DIY Stompboxes => Building your own stompbox => Topic started by: CheapPedalCollector on February 21, 2023, 04:28:17 PM
Title: DOD 690 VCO Question
Post by: CheapPedalCollector on February 21, 2023, 04:28:17 PM
I'd like to know how to calculate the operating frequency of the VCO design in the DOD 690 and other DOD pedals. I can't seem to find the circuit on the web, any of my books or datasheets.
(https://i.postimg.cc/kV2tk863/DOD690-Schematic.png) (https://postimg.cc/kV2tk863)
Title: Re: DOD 690 VCO Question
Post by: PRR on February 21, 2023, 08:07:24 PM
> how to calculate the operating frequency  ...  I can't seem to find the circuit on the web, any of my books or datasheets.
For the practical problem: I'd be lazy and just build it. It can't come out so wrong that a few cap-trials won't get it in a zone.
The new kidz @ TI have totally gerfarkled the classic datasheets. Fortunately Futurlec has the 2000 sheet archived. (https://www.futurlec.com/Datasheet/Linear/LM324N.pdf) Page 13 has this plan with minor transposition. But no theory.
Aside from added Vc filtering and raised impedance, DOD changed the hysteresis ratio. Which changes the speed but hurts my brain. I'd assume "about one time constant" each way, so 390k * 0.1uFd makes 0.039 second each way, 0.078 both ways, 12.8Hz. Which is in the ballpark. A pocket full of caps will get you where you want to go.
The R & R/2 structure looks familiar. If it is not due to Bob Pease, he cudda tole you all about it. He might say "Voltage to frequency converter" VCF.
(https://i.postimg.cc/ns2tNvhF/DOD-VCO.gif) (https://postimg.cc/ns2tNvhF)
Post by: CheapPedalCollector on February 21, 2023, 08:47:08 PM
Oh I know how the LFO works, I mean the VCO with the CD4001 and 25pf capacitor. The diode is there to change the duty cycle. That's the circuit I mean, sorry for not being clear.
The LFO changes the Vd voltage which changes the high frequency oscillator and sweeps it from about 12ms to 25ms delay, and I guess the oscillator frequency is ms*1000 according to an article by Craig Anderton in a polyphony article. I've just not been able to find this particular oscillator design, it's pretty interesting. Some of their other pedals use an opamp hooked to a 4013 to do it. I guess you can use a 4011 in the same way, which is also intereting. CMOS is cool sometimes, and it gives me some interesting ideas. I'm just curious about the math and wondering what kind of diode network can be used to change pulse width or not, and it if it will work without the diode.
Post by: Rob Strand on February 21, 2023, 09:29:57 PM
Yes, there's two parts: the LFO and the VCO.  To work out the frequency you need to know the swing of the LFO.  I'm getting about 2.3V to 11.7V at LM324 pin 7.
The LFO output is combined with a DC offset depending on the width control setting.    The DC offset at the 750 ohm resistor is about 1V.
When the width control is full you will get a swing of about 0.81V to 1.9V at the top of the 150k.  The following divider will drop that by a factor of 16 (150k & 10k?) giving a swing at the input to the VCO (LM324 pin 12) of 51mV to 119mV.
The VCO timing has two parts:  One where the cap is reset quickly through the diode and another where the current source charges the VCO cap depending on the VCO input voltage.   Small VCO input voltage => low charge current => long charge period => low VCO freq.  Similarly High VCO input voltage => high charge current => short charge period => high VCO frequency.   The charge current is I = VCO_in / 3.3k  (the LM324 pin 14 etc + 2N4124 transistor + 3k3 resistor form voltage to current converter).
When the diode is conducting, CD4001 pin 11 is high, and the time is approximately,
    t1 = R * C * ln(2)
Roughly, R = 330 ohm and C = 25pF  so t1 = 6ns.
I've also ignored gate output resistances and stray capacitance.
This is way faster than the CD4001 so would have to expect the actual time to be longer, maybe 300ns.
When the cap is charging through the current source, CD4001 pin 11 output is low:
   t2 = C*(Vdd/2 + Vd) / I            ; Vdd = 15V, Vd = 0.7V
where,
        I = VCO_in / 3.3k
When the width is full, VCO_in = 51mV to 119mV so I = 15.5uA to 36.1uA.
So with C=25pF, Vdd=15V, Vd =0.7V,  t2 = 13.2us to 5.7us.
Again we are ignoring other capacitances so we could be talking the actual t2 being 20% longer.
The idea is t1 is fairly small compared to t2 so the VCO input voltage determines the VCO period.
period T = t1 + t2 ~ 6us + 1us = 7us to ~13us + 1us = 14us.   About 2 to 1 span.
The SAD512 is 512 stages so the delay is Td  = (512/2)*Tc = 1.8ms to 3.6ms.
The SAD512D is 512 stages and also divides the clock by 2, so the delay is Td  = 2*(512/2)*Tc = 3.6ms to 7.2ms
Reality will be a little slower than that.
If you go here you can see Craig Anderton gets a 2:1 span.  I think he measured the clock but his delay calculations are way off, looks totally wrong.  Then he does a mod based on the wrong numbers.
https://www.muzines.co.uk/articles/dod-mod-ii-chorus/5290
It's also possible my numbers are wrong.  I have not simulated this circuit.  IMHO 20ms from a SAD512 is asking a bit much, so I'm going with mine.
If you plug in a square-wave input you can sometimes see the audio signal delay time on the oscilloscope.   You could also measure the clock and calculate the delay from that.
I'll let do you the case where the Width pot is on minimum.  Same idea with different VCO_in voltage.
Since that unit is using an SAD512D, not SAD512; forgot that subtlety.  IIRC that doubles the delay as it has a divide by 2 on the clock.
Can someone check?
Post by: CheapPedalCollector on February 22, 2023, 12:23:14 AM
Yes can confirm it is SAD512D, sorry I didn't know there was a distinction between the two.
So what would the frequencies be in KHz and what voltage swing to the clock input?
I was reading the 512D datasheet and it says 5V or so, which seems like quite a lot, but I'm not sure how the inverter connected nand gates output voltage.
I tried to sim, but getting part libraries for LTSpice working is way too much hassle for me, especially with such old parts.
Post by: anotherjim on February 22, 2023, 04:03:38 AM
Must admit the SAD512D is completely "new" to me. But it's only 8pin and the single-phase clock input is TTL compatible so 0-5V swing and then it must divide the clock frequency by 2 to obtain the 2 phases to operate the BBD section.
Post by: duck_arse on February 22, 2023, 08:43:55 AM
Quote from: PRR on February 21, 2023, 08:07:24 PM
https://www.ti.com/lit/an/snoa653/snoa653.pdf
page 26 of the LM3900 apps sheet has all the guff. that circuit used to be in every dual/quad datasheet.
Post by: anotherjim on February 22, 2023, 10:59:47 AM
I think this is the VCO in question...
(https://i.postimg.cc/QdTq1SHM/DOD690-BBD-VCO.png)
The clock here runs off +15v, so I suppose 5v is a minimum.
I don't know how it works apart from what looks like a variable current sink sets the timing. I suspect there are narrow pulses out as this BBD won't care about duty cycle.
Post by: ElectricDruid on February 22, 2023, 11:41:09 AM
I suspect that that VCO design is fairly variable. The logic thresholds will vary with supply, and probably between different versions of the 4001 too, so I'd expect only a fairly loose relationship between any equation and reality.
Post by: anotherjim on February 22, 2023, 04:27:57 PM
And could be a bit different again if the original used the old unbuffered CD4001A or CD4001UB devices and was cloned with the current buffered CD4001B. Some old "clever" circuits don't behave well with buffered CMOS. However, all of the gates are only used as inverters so 4/6th of a modern CD4069UB hex inverter chip could serve.
Post by: Rob Strand on February 22, 2023, 05:14:18 PM
QuoteI was reading the 512D datasheet and it says 5V or so, which seems like quite a lot, but I'm not sure how the inverter connected nand gates output voltage.
In the SAD512D datasheet it says the clock input is 5V *min* but in the datasheet text it says "or higher".  Since the chip has an internal clock generator the device is less fussy about the clock details.   Also the clock doesn't need to drive a high input capacitance like on the old SAD devices.
The clock generator divides the clock down by 2.  My initial delay estimates need to be increased by 2,
    Td =  2*1.8ms to 2*3.6ms = 3.6ms to 7.2ms.             ;I've patched the previous post with that fix.
The middle of that is 5.4ms pretty typical for a chorus pedal.  Just OK for a 512 stage BBD.  However, it still doesn't agree with Craig Anderton's article which is around 20ms.  The DOD brochure only gives a single delay time of 21ms.   Not sure what's going here.   My calculations make sense for the chip and Craig Anderton's article matches the the brochure.
The SAD512D was an 8 pin dip, smaller than the SAD512/SAD1024.   Kind of the first step at modernizing and shrinking the devices - perhaps to compete with the Panasonic devices.  After that came Reticon's R5106 (IIRC used in MXR microchorus? - maybe the microchorus was SAD512D and the later pedals were R5106) which was a better SAD512D .
QuoteI tried to sim, but getting part libraries for LTSpice working is way too much hassle for me, especially with such old parts.
Yes it can take a bit to get this stuff up and running.
QuoteSo what would the frequencies be in KHz and what voltage swing to the clock input?
I'd assume everything is running from 15V, it will work.  There's no other supply rails on the schematic, so that's a good assumption.
The frequencies at the output of the VCO are the reciprocal of the period,
        f = 1 / T
So take my estimates for the clock period  T = 7us to 14us, then  f = 71.4kHz to 143 kHz.
The hanging issue is the discrepancy in the delay times.   It could mean those clock frequencies are wrong.   I'm only seeing a clock divide by 2 in the SAD512D, not a clock divide by 4 which would double the delays again.
Quotesuspect that that VCO design is fairly variable. The logic thresholds will vary with supply, and probably between different versions of the 4001 too, so I'd expect only a fairly loose relationship between any equation and reality.
It's not too bad at 15V.   You might only see 20% variation.   As for the calculations the uncertainties of device speed, chip capacitance, the effect of the diode, gate output resistance all blur the estimates - but that's nothing to do with the performance of built units (and you can always make the calculations more complicated).
Post by: CheapPedalCollector on February 22, 2023, 09:48:22 PM
Quote from: anotherjim on February 22, 2023, 04:27:57 PM
They use CD4001BCN, so does the Flanger 670. I'm not sure what the N means, C is ceramic package yes?
The older version of it with SAD1024 seems to use a CD4013BCN as well.
Quote from: Rob Strand on February 22, 2023, 05:14:18 PM
Ok, that's good to know. I assembled the circuit on a breadboard, and it reads about 100mv on my meter, so I think my meter doesn't handle AC at that high of a frequency very well. I really need a scope badly... soon.
        f = 1 / T
Ok that makes sense, thank you.
It could just be part variation too, CTS pots are notorious for being out of spec by a large tolerance (I've seen up to 30% off), and also these thing had 0 cherry picking so I gather he designed it to be somewhere in the middle so that part tolerances would still produce a working effect even if not ideal. So Craig my have been assuming based on measurements of frequency without checking part values.
David did design things to be as cheap to produce as possible. Might explain why the MXR effects are more long lived, as they have better overall designs.
The point of all my asking is I hope to design some daughter boards for these pedals to repair them, and also to make some new ones with XVIVE/Coolaudio Panasonic reproductions. I've been collecting the different models and circuit variations for many years now, in both working and non-working order. I don't see a lot of people who want to preserve these things very much and I love them so I want to keep them all working (and working again) as long as possible. I just lacked the knowledge to do so, but I've been correcting that as much as I can.
You all rock, thank you so much.
Post by: Rob Strand on February 22, 2023, 11:16:04 PM
Usually means plastic.
QuoteOk, that's good to know. I assembled the circuit on a breadboard, and it reads about 100mv on my meter, so I think my meter doesn't handle AC at that high of a frequency very well. I really need a scope badly... soon.
Yes a generic multimeter can't be trusted over about 1kHz, 10kHz at a stretch.  Higher end DMM's might do 100kHz to 200kHz max.   I've got a very unique bench meter which goes out to about 20MHz.  It's about the size of a 4 litre ice-cream container, only does voltage, no ohms or current.   That only gives you voltage anyway what you really want is frequency.
You can go some way if your multimeter has a frequency range.   When the frequency is modulated it's not 100% reliable but you can set the Width pot to zero and measure a fixed frequency as a check.  Beyond that you can input you own fixed DC voltages into the VCO input.   Old-school "analog based" DMM's only go upto 200kHz on frequency, not quite making the full range of a BBD.    You can of course build you own frequency meter adaptor for your multimeter, even a purpose built one for this project!
QuoteIt could just be part variation too, CTS pots are notorious for being out of spec by a large tolerance (I've seen up to 30% off), and also these thing had 0 cherry picking so I gather he designed it to be somewhere in the middle so that part tolerances would still produce a working effect even if not ideal. So Craig my have been assuming based on measurements of frequency without checking part values.
I know what you are saying I've seen it too.  In this circuit it's not the pot since the frequency points are at the pot extremes and the pot's value doesn't affect things too much.   You can get some offset on the opamp used for the voltage to current converter.   At the low end the VCO input voltage is only 50mV and the opamp offset could be up to 7mV but even that's not going to double the period.
My feeling is the specs aren't correct.  I wouldn't even raise an eyebrow if that was the case!  And yes, maybe Craig went off the specs.   Without knowing the specs or seeing Craig A's article I would probably accept my calculated values - with the caveat that they could easily have 20% longer period (and delay), ie. 20% lower frequency.
QuoteThe point of all my asking is I hope to design some daughter boards for these pedals to repair
It's a good idea.  I suspect SAD512D's are going to be extremely hard to find and/or be expensive.
Something I forgot to say was we are assuming the DOD schematic is correct.  It's not unreasonable to think it's not 100% correct.    For example the thing could cause a difference is the VCO cap value.  We don't really know what value that part is.
I did a search for the schematic for the DOD 670 Flanger and found a similar circuit with different part values here and there!   The Flanger spec is 1.5ms to 15ms.  I have not redone the calculations to see how the values of that one pan out.
And lets not forget different versions of the DOD pedals!   How many versions of these pedals where there?
Post by: CheapPedalCollector on February 23, 2023, 05:19:58 AM
Quote from: Rob Strand on February 22, 2023, 11:16:04 PM
Cool, I'd be interested to do such a thing until I have the money to splurge on a scope. My meter is an old Fluke 87-III
The cap is indeed 25pf, I have one that doesn't work currently that I just got in the mail. I've had two 670's, I repaired and sold one, and the other one is a working unit. I also have a 680 delay, that the SAD4096 is toast, but I posted about that and the 670's already.
Afaik there is only 1 version of the 670, the older flanger was the 640 and used SAD1024. There are two versions each of the delay and chorus that I've seen. One delay uses SAD4096, and the other uses R5101. One chorus uses SAD512D, and the other uses SAD1024. I wouldn't doubt if there is also a 670 that uses a SAD1024, and I also wouldn't be surprised if there were versions of both the chorus and flanger that use R5106 and a 12 volt power supply.
So far I think it's quite possible to make boards for these with very minimum parts needed, and a single capacitor swap if the circuit is how you think it is. That's good news. I would think just a CD4013 and the appropriate BBD device, and doubling the clock cap, while using the VDD/VGG reversing trick they used in other devices. What do you think?
Post by: anotherjim on February 23, 2023, 09:31:57 AM
I think the 25p cap would be halved to double frequency. But the math is messed up with small caps as the stray & input capacitances become more significant. There will be at least 3pF stray and the input capacitance of 4001 is double as both gate inputs are tied together. So the 25pF circuit may actually see 30pF with 5pF being stray. If the cap changes to 12pF then it now sees 17pF instead of 15pF. A 10pF cap could actually get closer to halving the timing capacitance. These values are guesses to illustrate and reality depends on part tolerances and board layout.
Anyway, if these DODs have a signature sound, it would probably be important to make sure the linearity (or not) of the original clock VCO sweep is maintained.
If you don't want to buy a scope or other frequency measurement, you could rig up binary counters to divide the clock down to a range a DMM frequency counter can handle. An 8-bit counter dividing by 256 will render 256kHz at 1kHz.
However, you would probably want to freeze the sweep at min and max depths to give the reading a chance to resolve, otherwise, you have a moving target. This probably applies even if you have a method that can directly read the clock frequency (or pulse period).
Post by: Rob Strand on February 23, 2023, 06:05:24 PM
QuoteCool, I'd be interested to do such a thing until I have the money to splurge on a scope. My meter is an old Fluke 87-III
Those meters can measure frequency.   IIRC the frequency measurement is digital and quite accurate.   I don't know how well they work over 200kHz.
QuoteThe cap is indeed 25pf, I have one that doesn't work currently that I just got in the mail. I've had two 670's, I repaired and sold one, and the other one is a working unit. I also have a 680 delay, that the SAD4096 is toast, but I posted about that and the 670's already.
OK cool, good to know.
I redid the calculations for the DOD 670 Flanger.   As a side note the schematic I have has a whole lot of value changes marked in by hand.   Then it has additional notes talking about old units which imply the hand marked changes are not for old/new!  To the best of my abilities and after doing a lot of calculations I concluded the hand-marked changes are likely to be "more correct".   As far as the LFO design goes.  It's really hanging on by a thread.
(https://i.postimg.cc/qNxx7TYg/DOD670-Flanger-Schematic-copy-png.png) (https://postimg.cc/qNxx7TYg)
Anyway to cut a long story short:
- I started with the LFO output swing at the width pot at 1.4V to 13.5V, essentially the same range
  as the Depth control pot.
- That feeds a 470k + 33k (hand marked values) divider which then goes to a similar LFO circuit to the DOD 690 Chorus.
   That sets the range of VCO_in to 0.092V to 0.888V
- The Flanger circuit uses a 120pF cap instead of a 25pF cap.
- SAD512D delay chip
I got the follow estimates:
- clock period range 4us to 35us
- clock frequency range 28.6kHz to 250kHz
Based on the same assumptions as the chorus:
the SAD512D is 512 stages and has a divide by 2 on the clock, so
   Td = 2*(512/2) * T
That gives an estimated delay range of 2ms to 18ms.
The brochure for the Dod 670 Flanger states 1.5ms to 15ms.
Unfortunately the fact the Flanger schematic has been marked up puts some doubt on what the production units really are. And the fact old units were mentioned.    Despite that the best estimates are in close agreement with the brochure.
That being the case it makes me think the chorus calculations are OK and the calculated delays are correct.
QuoteI think the 25p cap would be halved to double frequency. But the math is messed up with small caps as the stray & input capacitances become more significant. There will be at least 3pF stray and the input capacitance of 4001 is double as both gate inputs are tied together. So the 25pF circuit may actually see 30pF with 5pF being stray. If the cap changes to 12pF then it now sees 17pF instead of 15pF. A 10pF cap could actually get closer to halving the timing capacitance. These values are guesses to illustrate and reality depends on part tolerances and board layout
In the scheme of things small errors.   You might see 20% increase in periods.  The thing is I'm estimating 3.6ms to 7.2ms and the brochure is 21ms.   The finer points can't fix that.    Moreover 21ms from a 512 stage delay is really pushing your luck.  It's going to be noisy.   We could check the filter frequencies but often they aren't technically correct on a lot of guitar pedals.
QuoteAnyway, if these DODs have a signature sound, it would probably be important to make sure the linearity (or not) of the original clock VCO sweep is maintained.
No doubt because the frequency of the VCO is proportional to the LFO waveform.
QuoteSo far I think it's quite possible to make boards for these with very minimum parts needed, and a single capacitor swap if the circuit is how you think it is. That's good news. I would think just a CD4013 and the appropriate BBD device, and doubling the clock cap, while using the VDD/VGG reversing trick they used in other devices. What do you think?
It has to be possible because there's already units out there.  I guess what you don't want to do is mess with how the VCO works as that would change the character of the unit.   In this case you don't care what the delay time or frequency is you just copy the existing ckt.
If you were to rejig the whole VCO that's going to come at a risk.   I wouldn't use any calculations to ball-park what the circuit is doing.  You would need to build one.   Then you would need to check your new circuit produced the exact clock frequencies over the whole range of VCO input voltages (at fairly fine steps).
The filter cap at the input to the VCO also has an effect and you would need to mimic that.
Post by: CheapPedalCollector on February 23, 2023, 11:13:24 PM
In the other thread for the 670 I posted a schematic that I cleaned up and verified from the one you have with both the units I had. That schematic also has an error in it at the output of the SAD512D, it does *not* connect to both +/- inputs of the opamp. It is otherwise accurate to two actual units. That schematic has part values for R5106, but doesn't say anything about changing the VREG to a 12 volt one, that would blow the chip pretty quickly I would think.
I have found the schematics for the 670 and 680 to also not be accurate, to my units at least. In fact, I found most DOD schematics are not accurate to production models and often contain fatal errors.
[/quote]
[/quote]
Oh good, that means I found the issue with both pedals as the clocks are very very low, the delay is only about 31khz. The AC reading I'm getting from them is also about 110mv so that can't be right can it? The chips are new, I'm not sure what would cause that behavior. The op amps have been tested and are fine, I tested the transistors too but I guess they may be failing under load. I really dislike having to pull parts to do this. I bought an ESR meter recommended by EEVBlog but it sucks and can't seemingly measure anything so I just use my cheap cap meter.
Yeah I would definitely have to build the circuits and do some comparisons against working units to make sure any modifications I come up with produce desired results. I have found that theory doesn't always work as expected in reality.
Post by: Rob Strand on February 24, 2023, 10:31:42 PM
Quote from: CheapPedalCollector on February 23, 2023, 11:13:24 PM
The one you posted was the R670 and it has quite a few differences to the plain vanilla 670, but also similarities.
And yes, I've got little trust in DOD schematics.
Well, the low voltage is expected.  The waveform isn't square it is a *very* narrow pulse.  It's probably like 200ns wide with a period in the order of 10us (100kHz) so the width is 1/50 th the period.  That means a very small AC voltage.
What pot settings did you get the 31khz on?
FWIW,  the very narrow pulses in this circuit can screw up frequency meters!   Yes, more complications.  Some of this stuff is a losing battle.
Cap meters vary all over the place.   The LCR types are the most reliable as they use sinewaves but some pulse types are OK provided you are only measuring a capacitor.   Most meters will not measure correctly in circuit although the LCR types can do a better job.
Note also the job of an ESR meter is to measure ESR.  Capacitance is often thrown in but the measurements aren't always trustworthy or accurate.
Theory does work but precise theory can get overly complicated.   This is where simulators like LTSpice take over.
However in this case the limiting factor is not having LTspice models for the CMOS gates.   In a circuit like this which pushes the capabilities of the chip and also depends on things like output resistance and input capacitance you need a fairly accurate model.   Such a model is difficult to construct.  It would be a project in itself to come up with a good model.
I've done a few sims with unverified models I've created myself and the results are in the ball park of the calculations.   The uncertainties like the input capacitance have a noticeable effect on the chorus but not so much effect on the flanger.  More complications are: In the circuit the gate has two inputs tied together.  Inside the CMOS chips there are protection diodes (which have capacitance) and protection resistors.   It all complicates getting the simulation right down to the small decimal points.
When you design things like this the simple theory is fine to ball-park circuit values.  You know there are uncertainties.  When you build a circuit you can make a few tweaks to compensate.   In the bad old days you could get caught out as not all brands of CMOS gates worked the same when pushed to the limit.  Typically you would either specify known brands that worked, or one day a production run would have problems and you had to make some adjustments for different brand chips.   Back in those days you couldn't buy faster chips you had to make do and squeeze the last drop out using whatever tricks or tweaks you could.
Post by: CheapPedalCollector on February 25, 2023, 07:09:11 AM
I figured out my LCR meter and now I can use it reliably, it's pretty sensitive to what frequency it's set to. It's the DE5000. I'm getting accurate values now and verified all the caps I've replaced are way out of spec and have silly dissipation factors compared to the new caps.
OK so the low AC reading is OK, that's good to know, maybe I've got this thing working now. I've been troubleshooting with the SAD512D chip out of it and also trying to understand the circuit absolutely so I don't make any wrong assumptions about it.
Looks like the best chip replacement for it would be MN3004, but that would be hard to fit into a small pedal like an MXR Micro Chorus or Micro Flanger, or the DOD 460 mini chorus. I don't think there is any 8 pin equivalents unfortunately.
I think I'll continue to learn the theory as best I can with my limited math knowledge, but always build stuff and tweak it as needed like I always have. This has been really informative and I learned a lot. I understand what's going on in most analog delay based pedals now. Of course the ones using the specific clock chips are easier to understand, but knowing these old ways are also pretty interesting. Using CMOS in analog ways is fascinating and I want to experiment and see what else can be done with it besides ring modulators, bit crushers and the MXR envelope filter.
Post by: Rob Strand on February 25, 2023, 07:02:46 PM
QuoteIt's the DE5000.
They are very good units.  I've got one myself.  I got it after I left my last job since I missed the cool LCR meters they had in the lab there.
I came across this page at one point.  You can see some of the cheaper LCR don't perform so well,
https://www.edn.com/review-continuing-the-search-for-the-ultimate-lcr-meter/
QuoteLooks like the best chip replacement for it would be MN3004, but that would be hard to fit into a small pedal like an MXR Micro Chorus or Micro Flanger, or the DOD 460 mini chorus. I don't think there is any 8 pin equivalents unfortunately.
Yes, it going to be a pain whatever way you go.
If you want to make a board that plugs into *any* pedal then it has to look like a SAD512D from outside, get the LFO/VCO from the existing board, be compatible with existing input output circuits.
Something that occurred to me was to use more modern devices but it seems they are only available in 256 stage or 1024 stage.    Probably need to operate the BBD at 5V or 9V.   You would need more circuit but the idea would be to use SMD to keep the size down.   Unfortunately the modern BBDs are still through-hole.   Two 256 stages is going to be bigger than a MN3004.   If you used a 256 stage divider the clock down by it would work but the quality wouldn't be great.  You could add more filtering but that may limit the circuit you can plug in to - and the filtering will change the sound.   Going for a 1024 and doubling the clock is going to be a headache since you would need to put in a PLL to double the clock.   Other options would be to make mods to the VCO but that going to be pedal specific and doubling the frequency is unlikely to keep the original behaviour.   All messy and intrusive options.
Post by: CheapPedalCollector on February 26, 2023, 04:23:02 AM
Quote from: Rob Strand on February 25, 2023, 07:02:46 PM
Yeah I think the SAD512D devices will just all eventually stop working and that will be that, unless someone manages to clone the chips or make something better that works the same enough to be usable. Sad state of affairs really, these units sound really good when they work.
Additionally I've found another design flaw with this and the 670 Flanger, and possibly other of their effects from this time period. They often couple the clock filter after directly, and I found that modern a opamp of the same type will not function at these tiny voltage levels that the SAD512D can output. I suppose this was a cost cutting measure as the ECG datasheet for it always has a darlington connected to the output. I think the reason these pedals fail and the MXR/EH ones tend not to, is because that opamp is drawing too much current through the SAD512D itself. Now that I look at the design, it's really kind of dumb in that regard.
This explains why the schematics floating around have that 22K load resistor crossed out and changed to 100k. All the performer series ones have it 100k too and run at 15v as well. I've done that on two pedals now and I'm getting about 2.5v on the following stage now instead of 1.2, and the circuit begins to function as it should. Unfortunately one of the BBD chips I bought got damaged by this current draw before I did that mod and now has distortion :( Maybe LM358 would be a better choice than 4558 or 4559 here? Is there another op amp that can take 15v and has a low current/voltage requirement? TL022 perhaps?
I think designing a drop in for MN3005 is not a problem for the 680, I already found some nice pin headers on mouser, the Aries 16-600-21 should do nicely with a side caddy board for the MN3005, and simple enough to design. I'm going to do that and have some prototype boards made and buy a few xvive MN3005 and see how it works. I notice the 680 also has a 22K load resistor so that might need to be changed, I need to look at the MN3005 datasheet and see what it wants.
Post by: Rob Strand on February 26, 2023, 06:06:50 AM
QuoteYeah I think the SAD512D devices will just all eventually stop working and that will be that, unless someone manages to clone the chips or make something better that works the same enough to be usable. Sad state of affairs really, these units sound really good when they work.
When the time comse some of the messy solutions may be better than having no pedal!
QuoteAdditionally I've found another design flaw with this and the 670 Flanger, and possibly other of their effects from this time period. They often couple the clock filter after directly, and I found that modern a opamp of the same type will not function at these tiny voltage levels that the SAD512D can output. I suppose this was a cost cutting measure as the ECG datasheet for it always has a darlington connected to the output. I think the reason these pedals fail and the MXR/EH ones tend not to, is because that opamp is drawing too much current through the SAD512D itself. Now that I look at the design, it's really kind of dumb in that regard.
The Flanger schematic I posted raises the resistor value to 100k for the R5106 device.  I would have to compare the datasheet for the SAD512D and the R5106 to see if a larger resistor makes sense.  What could have happened is DOD found problems like you have with 22k.  Then later on went they had to change to a R5106 they decided to use a 100k to fix the problem as part of the changes - it's hard to second guess this stuff.
My evaluation of the problem is the DOD design isn't great!  It's asking for trouble, you can't expect audio op amps to bias down at 1.2V.   There will be no opamp swing left even if it biases.
It seems the MXR microflanger also DC couples the opamp off the BBD.  They use 47k on an SAD512D.  That's going to raise the bias point to a better place.  That unit is only a 9V supply, for 15V the ideal opamp bias point would be higher.
The output load resistor on the BBD supposed to have a lot slack since the BBD outputs are JFET buffers.  However, I'm sure some resistor values work better than others.   You can use quite low value resistor loads.   Changing the load resistor affects the output level of the BBD.   The "Darlington" you see isn't a Darlington, it's a current mirror the idea is it helps combine the two outputs from the BBD.   In this case the output loads are quite low.   More the point though the output taken from the transistor collector is AC coupled to the opamps.  That means the opamp biasing doesn't have to follow the BBD biasing.  So that don't have the DC couple problem anyway.
The root cause of the problem is DC coupling the BBD to the opamp.   The BBD works fine with a low DC output bias but hardly any common audio opamps will work down that low.  If you AC couple the opamp from the BBD then it avoids the problem and lets both the BBD and opamp be biased optimally.  For the opamp that's around Vcc/2, however that means you would have to add some biasing resistors to the opamp.
So you can only make the best of a bad situation and tweak the resistor on the output of the BBD to get put the opamp bias at a better voltage.
When I did the calculations for the Flanger it was evident the LM324 opamps on the LFO and following shaper stage were getting push too much into the rails if you use the crossed-out values (on the schematic I posted).  The newly written values made a lot more sense, as if someone came in a fixed the evil, although it's still running close to the rails.
When I looked at your cleaned up schematic, I was surprised to see you re-instated all the crossed out values,
https://www.diystompboxes.com/smfforum/index.php?topic=126281.0
Is the unit really made with those crossed-out values, ie the values on you cleaned-up schematic?
Post by: CheapPedalCollector on February 26, 2023, 03:51:48 PM
Quote from: Rob Strand on February 26, 2023, 06:06:50 AM
I have a 565 Chorus and 575 Flanger and they also have 100K resistors and came with SAD512D, I don't think putting an R5106 in them is a good without lowering the voltage to 12V.
Yes they are accurate to 2 real units. When I get a schematic, I want it to be accurate, and I don't want random scribbles all over it that makes it hard to read. I can make another with the changed values, but as I said I don't think it's safe to run a R5106 at 15v, and the altered schematic is a bit misleading in that regard and could cause people to damage their working unit. It would have been better if they just added *100K or similar next to the values instead of scribbling things out.
Post by: Rob Strand on February 26, 2023, 04:56:25 PM
QuoteI have a 565 Chorus and 575 Flanger and they also have 100K resistors and came with SAD512D, I don't think putting an R5106 in them is a good without lowering the voltage to 12V.
Yes, good point.  I don't keep as many of these fine details in my head these days.   The funny thing is the example in the R5106 datasheet has the chip at 15V and the rest of the circuit at 13V, yet the chip is spec'd at 13V max.   The 15V is a mistake for sure.
Something else I noticed in the R5106 datasheet is it actually says a load resistor of less than 100k is not recommended, as the distortion increases.    Reading in between lines I suspect the SAD chips have different FETs on the outputs.
QuoteYes they are accurate to 2 real units. When I get a schematic, I want it to be accurate, and I don't want random scribbles all over it that makes it hard to read. I can make another with the changed values, but as I said I don't think it's safe to run a R5106 at 15v, and the altered schematic is a bit misleading in that regard and could cause people to damage their working unit. It would have been better if they just added *100K or similar next to the values instead of scribbling things out.
I generally try to make schematics accurate as well, or at least I write errata notes for the errors - I must have hundreds of files for schematic fixes.
Interesting your markup has the real values.   Electronically the circuit behaves quite different with those crossed out values on the schematic I posted.  I used the newly written values in my calculations - they look more correct from an electronics perspective.  The crossed out values give different VCO frequency estimates - as the LFO output is different and that affects the range of voltages at the VCO input.
To me it's totally unclear what the markups on the original schematic mean - there's no context.  They imply two versions or a fix (but by who?).  It also implies it's *not* new vs old.   Does the 100k vs 22k *only* apply to R5106 vs SAD512D?  or did someone mod the whole unit at some point and make a whole heap of changes.   *Sooo* many loose ends.    The schematic is useful for a guide but not for documenting what it is!
In the past when I'd come across stuff like this I'd trying to find many PCB pics to judge what versions were out there (no DIY clones allowed as they tend to use Web schematics).   Your real units essentially remove all the markups on the schematic.
Post by: CheapPedalCollector on February 27, 2023, 12:39:21 AM
Quote from: Rob Strand on February 26, 2023, 04:56:25 PM
Yes I became very frustrated trying to my original unit due to the inaccuracies and changes. I wasn't sure if mine had been modded or not, so I ended buying another one that needed repair because the symptoms it had were that of the caps being bad, and it was. Then I had another unit to compare to and they were identical other than I had changed that 22k resistor to 100k, which made the opamps I replaced bias up properly with a new SAD512D I purchased. I'm sure there are revisions of it, I just haven't seen one yet.
I'll go ahead and post the gut shots here too, why not. I have replaced the caps in both units, and one unit has more done to it because it came to me in a worse state, missing knobs, etc.
(https://i.postimg.cc/06vg2LhS/DOD670-1-inside.jpg) (https://postimg.cc/06vg2LhS)
(https://i.postimg.cc/HJ9qJ6Ch/DOD670-2-inside.jpg) (https://postimg.cc/HJ9qJ6Ch)
Post by: Rob Strand on February 27, 2023, 04:55:01 AM
QuoteYes I became very frustrated trying to my original unit due to the inaccuracies and changes. I wasn't sure if mine had been modded or not, so I ended buying another one that needed repair because the symptoms it had were that of the caps being bad, and it was. Then I had another unit to compare to and they were identical other than I had changed that 22k resistor to 100k, which made the opamps I replaced bias up properly with a new SAD512D I purchased. I'm sure there are revisions of it, I just haven't seen one yet.
Well well, very interesting.
I did a quick eyeball of unit/pic #1.   Your updated schematic which re-instates the crossed out values matched.
There is one more detail:
- On your schematic, the input opamp has a 2x22k, 10uF, 100k.
  However, as much as I can work out this should be:
  2x1M in place of the 22k's,  no 10uF,
  100k is not present (replace 100k with a wire so the center of the 2x1M's goes to the opamp + input)
   If you look at the schematic I posted with the crossed out values. It says old units have this exact circuit.
So what I think is going on is the crossed out values and the 2x1M etc represent the old model.
I didn't finish going over unit/pic #2 but there seems to be a good agreement with the newly marked values
So I guess that explains the mystery of the two sets of values on the schematic. Newly marked = new and crossed out = old.
Not sure if both units originally had the 22k on the output of the BBD.
That also means the two units you have are different.  One new and one old.
The pots on unit #1 are R1378034 = week 34, 1980
The pots on unit #2 are R1378127 = week 27, 1981
All starting to make more sense now.  I suspect the two units sound a little different.
There is one thing hanging.  The pre-marked up schematic has old values but 2x22k + 10uF+100k, as if there is a third version.   An old schematic cannot know about the new circuit configuration in this region!
Post by: CheapPedalCollector on February 27, 2023, 02:35:09 PM
The other unit did originally have a 22k instead of 100k on the output of the SAD512D, but the opamp would not bias with that so I changed it.
They indeed sound different, I sold the "newer" one because I liked the sound of the older one better.
Oops, thought I had pics of the circuit boards, guess I forgot to take some. The wires are fragile and I don't want to take the one I still have apart again.
Post by: Rob Strand on February 27, 2023, 03:55:38 PM
QuoteThe other unit did originally have a 22k instead of 100k on the output of the SAD512D, but the opamp would not bias with that so I changed it.
That pretty much ties up all the loose ends.  I'll do another pass of the calcs with the "old" values.
Another DOD pedal with a quirky history!  There are so many.
FWIW, the R870 circuit is more like the new version of the 670.
[For future readers the thread morphed into a Flanger discussion after Reply #20]
Errata on your updated schematic:   For the old units the 100k + 3k3 on wiper of the width pot should be 100k + 10k.
Post by: CheapPedalCollector on February 28, 2023, 12:40:25 AM
I still have the 690 torn apart, I'll take some pics of that too.
I was thinking, isn't one of the Panasonic chips 2x512? could just use half of it I guess. Would be kind of a waste, but a solution none the less.
:EDIT: Added pics
I'll take pics of the circuit board too the next time I have it out.
I did 2 changes, the 100K resistor on the output of the SAD512D, which is directly left of the socket, it was 22K stock. The other is the 22K resistor just below the trim pot which is the bias resistor for the output side of the NE571. Strangely this didn't change the bias on the circuit, and it seems a bit low to me, and perhaps the distortion is coming from the NE571 as its only about 5.81 volts with a 15 volt supply. Possibly similar to the FX90 problem I encountered.
The electrolytic caps are replaced by Nichicon 35V ones as they were all out of spec and some had very high ESR/dissipation. The 78L15 was replaced. The Coolaudio NE571 sounds better than the original to me (more treble), so I will leave it in. I will put the original LM324 back when I get some other parts I ordered as I just swapped it while troubleshooting. I socketed the 324, CD4007 and the two op amps, which I replaced with some NOS RC4559s I have as the originals (Ti 4558) were dead shorted. I also replaced the SAD socket because the ones they used are really cheap and often the flux they used (smells like honey) corrodes stuff and turns it green.
Unfortunately the SAD512D may be damaged and has quite a bit of distortion, but it sounds really nice otherwise, and it could be the NE571 making this distortion as I noted above.
I just got a new switch for it as the original was burned up, probably what killed the pedal. I still have the original cable and for once no one cut the ground prong off. I have a DC jack in there temporarily so I can power it up with 18v DC. I will be restoring the AC functionality, this is only temporary.
(https://i.postimg.cc/w7v2nCzF/DOD690-Chorus-Inside1.jpg) (https://postimg.cc/w7v2nCzF)
(https://i.postimg.cc/2brFGJTQ/DOD690-Chorus-Inside2.jpg) (https://postimg.cc/2brFGJTQ)
(https://i.postimg.cc/dLLR5GRx/DOD690-Chorus-Inside3.jpg) (https://postimg.cc/dLLR5GRx)
Post by: Rob Strand on February 28, 2023, 06:08:19 PM
First off I have some new info regarding the DOD 690 Chorus.   There are at least two versions:
- An early version, before approx mid 1980, which uses an SAD1024 BBD chip (1024 stages)
  I suspect very much this version corresponds to the 21ms delay spec in the DOD brochure.
  No schematic for this from what I can see.
- A later version, after mid 1980, which uses an SAD512D (512 stages).   That's the one you have.
(- A possible third version with an R5106.   Not sure about this ATM, hard to know if units have SAD512D subs.)
So screwed over by Dod variants again  :icon_mrgreen:
QuoteI was thinking, isn't one of the Panasonic chips 2x512? could just use half of it I guess. Would be kind of a waste, but a solution none the less.
Yes, there was a very early 16 pin device, MN3001, 2x512 stage.  There was also the SAD1024, also 2x512 stages.  AFAIK, none of these have reliable sources.
Cool.
QuoteI did 2 changes, the 100K resistor on the output of the SAD512D, which is directly left of the socket, it was 22K stock. The other is the 22K resistor just below the trim pot which is the bias resistor for the output side of the NE571. Strangely this didn't change the bias on the circuit, and it seems a bit low to me, and perhaps the distortion is coming from the NE571 as its only about 5.81 volts with a 15 volt supply. Possibly similar to the FX90 problem I encountered.
I couldn't confirm that 22k resistor was in fact the biasing resistor for the NE571 on the BBD output (expandor).   The PCB traces are hard to follow.  Are you confident that's the correct resistor?
With the FX90, the supply was 9V and the 10k resistor incorrectly biased the NE571 output to 6.6V (or whatever it was) and we increased the 10k resistor to 39k to *lower* the bias voltage.
I'm not sure if your 5.81V is before or after the resistor change.    However, the original 10k resistor looked good to me for a 15V supply.  It should bias the NE571 output to 6.6V (same as original FX-90 voltage).  If you wanted to raise that voltage a tad you could use 8.2k, however it's probably not going to give you much improvement - as the BBD is the bottle neck (maybe even the opamp bias, as discussed earlier).   Lowering the resistor will raise the bias voltage - opposite to what we did with the FX-90
If you are getting distortion the most likely place tweak is the BBD bias pot.   However, if the BBD output is clean *and* the filter output (at the opamp) is clean, then maybe there is a fault around the NE571.   You can get distortion if the cap on pin 1 of the NE571 isn't connecting or the value is too small.
Post by: CheapPedalCollector on February 28, 2023, 08:15:27 PM
Quote from: Rob Strand on February 28, 2023, 06:08:19 PM
I don't think there is an R5106 version, I have never seen those used until late Performer series in the Flanger or Chorus. There is also many circuit revisions on those, I have at least 3 different 565 boards and 2 different 575 boards. I have seen two different 585 boards so far too, one with SAD4096 and one with MN3005. The 680 has at least two versions as well, one with R5101 (the older one, which is odd) and the newer one (which I have as well) is SAD4096.
I am sure it's the correct resistor, but you're right I was tired and got it backwards. I'll try 8.2k or lower, I would think it should be around 7.5v. However it was 5.81 with either resistor which is a bit strange. I don't want to use my desoldering gun and soldering iron on the board too much, they are really cheap, but not as bad as EH boards. I'll try my decade box first and see if I can get a correct voltage out of it.
As for the electrolytics they are all new nichicons, either low esr audio grade in the signal path or 105C 5000 hour ones for power supply.
I do believe it's the SAD512D that's having problems, a shame, that was a new chip I bought, the other one was good that I put in my 670 Flanger. It's possible it just doesn't like this circuit, I don't know. I found these all to be really finicky unlike the rest of the hundreds and hundreds of pedals I've repaired over the last 35 years.
Post by: Rob Strand on March 01, 2023, 03:47:55 AM
QuoteI don't think there is an R5106 version, I have never seen those used until late Performer series in the Flanger or Chorus. There is also many circuit revisions on those, I have at least 3 different 565 boards and 2 different 575 boards. I have seen two different 585 boards so far too, one with SAD4096 and one with MN3005. The 680 has at least two versions as well, one with R5101 (the older one, which is odd) and the newer one (which I have as well) is SAD4096
I think you are right, the R5106 units I saw could be 565/575.  The available schematics for those show an SAD512, which should be an SAD512D.   If there was a change to use the R5106 it's probably in 1982, and there are 1983 units as well.
I looked through some easy to get to notes and it turns out I actually traced a DOD 565A back in 2003 - 20 years ago now, eek!   That one was 1983.  It used yet another circuit with an MN3007!  As I recall this one was called a stereo chorus.
(https://i.postimg.cc/QBkS3ypL/dod565a-v12-pngcopy.png) (https://postimg.cc/QBkS3ypL)
Oh, read the notes on the schematic.  The unit I traced was built with the filters caps swapped!
Clearly DOD are making changes by the year!
QuoteI am sure it's the correct resistor, but you're right I was tired and got it backwards. I'll try 8.2k or lower, I would think it should be around 7.5v. However it was 5.81 with either resistor which is a bit strange. I don't want to use my desoldering gun and soldering iron on the board too much, they are really cheap, but not as bad as EH boards. I'll try my decade box first and see if I can get a correct voltage out of it.
Good to know.   It's odd the voltage isn't changing, even suspicious.
QuoteI do believe it's the SAD512D that's having problems, a shame, that was a new chip I bought, the other one was good that I put in my 670 Flanger. It's possible it just doesn't like this circuit, I don't know. I found these all to be really finicky unlike the rest of the hundreds and hundreds of pedals I've repaired over the last 35 years.
It's possible the clock shaping network on the original SAD512D's was very robust, that was the idea, but some of the recent day copies might use a weaker circuit making them sensitive to the clock pulse shape.  The DOD VCO produces a *very* narrow negative clock pulse which is perhaps too narrow for the replacement chips.   Moreover the clock-pulse barely swings to 0V as the CMOS chip is being pushed.  The reason being is the new chips might handle the max clock frequency but only for square clock signals - they didn't consider that some circuit use narrow clocks, which the original SAD512D's handled.
Something you can try is to increase the 330R resistor on the VCO.   You might need to go as high as 3k3 ohm but the idea is to change it just enough to get it working then add a bit of safety margin.   Start with say 1k, if no good try 2k2 then 3k3.  If 1k works try 680R.
It would help if you could listen to the audio to confirm exactly what point (BBD, Filter, Expandor) the audio becomes distorted.
Post by: CheapPedalCollector on March 01, 2023, 07:30:26 AM
Thank you for the schematic! I would love any more you might have.
I can take pics of the other boards I have, I can't be bothered to trace them. However be warned I've cannibalized the boards for caps and chips. I bought them in a lot, and I would have rebuilt them, but the pots and knobs and harness was missing for each of the four I got cases for, and nothing came with the delay board. I really didn't feel like making new harnesses with molex connectors. So they have been added to the parts bin.
Finding errors in their schematics and production units doesn't surprise me at all. I feel they were kind of like EH and just using whomever they could get, and filling boards with whatever they had a lot of the time. I suppose I can ask Tom Cram about that, but he stopped posting on the FB group after DOD was bought by Cort. I really wish the companies didn't gate keep all this stuff and release it to the public after all these years. I used to be able to get Schematics and parts from Dunlop but not anymore. BOSS recently stopped letting dealers purchase parts too unless they are external and now require you to send stuff to authorized repair centers.
So before I changed the resistor back, and rewired the AC power switch with a the one and removed my temporary DC jack, I took some pictures of wiring and the bottom side of the board. Posting them here for posterity. I haven't finished cleaning the flux off the board yet, apologies.
(https://i.postimg.cc/B8gjj9kX/DOD690-Circuit-Board1.jpg) (https://postimg.cc/B8gjj9kX)
(https://i.postimg.cc/7bb5ZRVZ/DOD690-Circuit-Board2.jpg) (https://postimg.cc/7bb5ZRVZ)
(https://i.postimg.cc/kBbDxtLr/DOD690-Wiring.jpg) (https://postimg.cc/kBbDxtLr)
I feel adapting the circuit to MN3007 is a bit more trouble than it's worth and it wouldn't sound the same at all. The SAD512D was a unique device only needing a single clock input and having 512 stages only. If I can't get it working, I'll just buy some more chips or wait until I get another donor unit that isn't worth repairing. I'm intending to keep them for my collection, so I'm not in any real hurry.
Post by: Rob Strand on March 01, 2023, 06:24:01 PM
QuoteThank you for the schematic! I would love any more you might have.
No problem.   I honestly don't know what I have.   Finding that one was a surprise but as soon as I opened up the file I remembered doing it and some of the things that came up at the time.   I've got a large stash of stuff but I deliberately made it convenient to access so I don't mess around with it.    I've got a CD around my desk from 2010 but I know it's nowhere near half of it.
QuoteI can take pics of the other boards I have, I can't be bothered to trace them. However be warned I've cannibalized the boards for caps and chips. I bought them in a lot, and I would have rebuilt them, but the pots and knobs and harness was missing for each of the four I got cases for, and nothing came with the delay board. I really didn't feel like making new harnesses with molex connectors. So they have been added to the parts bin
My days a numbered tracing PCBs.   I might end up doing one or two a year but its more the interest in something particular that draws me in rather than me chasing after it.
QuoteFinding errors in their schematics and production units doesn't surprise me at all. I feel they were kind of like EH and just using whomever they could get, and filling boards with whatever they had a lot of the time. I suppose I can ask Tom Cram about that, but he stopped posting on the FB group after DOD was bought by Cort.
I think a lot of pedal manufacturers worked the same way.  MXR seemed to be different, the way they did things gives me the impression some those guys came out of different industries.
QuoteI really wish the companies didn't gate keep all this stuff and release it to the public after all these years. I used to be able to get Schematics and parts from Dunlop but not anymore
Yes, it's very inconvenient for repairs.  Lets face it, no matter what companies do if someone is keen enough they will trace it and even make clones of it.
QuoteBOSS recently stopped letting dealers purchase parts too unless they are external and now require you to send stuff to authorized repair centers.
Is that what's happened with Boss.  I used to think their support was great.
Yes, good to capture these things.
Something else that gets under the radar is the transformer voltages and the DC resistances of the transformer windings.   Small transformers are a headache since the regulation is poor a 12Vac transformer can measure 15Vac with no load.  Someone measures a 12Vac transformer at 15Vac then buys a 15Vac transformer and that produces 18Vac.  Then of course the internet propagates all the errors.
QuoteI feel adapting the circuit to MN3007 is a bit more trouble than it's worth and it wouldn't sound the same at all. The SAD512D was a unique device only needing a single clock input and having 512 stages only. If I can't get it working, I'll just buy some more chips or wait until I get another donor unit that isn't worth repairing. I'm intending to keep them for my collection, so I'm not in any real hurry.
At this point in time I agree, it's going to take some work.   Yes, the SAD512D was target towards making things easy and packing circuits in a small form factor.   It didn't last long since it got replaced by the R5106, which is similar and was popular for a while as well.   Boss and Ibanez tended to stay with the Panasonic devices - they had a culture to stick with the Japanese parts.
As a side point.  When I skimmed over a few random DOD schematics it looked like some of the units that converted to the MN3101/MN3007 etc era chips tried to emulate the old VCO.   No idea how close they work but you could see some intent there.
Post by: CheapPedalCollector on March 01, 2023, 10:05:41 PM
Quote from: Rob Strand on March 01, 2023, 06:24:01 PM
I've been around lurking for ages, but I had a house fire in 2011 and lost a lot of stuff. I've recovered a lot through the way back machine, but I have no idea what I don't have anymore too. I still have quite a bit and friends who have shops send me stuff on request when I need it.
You and I both, I used to trace everything when I was young, but now I mostly want to make my own things again, so I'm more learning how things work to the best of my ability. I have a good working knowledge of a lot of things, the engineers really made it easy to do a lot of things. I think more in terms of features and how I want things to sound.
I agree, MXR are my favorite effects from the old times. They clearly knew how to design and layout properly and made stuff to last, and I don't find anything they made sounding bad, breaking down very often, and they tend to be quiet too without any corner cutting. At least the best that they could at the time with the tech that was available.
Yes I am extremely disappointed at this decision by their management. It's almost as if as soon as right to repair passed here in the USA, they immediately started with the gate keeping. I've never been a fan of their products, but my friends and customers are, and I wanted to continue repairing them for them. Now when I run out of certain parts like jacks and pots, that's not going to be possible anymore as I dislike substituting.
I usually figure a transformer is rated 3-5 volts usually above the regulated voltage, unless I know the spec of a part.
I think I can adapt this chorus very easily to R5106 by just changing the vreg to a 78L12 and popping the chip in. The 100K resistor on the output should be enough. I have a limited source for those and I will do that as a last resort.
Post by: Rob Strand on March 03, 2023, 07:44:21 PM
QuoteI've been around lurking for ages, but I had a house fire in 2011 and lost a lot of stuff. I've recovered a lot through the way back machine, but I have no idea what I don't have anymore too. I still have quite a bit and friends who have shops send me stuff on request when I need it.
It's a happened to a few people here.  I really need merge all my stuff and make two copies of *everything* - I used to make three copies of everything but started losing interest.   If you ever get stuck just ask, I might remember if I have specific things.   The post 2010 to 2018 stash is very inconvenient to access ATM.
QuoteI think I can adapt this chorus very easily to R5106 by just changing the vreg to a 78L12 and popping the chip in. The 100K resistor on the output should be enough. I have a limited source for those and I will do that as a last resort.
A good back-up plan just the same.  You will have to re-bias the NE571 perhaps even the compandor (input) side as well.
Title: Re: DOD 690 VCO Question
Post by: CheapPedalCollector on March 04, 2023, 05:28:51 AM
Quote from: Rob Strand on March 03, 2023, 07:44:21 PM
Thank you Rob, you're a champion.
Indeed, and I know how now easily enough thanks to your guidance.
Post by: CheapPedalCollector on March 10, 2023, 05:50:50 AM
Follow up on this.
The new Coolaudio V571Ds sound a bit different than the Sygnetics ones, they have more top end and they also have a bit more distortion it seems. I swapped an older chip in and the distortion in the background went away. I'm not sure if this is bias related, or the chip masks aren't as good quality, or different thd caps are needed. I noticed the one I just fixed for a friend had tantalum caps in those like the FX90 delay I fixed did, I'm wondering if ESR is very sensitive here.
I also had to replace the SAD512D and it works wonderfully now. I think I may tweak the output resistor to be 51k or so, and I may mess around with getting rid of the direct coupling to the 4559s with a 1uf cap and a resistor to VDD, say 470K or so. Hopefully it won't affect the sound and will keep the SAD512D working longer as it won't be supplying any current to the 4559. I can say that my RC4559s will bias up with just 2.4v, while any other modern 4558 or 4559 will not, which is also interesting.
I also noticed if you remove the SAD512D to test voltages it might be a bad idea, as the following opamp stage then has a few mv on the + input and a full 15 volts on the - input and output. I don't think that's good for the chip, and I remember reading something from RG Keen about that.
I may make similar mod to my 670 Flanger and 680 Delay once I get a working SAD4096 for that.
This dive also helped me fix a friends 690 Chorus in just a matter of a couple hours, so it was worth it.
Post by: Rob Strand on March 11, 2023, 04:47:28 AM
QuoteFollow up on this.
Good work!
I'll have to check the RC4559 datasheets to see if there's a reason the thing won't bias.   The output stage should be able to swing down to 2.4V, even if the swing is poor.  So I don't think it is that.  I'm suspicious it's got something do with the common mode range of the inputs.
