DIY Stompboxes => Building your own stompbox => Topic started by: Mark Hammer on December 24, 2021, 12:24:05 PM
Title: An intriguing idea for using sample & hold
Post by: Mark Hammer on December 24, 2021, 12:24:05 PM
Too many things to get to for me to do the R&D, but I thought I'd throw it out there for those who are adventurous enough.  I have to credit Moritz Klein's excellent Youtube channel for jogging my thinking.
Sample & hold units traditionally use a clock to feed a fixed-width pulse to the gate of a JFET.  When turned on, the gate allows a storage cap to charge up and hang onto that voltage until the next clock pulse/step.  We are most familiar with the use of such circuits in filter units, like the Maestro/Oberheim circuit, and more recent doodads like the various "robot" pedals from Sub Decay and others.
The strong-arm tactic these pedals use is that the "step-rate" is dictated by the on-board clock.  That, in itself is neither terrible or unmusical, but it IS limiting.  What if the clock rate varied with one's picking strength?  Pick/strum hard,and the filter cycles through steps more quickly.  Or better yet, what if there was a step for each note picked, as detected by an envelope-follower/trigger generator?  So, note X has one filter setting, note X+1 has another, and so on.    Or what if the sampling was dictated by a sequencer-like circuit, not unlike what Zach Vex uses for his various "Seek" effects, but instead of the little pots setting the level of an effect, they set the time a sample is held until the next step.  The noise source to be sampled remains the same, and the degree of randomness is the same, but the timing of the sampling is at the command of the player.
How does that sound to you?  I hate having ideas that intrigue the heck out of me, and exceed the time and/or skill I can bring to the fore.  But recent off-line interactions with folks I respect tells me there are clever people out there waiting for intriguing ideas.
Merry Xmas.
Title: Re: An intriguing idea for using sample & hold
Post by: EBK on December 24, 2021, 12:40:49 PM
Quote from: Mark Hammer on December 24, 2021, 12:24:05 PM
There's a thread full of such ideas looking for people.
https://www.diystompboxes.com/smfforum/index.php?topic=121960.0
Post by: mozz on December 24, 2021, 01:58:51 PM
Probably nothing about what you are thinking about, I've got some of these if anybody wants to try. Some funky waveforms might be possible. Gated op-amp could be triggered somehow by level or freq?
https://www.mouser.com/catalog/specsheets/intersil_fn2856.pdf
Post by: RickL on December 24, 2021, 04:38:54 PM
QuoteOr better yet, what if there was a step for each note picked, as detected by an envelope-follower/trigger generator?
I'm pretty sure Boscorelli released a project that did something similar to this. I think it was a panner that sent each note (or, selectably, each 2 or 4 notes) to alternate outputs. IIRC I tried to build it but didn't have much success.
Post by: Ripthorn on December 24, 2021, 04:59:15 PM
I think EQD do something in the night wire trem that changes rate with picking strength, so your idea is not to far out there.
Post by: iainpunk on December 24, 2021, 05:20:51 PM
now i want to experiment with S&H again. i did a snare drum sound once with S&H where an audio freq osc sampled a MHz range sqare wave osc for a ''random high/low'' computer 8 bit distortion, but the biggest problem was the volume, it was constant.
a similar system with a guitar signal's every positive zero-crossing triggering a sample of either white noise or that MHz osc. would probably sound like a more chaotic octave down divider.
Post by: parmalee on December 28, 2021, 04:16:08 PM
Interesting.  Not sure if I'm completely out to lunch here, but your description actually reminds me a bit of Fairfield Circuitry's Shallow Waters <<< (http://"https://fairfieldcircuitry.com/products/shallow-water") pedal.
Obviously, it takes a very different approach--using a delay (a BBD, I think), with timing controlled by pseudo-randomness (an lfsr, presumably), and a voltage controlled gate/filter--but the results might not be wholly dissimilar.
OK, I suppose the results are apt to be entirely dissimilar, but not entirely in a different ballpark (?!).  An intriguing idea all the same.
Post by: Digital Larry on December 28, 2021, 04:27:22 PM
This sort of stuff is easy to do on the FV-1. In one case I took the sampled random value, low pass filtered it to introduce a little lag, then mixed that back into the signal controlling the ramp LFO rate.  I also made a 4 "phase" sample/hold that updated one thing after the other.  You can send any value to anything - filter freq, Q, delay time, LFO rates, etc.
I'm not sure if something like that results in better music or not.   :icon_mrgreen:
Post by: Mark Hammer on December 28, 2021, 04:31:18 PM
You shame me, sir!  :icon_cry:  Man oh man, do my digital chops need to catch up.
Post by: parmalee on December 28, 2021, 04:45:24 PM
Quote from: Mark Hammer on December 28, 2021, 04:31:18 PM
Sure, but after the EMP--or, I suppose, a continuous succession of EMPs--who is going to get the last laugh?
Post by: Mark Hammer on December 28, 2021, 05:22:37 PM
If I'm not mistaken, our friend Ton "Puretube" Barmentloo.
Post by: ElectricDruid on December 28, 2021, 07:06:06 PM
Quote from: Mark Hammer on December 28, 2021, 05:22:37 PM
Don't forget Metasonix!
Post by: Mark Hammer on December 28, 2021, 09:27:41 PM
Given some of the names of their products, Tom, I think they've had their laugh already!
