DIY Stompboxes => Building your own stompbox => Topic started by: nast2112 on January 01, 2004, 02:28:00 PM
Title: Adding A Level/Mix Adjustment To A Boss BF2 Flanger
Post by: nast2112 on January 01, 2004, 02:28:00 PM
I really love the flange sounds of the BOss BF2 flanger, however, it gives a volume boost when activated that I do not care for.  I'm looking to possibly add some sort of level adjustment to it.  Suggestions?
Chris
Post by: smoguzbenjamin on January 01, 2004, 02:30:55 PM
Take the output of the effect & add a trimpot to wire as a volume pot. Simple enough...
I have a BF-2 but I'm too scared of damaging it. And I'm not that bothered by the volume boost :)
Post by: nast2112 on January 01, 2004, 03:01:07 PM
Quote from: smoguzbenjaminTake the output of the effect & add a trimpot to wire as a volume pot. Simple enough...quote]
What size pot would you recommend? 100K?
Thanks again
Chris
Post by: smoguzbenjamin on January 01, 2004, 04:02:07 PM
Mmmm I guess a 100k log would do just fine. :) I use whatever pot I can find (I have loads lying around) but I like 100k the best. Don't know why, it just feels better :)
But yeah go and get yourself a 100k log trimpot. If they don't have log that's not a problem just get a linear one, but logarithmic pots usually feel better, there's an article about that on www.geofex.com
But anyway, going to watch a movie now :)
Title: Re: Adding A Level/Mix Adjustment To A Boss BF2 Flanger
Post by: flintstoned on May 28, 2010, 07:45:09 PM
hey, just reviving an old thread, trying to do the same. would a trimpot on the output work? first i tried to put in trimpots at r32 then r33 but that affected the buffered signal too, then i found this thread and was wondering if this would affect the buffered signal the same way. can anyone see a better way?
(http://www.schematicheaven.com/effects/boss_bf2_flanger.pdf) (http://(http://www.schematicheaven.com/effects/boss_bf2_flanger.pdf))
Post by: flintstoned on May 30, 2010, 10:09:42 AM
For any future searchers r29 is the one you wanna replace. I used a trimpot so I don't have the exact value to swap for but that's really a taste preference anyways.
