DIY Stompboxes => Building your own stompbox => Topic started by: Sesh on April 30, 2020, 11:14:20 AM
Title: Wasp Filter Pedal - odd value resistor & rotary switch
Post by: Sesh on April 30, 2020, 11:14:20 AM
Hi DIY'ers
I'm in the middle of making the Sonusfluxa stripboard layout of the Wasp filter (cool lo-fi synth filter!).
The layout, however, has two parts that I've had a hard time sourcing: A B47K pot (can only find 50K) and a 1P4T rotary switch.
I've tried looking up how to replace these type of parts with different types/values, but finding something condensed and specifically about guitar pedals has been hard to find.
So: What can I buy instead of those two hard-to-find parts - and why does that work? (I mainly source from Banzai & Musikding.de)
Title: Re: Wasp Filter Pedal - odd value resistor & rotary switch
Post by: idy on April 30, 2020, 11:37:25 AM
For the pot use the 50k. That is close enough and its a pot! You may lose a tiny bit of extreme but that's what we do. Pot tolerance is pretty wide, you may find a 50k that measures closer to 47k, but probably the guy that designed it couldn't get 50K and had to settle for 47k :). Different times and places manufacturers made diffferent series.
For the rotary you use the 1 pole 12 position. The plastic ones (I forget about the metal ones) have a "keeper washer" that allows you to select how many positions you want. Banzai has these. Lots of places do.
Post by: Sesh on April 30, 2020, 11:49:16 AM
Quote from: idy on April 30, 2020, 11:37:25 AM
awesome!! thanks a bunch
Post by: idy on April 30, 2020, 12:07:28 PM
For the 1x4 you could also use 2x6 or 3x4. Look ahead and think what you might need in the future and order a few if you can....
Post by: FUZZZZzzzz on April 30, 2020, 02:04:13 PM
Cool! which WASP layout are you preferring too?
Quote from: Sesh on April 30, 2020, 11:14:20 AM
Hi DIY'ers
Post by: Sesh on April 30, 2020, 04:18:38 PM
Quote from: idy on April 30, 2020, 12:07:28 PM
I found (and ordered, amongst other stuff) the adjustable 1P2-12T rotary, you talked about. Super neat! But yeah, I've read that you can use those, too, but wouldn't I have some positions that then does nothing?
Quote from: FUZZZZzzzz on April 30, 2020, 02:04:13 PM
This badboy:
http://guitar-fx-layouts.42897.x6.nabble.com/Jurgen-Haible-Wasp-VCFilter-td31320.html
Post by: anotherjim on April 30, 2020, 04:36:02 PM
All the Alpha/Lorlin rotary switches can be limited to any stop. A 2P6T can be limited to 4 throws and the extra pole used to switch panel LED's. A 3P4T doesn't need limiting at all.
Hint - use a tiny amount of glue to hold the limit washer in place - 'cause it easily falls off until it's bolted in.
Post by: FUZZZZzzzz on April 30, 2020, 04:38:47 PM
I'm currently building a Jasper Synth (between all my other projects). A synth clone of the WASP. The filter part is already working and very cool. Worth your while ;)
Post by: Sesh on April 30, 2020, 04:45:41 PM
Quote from: FUZZZZzzzz on April 30, 2020, 04:38:47 PM
Awesome! Yeah, I knew it from the synth world already, why I choose it over, say, an Evil Filter that has vero layouts as well.
With a droney, fuzzy, reverbsoaked sound, this filter and an EHX 8-Step Program or something like that feeding into the cv input of the filter = ambient guitar heaven.
Post by: frequencycentral on April 30, 2020, 06:46:20 PM
This is mine:
Post by: ElectricDruid on April 30, 2020, 08:00:11 PM
"How to get huge sounds out of tiny synths (with just a bit of outboard)"
Thanks! Great fun!
