DIY Stompboxes => Building your own stompbox => Topic started by: WGTP on November 24, 2003, 09:54:39 AM
Title: Fet Diodes
Post by: WGTP on November 24, 2003, 09:54:39 AM
I measured a J201 and 2N7000 as diodes and they were slightly higher than std. silicons.   Would they have a slightly higher clipping threshold?
Title: Fet Diodes
Post by: will on November 25, 2003, 02:33:05 AM
Hi WGThickPresence,
Yes they should. However, whether they sound better or not is subjective. If you want to raise the clipping threshold you can always double up the diodes.
Give it a try! I find in some circuits I have tried all sorts of combinations before I was happy with the circuit.  It really depends a lot on the circuit. In some circuits, like the muff fuzz, I have found the 1N60 Ge diodes caused a gating effect that I need to include a cap to eliminate. Where the si or led's worked better for me with out the cap.
Regards,
Will
Title: Fet Diodes
Post by: aron on November 25, 2003, 02:46:39 AM
Put the J201 etc... in a feedback loop like the Tube screamer type circuit. Tell me what you think.
