can i use a 2n3904 instead of a 2n5089 in the following schematic??? thanks
http://www.commonsound.com/phaseur/phaseurscheme.pdf
Well, you could, just so long as you had the pinout correct. They might have a bit of a different sound, but they ARE both NPN.
-Colin
The pinout is the same, but the 2N5089 has a higher current gain (Hfe) and is low-noise.
I'm pretty sure a 2N3904 will work here. You can replace it with a 2N5089 later. Small Bear (http://www.smallbearelec.com) has them.
Good luck,
Joep
