DIY Stompboxes => Building your own stompbox => Topic started by: computerjones on November 20, 2003, 07:27:42 PM
Title: metal can transistor ID help
Post by: computerjones on November 20, 2003, 07:27:42 PM
i have a bunch of transistors here that i need some info on.
TI
9275-1
7203
M (motorola)
8107-1
511
F (or P, not sure of company)
2445P1  317
the full part number on the invoice enclosed is:  43A162445P1
the first 2 are a larger metal can, and the last one is a smaller metal can.
thanks for any help
Post by: computerjones on November 21, 2003, 05:50:24 PM
please help!
Title: Re: metal can transistor ID help
Post by: kinetiq on November 22, 2003, 03:32:27 AM
This info is from NTE's QUICKCross Software
Industry Number  : 72031
NTE Device Number: NTE130
T-NPN,SI-AF POWER OUTPUT,,TO-3
Data Sheet: http://www.nteinc.com/specs/100to199/pdf/nte130.pdf
Industry Number  : 511-1
NTE Device Number: NTE47
T-NPN,SI LO NOISE AMP,TO-92
Data Sheet: http://www.nteinc.com/specs/10to99/pdf/nte47.pdf
Industry Number  : 43A162445P1
NTE Device Number: NTE199
T-NPN,SI-LO NOISE,TO-92
Data Sheet: http://www.nteinc.com/specs/100to199/pdf/nte199.pdf
The data sheets are for NTE's equivalent to the original mfr's product. Hope this helps.
Edit: That's just general info for the first 2 transistors. I could probably pull up more specific info if you needed it.
