DIY Stompboxes => Building your own stompbox => Topic started by: m7b52000 on June 24, 2020, 08:27:56 PM
Title: Numbering of trimpot lugs?
Post by: m7b52000 on June 24, 2020, 08:27:56 PM
I am about to build a FF on a PCB. I am going to use external pots in place of the internal trimpots but want to make sure I get the solder lugs right. Is the numbering consistent between trimpots and pots i.e 1 on left looking down at the screw controller?
Title: Re: Numbering of trimpot lugs?
Post by: GGBB on June 24, 2020, 09:46:09 PM
In my experience, 1 is counter-clockwise from the front of the control. Which for "our" kind of external pots is looking down at the top of the shaft. With the lugs pointing down and control counter-clockwise, the left lug is connected to the wiper/middle, so that makes it "1". Trimpots vary in orientation of the "control" to pins - best to look for some kind of indicator on the device or check the spec sheet. Or just test it with your meter.
Post by: mth5044 on June 24, 2020, 09:46:54 PM
Most trimmers will have a '3' and/or a '1' printed somewhere on the body to tell you. There are many different types of trim pots, and just looking at it from above may not be enough information. Can you share what trimmer your using?
Post by: m7b52000 on June 24, 2020, 11:43:01 PM
Currently away on hols. Will look closely when I get home!
Post by: bluebunny on June 25, 2020, 03:45:00 AM
The order of the pins doesn't really matter for a trimmer: it's a trimmer.  If it's not obvious from looking at it which are the ends and which is the wiper, then you can test easily with your DMM.
