DIY Stompboxes => Building your own stompbox => Topic started by: troubledtom on January 19, 2004, 01:38:36 PM
Title: i need a real big enclosure
Post by: troubledtom on January 19, 2004, 01:38:36 PM
........ its got to be strong/stompable. i'd like it to be 14in by 4or5 in and 2in high. just to give you an idea. it " could " be just about any size, but BIG.
          thanx,
              - tom :idea:
Post by: smoguzbenjamin on January 19, 2004, 01:39:11 PM
Hammond 1590 DD?
Post by: ExpAnonColin on January 19, 2004, 01:51:42 PM
You could always get it custom made (about $50).
-Colin
Post by: ExpAnonColin on January 19, 2004, 02:02:03 PM
Try Mouser part numbers 546-1411ZU (17x5x4) and 546-1411XU (12x7x4).  Also, 546-1444-18 (17x4x3).
-Colin
Post by: R.G. on January 19, 2004, 03:08:31 PM
Quote........ its got to be strong/stompable. i'd like it to be 14in by 4or5 in and 2in high. just to give you an idea. it " could " be just about any size, but BIG.
... have you read the article at GEO about the larger size Steel Stud enclosure? I think it's pretty much exactly what you're looking for, given that you're willing to fabricate a bottom and side covers.
A real primo look for these is to make hardwood end covers and a flat sheet metal bottom cover. Pretty easy, even with minimal tools.
They're mild steel, so all auto body painting supplies work great on them.
Post by: troubledtom on January 19, 2004, 03:35:08 PM
Quote from: anonymousexperimentalistTry Mouser part numbers 546-1411ZU (17x5x4) and 546-1411XU (12x7x4).  Also, 546-1444-18 (17x4x3).
-Colin
thanx colin,
       but those enclosures are not stompable, great for table top units though.
           - tom
Post by: mikeb on January 19, 2004, 04:35:48 PM
Hey Tom - wassup? I emailed you a couple of days ago.
Hammond diecast boxes don't come any wider than about 10.5" (and that is with a height of 2.75"!). Suggestions:
- use a smaller stompable box, connected to a remote box that has all the controls, ins and outs etc. You can use relays for switching stuff to avoid passing the audio through the cable.
- the Hammond sloping face series
14" wide x 1.5" high (front)/3" high (rear) x 8.3" deep -> 1456PH1WHBU (white top, blue case) or 1456PH1BKBU (black top, blue case) or 1456PH1WHCWW (white top, walnut case) .... these are 10 degree slopes
There are more options for the Hammonds in 15 and 30 degree slopes too.
This Hammond catalog makes for fun bedtime reading! :twisted:
MikeB
Post by: Zero the hero on January 19, 2004, 05:48:23 PM
Man, I hope that this is big enough.
There's enough space for everything, included stomps, jacks and pots.
https://www.forwardair.com/prepaid/container_Pictures.htm
Post by: dan on January 19, 2004, 06:00:40 PM
^^plus a motorcycle
Post by: dan on January 19, 2004, 06:22:03 PM
p.s. will this (http://www.mouser.com/index.cfm?&handler=search.listcategory&Ntt=*546-1411WU*&Dk=1&terms=546-1411WU&D=546-1411WU&N=0&crc=true) work for whatever your making? it's figure c in the catalog. this would be what i would get. btw, what are you making? i'm guessing...big loop box or remote bypass switch box thingy mijiger?
Post by: Dan N on January 19, 2004, 07:00:02 PM
It's been a while, but Ted Weber of webervst.com was threatening to produce a big enclosure for multiple foot switches. I don't know if he ever made any.
You might email him. Could be that if he does not have that enclosure, there may be some kind of unpunched amp chassis that might suit your needs.
Good luck!
Post by: Paul Perry (Frostwave) on January 19, 2004, 07:02:32 PM
This may sound crazy, but depending what you are building, it might be worth  bolting a number of boxes together. You certainy get a very robust result.
Post by: afranks on January 19, 2004, 07:48:18 PM
Check out Rose Bopla for about the best extruded enclosures
I've ever seen.  The extrusion stock comes in 1 meter lengths,
so you have to order at minimum enough to make up a meter
of stock.  The extrusions are from their build-a-box product line.
You buy the extrusion and end panels seperately, and the end
panels screw into the extrusion.  They're available with a nice
textured powder coat finish.  They are not cheap, but they're
commercial quality.  We're using their build-a-box line for a
product we're developing where I work (automotive diagnostic
equipment).  Definitely stomp worthy.
http://www.rose-bopla.com/
-alan
Post by: troubledtom on January 19, 2004, 09:14:11 PM
Quote from: mikebHey Tom - wassup? I emailed you a couple of days ago.
MikeB
tv email is down . i'm useing the wifes computer at this time.
     peace to my brother mike both 8)
                      -tom :twisted:
Post by: RDV on January 19, 2004, 09:24:56 PM
Quote from: Zero the heroMan, I hope that this is big enough.
Imagine the knobs Tom would mount on that sucker, might even have room for a stompswitch!  :P
Regards
RDV
Post by: troubledtom on January 19, 2004, 09:48:19 PM
Quote from: Paul Perry (Frostwave)This may sound crazy, but depending what you are building, it might be worth  bolting a number of boxes together. You certainy get a very robust result.
the mighty FROSTY  8)
         that was my other idea, i figured how many cazy cool sob's will want this device.
   so , i'm leaning more towards that idea , i'm going to a custum shop in a day or 2.
     also, id like to thank all for their input.  please fell free to give me some other options !!!!!!!
         the encloser will likley be bigger than i thought. so i'm gonna try
getting a custom box that i can combine together.
   9 by 5 , 1 3/4 high times 2  :twisted:
                    - tom
Title: Re: i need a real big enclosure
Post by: Ansil on January 19, 2004, 10:45:00 PM
Quote from: troubledtom........ its got to be strong/stompable. i'd like it to be 14in by 4or5 in and 2in high. just to give you an idea. it " could " be just about any size, but BIG.
          thanx,
              - tom :idea:
contact donald stringer..  he may be able to help you. he works with metal and ahs helped me in the past wiht some kicining boxes
Post by: hair force one on January 20, 2004, 02:55:40 AM
i can make you one of that particular kind,  y:Pp
See an exemple of what i'm making in the "tinker time!" thread.
Cheers
Post by: troubledtom on January 20, 2004, 07:13:15 PM
Quote from: hair force onei can make you one of that particular kind,  y:Pp
Cheers
thank you soooooooooooooooooooooooo much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i think shipping would be $$$$$$$$.
    but you truly have a talent and i'd love to see it happen. i did follow your tread and it puts a smile on my face every time i see one of your enclosures.
      we need to talk/email for sure.
              peace,
                  - tom pollock
www.troubledvariance.com
Post by: jsleep on January 21, 2004, 05:54:42 AM
Tom,
Small Bear's got the best bang for the buck that I've found.  Almost as big as a "D" for half the price.
JD
Post by: Paul Perry (Frostwave) on January 21, 2004, 08:46:27 AM
A problem wiht "large area" boxes is that no matter how solid, if the face is large enough it will sag when you stomp. So you mighinternal supports, possibly made from standoffs.
I notice it is fashionable at the moment to have stainless steel kitchen fittings, a lot of this is just wood with thin sheet over it. Who knows, stainless is impossible to work with, but brass sheet solders like a dream, maybe there is some way to do something that way.
Post by: troubledtom on January 21, 2004, 10:17:08 AM
jd,
   thanx for the info, but i really need a big box, i'm already using the biggest size steve offers , i beleive. i need a box i can get 9 or 10 stomps on.
crazy , yep, but that's my market ' people that want 10 times more then you can get from any guitar shop'. the first two are going into frying pans
sorry, joe g.  :wink:
   peace,
      - troubledtom
Post by: RDV on January 21, 2004, 11:09:53 AM
I've long been toying with the idea of putting all my fave DIY boxes in one unit. The encloure has been the stopping point. If we come up with one I'll definitely buy one also. It's much preferrable for me to have one big stompbox with everything I need in it Vs. a pedalboard. If I were going to go into the business, that's what I'd do. Analog multi-effects. Sigh.
Regards
RDV
