DIY Stompboxes => Building your own stompbox => Topic started by: iainpunk on September 04, 2018, 01:52:58 PM
Title: Overdrive/fuzz squeeling and buzzing.
Post by: iainpunk on September 04, 2018, 01:52:58 PM
Hey everyone, need some help
Ive build the following schematic on my breadboard, its a pedal that does both a grainy overdrive and a gritty fuzz.
(https://s15.postimg.cc/yhgis3uaf/IMG_20180904_193908.jpg) (https://postimg.cc/image/yhgis3uaf/)
Both out a and b go to a spdt switch to switch between overdrive and fuzz.
Th problem comes when i turn up the volume on the fuzz side, when above noon (Which is about unity volume) it starts to squeal and/or buzz really hard, like an oscillating fuzz. This however, is a bug and not a feature. I tried everything on the debugging list i could think of.
Any suggestions?
Thanks in advance, iain
Title: Re: Overdrive/fuzz squeeling and buzzing.
Post by: iainpunk on September 04, 2018, 02:55:23 PM
Nevermind, the switch has capacitive properties, large enough to let signal back in to the 2nd stage, which makes it oscillate.
Im goibg to buffer the middle putput with a gain of -1 so its in phase with the output at the end so i can blend between them
Post by: thermionix on September 04, 2018, 03:01:54 PM
Unrelated, but you might consider an input cap too.
Quote from: iainpunk on September 04, 2018, 02:55:23 PM
I'm not totally following you, but if you've selected Output B, the Q3/Q4 portion of the circuit is still connected.  Maybe it's not a switch capacitance issue, but I'm probably misunderstanding.
Post by: iainpunk on September 04, 2018, 04:13:28 PM
Well, leaving the "2nd stage" connected or not would in theory (and practice)(if the 'out b' were buffered) not make any difference, since jfets have only a small capacitive impedance on their inputs, and about 20Mohm of resistance. This doesn't really change the signal.
And yeah, i have an input cap, but forgot to draw it, since its on the other side of the bypass switching.
