DIY Stompboxes => Building your own stompbox => Topic started by: 549 on January 04, 2004, 08:49:07 AM
Title: Need:change AC to DC diagram
Post by: 549 on January 04, 2004, 08:49:07 AM
I will set 2 tranformers inside effect box.
but tranformers are AC , I must change to DC
anyone  have diagram circuit??? :?
or link site
thank you :wink:
Post by: Mike Burgundy on January 04, 2004, 09:26:23 AM
If you don't know what you're doing don't mess with AC. it's deadly if not done properly (think about waht would happen if your strings were hooked up to a wall socket). Transformers need to be well isolated electrically (safety), and need to be positioned in such a way that they don't interfere with each other and any other circuit nearby (they have a rather powerful magnetic field that hums at 50-60Hz, and you *will* hear this through audio circuits). A good fuse at a correct value and other protection arrangements are due here. Oh, and they can get hot.
That said, what you need is a rectifier and filter section maybe even with a regulator. The exact circuit used depends largly on transformers used, required voltage, current drawn, filtering requirements, the circuit you're feeding, etc.
Post by: 549 on January 04, 2004, 09:32:57 AM
Hmm.....thank you
It's a new knowleage to me. :lol:
Post by: smoguzbenjamin on January 04, 2004, 11:37:38 AM
After almost killing myself when I shorted a PSU once, my advice would be not to mess with AC unless you're an experienced builder. Buy a wallwart with different voltage outputs, that'll supply all your DC needs.
