DIY Stompboxes => Building your own stompbox => Topic started by: DJPsychic on November 08, 2021, 07:18:49 AM
Title: Klone Unity level issue
Post by: DJPsychic on November 08, 2021, 07:18:49 AM
Just completed my first Klone using the Sabro layout (https://www.sabrotone.com/klon-centaur-build-finished/)
I wired true bypass and omitted (numbers via original schematic) R3, R4, R26, R27, R28 & C2. I'm also using a MAX1044 instead of the 7660 as I was having noise/level issues.
After some trial and error I finally got working. It sounds nice but I think my unity level is a bit low. On a lower-mid gain setting the VOL is turned to 1-2 O'clock to reach unity.
Other Klones I have, unity is reached much earlier (around 9 o'clock).
I also notice I'm not getting the same fullness/magical harmonics from other Klones I have. May have to try some other diodes. I'm using NOS single black band 1n34as
Any suggestions are greatly appreciated
Title: Re: Klone Unity level issue
Post by: ElectricDruid on November 08, 2021, 07:46:22 AM
Sounds to me like there's something wrong still. Not something critical, but perhaps a wrong value somewhere, giving you not enough gain and therefore not enough level or harmonics.
Keep hunting?
Or post some voltages/pictures and let us lot take a look. You never know, someone might spot something. Fresh eyes helps.
Post by: DJPsychic on November 08, 2021, 08:07:34 AM
Hey Druid,
Not sure photos will help, it's a bit messy. I'll go through everything again today and match it against the layout. Voltages seem good as well.
IC1
1: 4.56
2: 4.56
3: 3.9
4: 0
5: 4.7
6: 4.5
7: 4.6
8: 9
IC2
1: 4.4
2: 4.3
3: 4.4
4: -8
5: 4.2
6: 4.4
7: 4.3
8: 15.6
IC3
1: 9
2: 4.5
3: 0
4: -4.2
5: -8.4
6: 3.4
7: 6.14
8: 9
(https://i.postimg.cc/t7TtZBST/IMG-0662.jpg) (https://postimg.cc/t7TtZBST)
Post by: DJPsychic on November 08, 2021, 04:14:53 PM
Yay figured it out.
I had the wrong value in the Sabro R25 (560R).
Also had a gain wire in the wrong hole on board.
All good now!
Comparing it to an AF2 (aluminum Falcon) that I have, it's very very close. Mine is slightly thinner/brighter than the AF2. The AF2's mids are slightly smoother/Warmer, fuller lower end. I imagine this is where diode selection play a role. May try swapping the 3.9nf with a 6.8
Any pointers always welcome
Thank you!
Post by: DJPsychic on November 08, 2021, 04:35:18 PM
Edit/
