DIY Stompboxes => Building your own stompbox => Topic started by: vinceg on September 04, 2018, 05:50:14 PM
Title: TS808 diy clone or Strat noise
Post by: vinceg on September 04, 2018, 05:50:14 PM
Hi, I'm new in stompbox building. I assembled a ts808 clone. It works well with my two humbucker guitar, but when I plug a stratocaster too much noise. My strato if plugged directly in amply is more quiet, with screamer too much noise. My Prs is quiet with screamer, only little wish when drive turned to max. what could be the problem?
Title: Re: TS808 diy clone or Strat noise
Post by: ElectricDruid on September 04, 2018, 06:04:57 PM
Welcome!
If the pedal is quiet with humbucker pickups and more noisy with single coil pick-ups on the Strat, there probably isn't anything wrong with it at all. That would be what you'd expect, and that's why people invented "hum bucking" pick-ups in the first place - the single coil type are a bit noisy!
HTH,
Tom
Post by: GibsonGM on September 04, 2018, 06:13:07 PM
The pedal is probably amplifying noise that is "not hum-bucked", like Tom says.   That makes it MUCH more obvious!
Welcome to the forum, Vince!
Post by: phaeton on September 04, 2018, 11:57:39 PM
A side effect of the 'out of phase' wiring in a Strat is that the two active pickups act like a humbucker.  If you flip your pickup selector into 2 or 4 position on the Strat, I'll bet that all (or a whole damn lot) of the noise disappears.
Like the other guys have said that noise is always there, just very faintly.  The TS808 is just amplifying it.  I have a strat with a pair of H-90 single coils on it.  If I use any sort of distortion at all I pretty much have to keep both pickups on to silence the noise.
Post by: vinceg on September 05, 2018, 12:39:34 AM
Hi, thank's for welcome in this forum and for yours answer.
So, despite my Strat is quiet in bypass mode, it's normal a noise with effect turn on.
And why the pot volume of both guitars, one with single coil and one with humbucker, scratches when turned with effect on?
Post by: thermionix on September 05, 2018, 03:38:32 AM
Quote from: vinceg on September 05, 2018, 12:39:34 AM
Volume pots get scratchy if they're in need of cleaning, or if they have DC voltage across them.  You can measure for DC with a meter, it will likely be a very small voltage if present.  If you do find DC it may be leaking from a faulty input cap in your pedal.  If not, clean the pots with DeOxit or similar.
Post by: vinceg on September 05, 2018, 04:45:51 AM
Quote from: thermionix on September 05, 2018, 03:38:32 AM
I mean guitar's volume pots, I do non think they have a DC voltage and they are new pots and I cleaned them
Post by: vinceg on September 05, 2018, 05:00:48 AM
Sorry, about noise, first I forgot to say that I reduced the 4k7 resistor with 2k2. Can this mod increase noise?
Post by: thermionix on September 05, 2018, 08:08:11 AM
Quote from: vinceg on September 05, 2018, 04:45:51 AM
Right, I'm talking about the guitar volume pots too.  Assuming your guitars have passive electronics, the only way to get DC on the pots is for it to come from whatever you plug into.  Tube Screamers and most other pedals have an input cap that should block DC from working its way back up the signal chain, but if the input cap is leaking DC it can happen.  It only takes a fraction of a volt to make the guitar pots audibly scratchy.  If you have a meter it's an easy test, you don't even need the guitars handy.  Just plug a cable into the pedal, with the effect on, and measure for DC voltage between tip and sleeve of the plug at the other end of the cable.  Set your meter to the lowest scale if it isn't autoranging.
Post by: vinceg on September 05, 2018, 11:01:39 AM
Quote from: thermionix on September 05, 2018, 08:08:11 AM
Wowww I did not know about this. I will test as soon as possible. In case I find DC voltage can I replace with any cap?
Post by: GibsonGM on September 05, 2018, 03:33:50 PM
If possible, you'd open the effect the DC is coming from and find which cap is bad, and replace with the same value or as close as you can find.  Using other values can make the effect sound different (tone-wise.....those caps are like "AC resistors").
Post by: phaeton on September 05, 2018, 04:04:47 PM
...or if they have DC voltage across them.
I did not know this.  Thanks for the... tip.
Of course, I roasted a pickup in one of my guitars with a shorted input cap, so I *always* always ALWAYS check any new circuits for DC on the inputs and outputs before I plug anything into them.  Every time.
I learned this one the hard way :-/
Post by: vinceg on September 05, 2018, 04:31:48 PM
The cap sholuld be C1 and should not make effect in the sound, is not it?
What could happen if it is larger?
(https://s8.postimg.cc/cdamuu7ox/tube-screamer-true-bypass-schematic.png) (https://postimg.cc/image/cdamuu7ox/)
Post by: phaeton on September 05, 2018, 05:11:17 PM
Lest I'm misreading that schematic, if that switching jack is wired like that, then it won't run off the battery at all.  It's designed to disconnect the battery after you insert the cable.  Mind you, there will probably be a quick blip of DC in the cable right as you insert it.  If it's mis-wired, it could inject constant DC into your guitar.  Best test is to plug a cable into the effect, and measure for DC Voltage between tip to ring on the other end of the cable.
There are a few other things about that subset of schematic that are a bit odd as well, like the ground symbol connecting R4 to the junction of R5.  I'm guessing they're not supposed to be connected, but the schematic might suggest they are.
Post by: phaeton on September 05, 2018, 05:31:10 PM
To answer your question though, yes the cap can change the sound.  Generally, smaller input caps cut off bass response, larger ones let more in.  This is especially true when you have resistor nearby creating an RC network.  It's a tad complicated and someone else can certainly answer it better than me.
IIRC the TS has around a 0.022uF cap on the input, but something within 15 or 20 % probably won't cause THAT much difference.  You can always try it and see.  You may like the difference.
That said, you generally want that cap between all power connections and the tip of the cable.
For reference, here (http://www.generalguitargadgets.com/pdf/ggg_its8_sc.pdf) is GGG's true-bypass TS-808 that is tried and true.  Note how the battery is switched in/out using the ground (ring) of the cable.
Post by: vinceg on September 06, 2018, 01:21:23 AM
Quote from: phaeton on September 05, 2018, 05:31:10 PM
This is how I assembled th circuit, can you see if there is a mistake on the switching jack
(https://s8.postimg.cc/8clkiu4kx/image.jpg) (https://postimg.cc/image/8clkiu4kx/)
Post by: vinceg on September 06, 2018, 02:45:52 AM
I plugged a cable in imput jack and measured DC voltage. I found a 2.8V DC  :icon_rolleyes:
I changed 22nf C1 but nothing changes, there is a 2.8 DC voltage between the ring and the other end of the cable.
(https://s8.postimg.cc/3shb3h2lt/ts808.jpg) (https://postimg.cc/image/3shb3h2lt/)
Post by: Slowpoke101 on September 06, 2018, 02:53:36 AM
Is the cable that you used a mono cable (tip and sleeve) or a stereo cable (tip, ring and sleeve)?
The wiring diagram of your input jack wiring looks OK. But I'm not sure about the DC jack's positive (red) wiring. Those wires may need to swapped over.
Post by: vinceg on September 06, 2018, 02:59:23 AM
Quote from: Slowpoke101 on September 06, 2018, 02:53:36 AM
The cable is a mono. The DC jack's I think is ok, I've 9V in the correct point. The problem is a 2.8V DC in the imput cable
Post by: Slowpoke101 on September 06, 2018, 03:15:38 AM
Very odd. Is there any chance that you can upload a picture of the pedal's wiring and a close-up of the input jack's connections?
A DC voltage certainly explains the scratchy noises from the guitar's volume control. I can also understand your concerns about ruining any pickups - not cheap.
Post by: vinceg on September 06, 2018, 03:28:04 AM
Quote from: Slowpoke101 on September 06, 2018, 03:15:38 AM
Yes, only a moment
Post by: vinceg on September 06, 2018, 03:40:33 AM
Thanks to your suggestion of the pictures, I discovered this connection between input and one resistor that should not be there.
Now there is not 2.8V DC but there is a small negative voltage, -3.4mV between tip and sleeve of input cable. Do I still have a problem?
(https://s8.postimg.cc/qfnu1b9zl/20180906_092246.jpg) (https://postimg.cc/image/qfnu1b9zl/)
(https://s8.postimg.cc/ob3h09qdd/20180906_092147.jpg) (https://postimg.cc/image/ob3h09qdd/)
(https://s8.postimg.cc/w3u4sam2p/20180906_092208.jpg) (https://postimg.cc/image/w3u4sam2p/)
Post by: vinceg on September 06, 2018, 03:42:01 AM
(https://s8.postimg.cc/hxedx6t8x/20180906_091916.jpg) (https://postimg.cc/image/hxedx6t8x/)
Post by: Slowpoke101 on September 06, 2018, 03:54:49 AM
Your build seems to look pretty good.
Excellent work on finding that little solder bridge - they can happen all too easily. Very good that the 2.8Volts is now gone.
The input jack wiring looks correct. No problems there.
Now, the very small voltage that you are measuring is most likely some stray voltage your meter is picking up from its leads - like an antenna. Not to be overly concerned about.
But one thing that you may wish to consider - Install a 1M (1 Meg) resistor between the Input pad and the GND pad on the board. This will keep any leakage voltage (normally happens) from the input capacitor from building up. This helps reduce any popping noises when changing from Bypass to engaged modes.
Hopefully your scratchy noises from the guitar's volume control will be gone now. Just remember that single coil pickups are notorious for picking up any electrical noise and coupled with the high gain of this pedal you will have some noise. Humbucking single coils or shielded pickups are available but they do sound different and they are not cheap.
Post by: vinceg on September 06, 2018, 04:13:31 AM
Ok, now I'm going to install a 1M resistor and I'll try the build. I'll let you know. Thank you very much :)
Post by: vinceg on September 06, 2018, 05:13:28 AM
@Slowpoke101 yeahhh, now it work good, no guitar volume scratches, no popping noise when changing to bypass to engaged mode and, surprise, no hiss noise in humbucker or single coil. Also, I note a better sound. I'm very happy  :)
Thank you very much!!
Post by: anotherjim on September 06, 2018, 05:29:18 AM
Going back to earlier notes about Stat's humbucking in 2 & 4 positions - they don't all have that, depends on the particular guitar & if it has original pickups. It must be 5 way switched guitar with a middle pickup with a reversed coil winding and reversed magnet polarity (known as RWRP) compared to the neck & bridge pickups. I have a 1980's Tokai which has a 5 way selector but no RWRP middle pickup, so no humbucking.
Hendrix's Strats only had 3 way selectors & probably did not have RWRP pickups either. The mod at the time to get 5 way selection was to pull the little ball bearing detent out of the switch lever and move it to where it sounded like it was in positions 2 or 4. When this eventually wore too loose to stay put, a couple of matchsticks were wedged in - no Blutack back then ;)
Post by: thermionix on September 06, 2018, 11:17:33 AM
Quote from: anotherjim on September 06, 2018, 05:29:18 AM
Hendrix's Strats...probably did not have RWRP pickups either.
I guarantee they didn't, I'm not sure when Fender started doing that but I think the 80s.  All the vintage Strats (and Les Pauls, SGs, 6120s etc) used the same pickups in all positions.  Obviously not the Telecaster, but the Esquire...yeah.  ;)
You're right about the 3-way lever switches, they're MBB and players noticed the cool sounds they'd get in between positions, and started modding the switches for 2 additional stops.  I guess it was the 70s when Strats started coming stock with "pre-modded" switches.  Then some time after that the RWRP middle became the norm.  That may have started with aftermarket replacement pickups, but I don't know.
Post by: phaeton on September 07, 2018, 10:35:55 AM
Quote from: thermionix on September 06, 2018, 11:17:33 AM
My English teacher in HS had a ('72 IIRC) Fender Strat with a teeny little toggle added on the pickguard.  He said it was a mod to "turn on all the pickups" but to me it sounded more like it enabled the center pickup regardless of the (3-way) switch position.  Of course, at the time I was just a 13-year old who was just getting into guitars and their ruinous lifestyle.
The biggest thing I remember from that guitar was the blonde w/ black + maple fretboard color scheme.  It remains one of my favorites to this day.
