DIY Stompboxes => Building your own stompbox => Topic started by: yeeshkul on August 20, 2020, 07:08:57 AM
Title: Voltage doubler with ICL7660S
Post by: yeeshkul on August 20, 2020, 07:08:57 AM
I am about to use the doubler on the picture below to pump 9V to  18V.
I see 10uF caps are used.
Would bigger caps - like 100-220uF improve the function somehow?
(https://i.postimg.cc/MX49mh21/doubler-420x315.jpg) (https://postimg.cc/MX49mh21)
Title: Re: Voltage doubler with ICL7660S
Post by: Mark Hammer on August 20, 2020, 08:04:39 AM
Your use of the word "somehow" is open-ended enough that you have no particular expectation.
One of the caveats of charge pumps is that they rely on an internal clock, which can provide audible whine in some circumstances.  Connecting pins 1 and 8 doubles the clock frequency, but that doesn't mean the clock couldn't be audible in some way.  So, like yourself, I'm curious about whether use of other cap values can offer some improvement in that area.  I'll qualify this by stating that I don't actually know if:
a) this is possible
b) the charge pump itself is actually the optimum place to try and reduce whine
c) any change to cap values has to be the same across all such caps (e.g., if tripling voltage, do all 3 caps have to be the same value?)
Like yourself, I eagerly await replies from others.
Post by: yeeshkul on August 20, 2020, 08:14:40 AM
Mark, i have been using 100uF/50V between the diodes and 220uF/35V at the output. First i used 56ohm/220u low pass filter at the output, but then i removed the resistor since it wasn't whining at all and the resistor was lowering and softening the output a bit.
I am asking merely because i am courious, the above stated has been working just fine for me. Star grounding helps also.
Post by: antonis on August 20, 2020, 08:42:48 AM
IMHO, bigger caps improve (to some extend) load drive current regulation/capability..
Post by: Mark Hammer on August 20, 2020, 09:22:40 AM
So are the 10uf values we generally see in drawings a recommended minimum value and no sort of absolute requisite?
Post by: antonis on August 20, 2020, 10:50:23 AM
I presume so, Mark..
(they are a golden mean between affortable voltage ripple & maximun current..)
Post by: duck_arse on August 20, 2020, 11:28:48 AM
the Intersil ICL7660 datasheet [3072.4] includes the note:
QuoteNOTE: For large values of C OSC (>1000pF) the values of C1 and C2 should be increased to 100μF.
suggesting only lower pumping frequencies need bigger caps. it also mentions increased cap size benefits can be lost due to increased ESR of the large caps. so low ESR 10uF's might be the best bets.
Post by: antonis on August 20, 2020, 11:46:58 AM
Can't see any reason for facing it like something different of "conventional" voltage doubler charge pump..
Post by: PRR on August 20, 2020, 07:54:36 PM
A couple-hundred uFd might be good for 50/60Hz AC.
This thing runs, what, 10KHz? 20kHz?? So a couple hundred times *smaller* would be to-scale. One or two uFd.
At heavy load, ESR matters. Old e-caps in small uFd could have high ESR. That's why they spec 10uFd (which don't cost more than 2uFd).
Post by: Rob Strand on August 20, 2020, 09:07:46 PM
There's a graph in the data sheet of output droop vs cap size.
Low ESR caps improve most aspects.   See appendix A for ripple,
https://www.maxlinear.com/appnote/ani-19_selectingchargepumpcaps_072406_d.pdf
