DIY Stompboxes => Building your own stompbox => Topic started by: soggybag on April 14, 2022, 06:44:37 PM
Title: Cheap op-amps from Aliexpress
Post by: soggybag on April 14, 2022, 06:44:37 PM
I ordered some op-amps from Aliexpress. Here's what I bought:
- TL022
- TL62
- TL072
- OP2134
- LM308
- LM386
The tl;dr is the chips were about $0.22 each and shipping took about 2 weeks. All of the chips seems to work fine, except the LM308 for some reason. I need to think of a way to look at these more closely.
Plugging the LM308 into a Rat clone produced no sound. So these seem to not work at first test. What would be a good way give these conclusive test?
http://www.super-freq.com/cheap-parts-from-aliexpress-com/
Title: Re: Cheap op-amps from Aliexpress
Post by: Rob Strand on April 14, 2022, 07:26:03 PM
Worth checking this out,
https://www.diystompboxes.com/smfforum/index.php?topic=128924.msg1243553
Post by: antonis on April 15, 2022, 06:00:07 AM
Quote from: soggybag on April 14, 2022, 06:44:37 PM
Any DC buffer configuration..
e.g. A DC power supply of any voltage between 5v and 35V, a mid-supply (or any other point between supply rails) voltage divider connected to non-inverting input, a short between inverting input and output and a measurement on output (or on inverting input)..
Post by: Mark Hammer on April 15, 2022, 09:19:37 AM
I ordered some CA3260 chips through them, to make some Mostortions, and only one of the 5 worked.  I thought the other 4 might be remarked single op-amps, but they didn't work in that configuration either.
Post by: antonis on April 15, 2022, 09:26:58 AM
A test board for "unknown" ICs should be an interesting tool.. :icon_wink:
