SPST switch to the LED wiring for visual on/off. The wah taper would then control the LED of the photocoupler pretty much converting it to a dual pot.
I may try this on my wah tonight just for the concept. It's a little more complicated than how I've explained  ;D
Also someone mentioned a LED plate for the bottom cover which is a great idea if you're into it. There are some sellers for these transparent plates around the web. The floor beneath the pedal would light up apposed to a couple small mounted LEDs.
Post by: Bassaholica on March 29, 2018, 04:21:00 AM
I've seen the base plates, they look great, I might try them with a different project. I'm really looking for the leds to connect to the pot so they brighten and dim with the pedal in action.
Post by: thermionix on March 29, 2018, 12:41:47 PM
It's not impossible, you could add a second geared pot, perhaps linear taper, to mesh with the gear on the actual wah pot (toe side), but you would need to come up with a way to mount it.  If you have some aluminum angle, a drill, and a dremel, it can be done.  If there's room for all that.
