DIY Stompboxes => Building your own stompbox => Topic started by: jlove0413 on January 05, 2004, 11:04:30 AM
Title: Silly newbie question?
Post by: jlove0413 on January 05, 2004, 11:04:30 AM
I see the phrase "gating effect" referred to  in many of the posts.  Can someone explain what this is?
Thanks.
Title: Gating
Post by: petemoore on January 05, 2004, 11:13:54 AM
SOunds like a nasty taper off of amplified signal when you're note decays.
 A misbiased Q will gate or shut off sporadically causing a [not exactly a scritch or crackle but] noisey decay or let only transient sputters through.
  Take yer basic transistor ckt and put a trimpot to replace the  collectors resistor , twist the trimpot...if it's adjusted value gets 'outside'  the bias parameter you will hear the gating efkt.
Post by: jlove0413 on January 05, 2004, 11:34:12 AM
Thanks for the explanation!
Post by: smoguzbenjamin on January 05, 2004, 12:21:21 PM
Spluttery noisy mess. ;)
