DIY Stompboxes => Building your own stompbox => Topic started by: Hungeryhippie on February 04, 2004, 05:17:37 AM
Title: RM AXIS FUZZ
Post by: Hungeryhippie on February 04, 2004, 05:17:37 AM
Hello, I have been looking at the RM Axis fuzz, and last night I bread boarded it up. I didn't manage to try it out through my amp, though, only played it through my little gem type thing. I didn't really seam to get much fuzz, some crunchy overdrive yes and it did sound good on chords but with the drive control maxed I didn’t seam to get floods of fuzz like I was expecting.
I have noted the voltages for Q1 (2N3906) Q2 (2N3904).
Q1, E B C =  4.5 3.6 3.9
Q2, E B C =  3.5 3.9 6.5
battery = 9.15v
How does this compare to any one else's?
does the emittor of the 2N3906 go to the 220ohm resistor or to the base of the 2n3904?
Hopefully I'll get to check it more tonight.
Peace.
Title: RM AXIS FUZZ
Post by: Boofhead on February 04, 2004, 06:01:39 AM
I don't have one built up but....
According to simulation I gett for battery = 9.2V
Q1  E= 4.4V, B=3.8V,  C=3.2V
Q2  E= 2.6V, B=3.2V,  C=6.0V
Your measurements look off enough that something could be wrong.
Somethings don't seem to add-up:
- Your Q2 E voltage implies  Q1 B should be 3.9V
- Your Q2 B voltage implies Q2 E should be 3.3V.
- Your Q2 B + Q1 E voltages imply Q2 C should be 6.3V
- Your Q2 E voltage implies Q2 C should be 6.3V
Perhaps your meter is analog?
Quote2N3906 go to the 220ohm resistor
Yes.
Title: RM AXIS FUZZ
Post by: brian wenz on February 04, 2004, 12:03:59 PM
Hello Hello Hungeryhippie--
  Here are the readings from a real Mayer Axis:
    2N3906
  E-- 4.34
  B--3.64
  C--3.20
     2N3904
  E--2.68
  B--3.25
  C--5.86
  Here are the readings from my D.I.Y  build--
     2N3906
   E--4.21
   B--3.52
   C--3.04
     2N3904
   E--2.47
   B--3.04
   C--5.68
 The 220 ohm DOES go to the emitter of  the 2N3906.
Brian.
Title: RM AXIS FUZZ
Post by: Hungeryhippie on February 05, 2004, 04:31:11 AM
Thank you to both of you, Thats been a great help.
I managed to get  quick look at it last night and i discovered the 39K was in fact 90K! not sure how that happened one of those things, but some thing else is still up i now have,
2N3906
E--4.42
B--3.07
C--3.02
2N3904
E--2.5
B--3.02
C--5.52
It sounded better but i think it needs another look those BC on Q1 look wrong still.
am i right i thinking that a transisor has 0.6v dropped across its B E when its turned on? Which would mean the bias is wrong somewhere.
I'll keep you posted as to what happens next.
Title: RM AXIS FUZZ
Post by: Boofhead on February 05, 2004, 06:26:37 AM
Quoteam i right i thinking that a transisor has 0.6v dropped across its B E when its turned on? Which would mean the bias is wrong somewhere.
Yes on both accounts.
The base emitter voltage of Q2 is low.  To me it looks like the DC feedback is trying to pull the base of Q2 up but it runs out of range and cause Q1 to saturate - that's why Q1's B and C voltages are close.
Maybe look at the biasing resistors on Q1: 180k, 820k, 680k.
Title: RM AXIS FUZZ
Post by: Doug H on February 05, 2004, 08:30:43 AM
According to my SPICE model, your Q1 base voltage is too low. In the model it is around 3.73V. The rest of your voltages look pretty close to the model. Check the 180k, 820k, 680k bias string that is setting your base bias of Q1 and see if there is an error there.
Doug
Title: RM AXIS FUZZ
Post by: brian wenz on February 05, 2004, 10:23:59 AM
Hello  Hello  HH--
    What type of trannys are you using??   [Fairchilds......etc..]
I know I've had to tweak the bias a lot  on some circuits 'cuz the trannys were not the same brand as the original  [the Mayer Axis was one of 'em!]
According to the specs on the original Mayer pedal every reading came out a little "low" for my diy build and had to be adjusted.  Actually, your're not TOO far off so it should be pretty easy to bring it up to spec.
Brian.
Title: RM AXIS FUZZ
Post by: RDV on February 05, 2004, 10:43:26 AM
Does anyone know if a 2N4401 & 2N4403 will work in this circuit?
Regards
RDV
Title: RM AXIS FUZZ
Post by: brian wenz on February 05, 2004, 11:18:36 AM
Hello Hello RDV--
    No, haven't tried those.......seems like this would be a good circuit for putting sockets in!   I built an Axis with a BS170 in Q2 and it sounds good, so there must be a bunch of different trannys that would work as well.
Brian.
Title: RM AXIS FUZZ
Post by: dev on February 06, 2004, 02:45:14 AM
Hi all,
When working properly on a clean amp does this fuzz have a stong octave with the volume on the guitar at 10.   Then slight octave from 5 to 8, and gets clean aroung 2and 3?  Is there a way to minimize the octave effect and maintain the sustain?  Also, how do you like to set the fuzz and volume controls on the pedal?
thanks Dev
Title: RM AXIS FUZZ
Post by: Hungeryhippie on February 06, 2004, 06:14:36 AM
Ok well here's what I got so far.
The transistors I have the 2N3906 has a T2 printed on it, is this the manufacturer? And the 2N3904 is a new one I don’t know the manufacturer.
I have tried adjusting the bias for Q1, the 180K,820K, and 680K resistors, I used a 1M pot and tweaked it and watched the E and B voltages go up and down, and then I tried a combination of two 1M pots one in the 680K and the other in the 820K position. But I still haven’t been able to get the Q1 base voltage up with out the emitter being way to low (2.4v) or to close to the base voltage. Very frustrating.
How ever,
The 10K after the 180K, I replaced this with a pot, and with it shorted (no resistance) the voltages I got back were.
Q1,
E--3.21
B--3.6
C--5.1
Q2
E--2.7
B--3.21
C--6.7
However ( there is always something else isn’t there) I get no sound out of it, nuffin. Then turning the pot back again, it bursts into life!?!?
still its friday, I can spend a bit more time on it at the weekend. Thank you for your help so far,
Title: RM AXIS FUZZ
Post by: Boofhead on February 06, 2004, 06:52:22 AM
QuoteHowever ( there is always something else isn’t there) I get no sound out of it, nuffin. Then turning the pot back again, it bursts into life!?!?
That would be normal the output is tapped off the 10k/22k junction and shorting the 10k kills the output signal completely.
At this point I  recommend you change Q1 I think there's something wrong there.  I looked at a few scenarios and could not find one which had a VBE~0.4V on Q1.  If you have *any* other pnp silicons throw one in as a sanity check.
Title: RM AXIS FUZZ
Post by: Hungeryhippie on February 06, 2004, 07:28:46 AM
i did try different transistors in Q1, all 2n3906's, but all the same results,
the one thing i forgot to mention is, its also hard to concentrate with my other half going "blar blar blar Fuzz pedals is all you ever do blar blar blar" its even called Fuzz Pedaling, in my house (flat) now no matter what type of effect it is, I showed her the Dr Q and demonstrated it, "is that a new fuzz pedal!" hmmm. Well she is Norwegian.
Peace to you all cos i know i aint the only one who gets an earfull.
Title: RM AXIS FUZZ
Post by: Doug H on February 06, 2004, 08:44:16 AM
Quote from: devHi all,
thanks Dev
Yeah, part of the whole deal is the strong 2nd harmonic which gives it an "almost octavia" sound when everything is dimed. Earlier I tried biasing it differently and etc with no luck. But now I realize that sound is all part of the fun. I've got this on the breadboard right now and when I experiment with it I rarely turn the guitar vol up to 10. I turn it up for octave feedback, swells, and other noise for emphasis, but keep it down around 5-7 for a good lead tone most of the time, down around 1-2 for cleanish overdrive rhythm sounds.
Also, this is not a good effect for a clean amp. Like most fuzzes, it sounds much better through a tube amp that is a little dirty. Then you get the synergistic effect of the fuzz and amp sound which combines into an awesome tone.
Doug
Title: RM AXIS FUZZ
Post by: Doug H on February 06, 2004, 08:46:34 AM
Quote from: brian wenzHello Hello RDV--
Brian.
I agree. Experiment away with different transistors. :D  I used a metal-can 2n2222 for Q2 on the breadboard and that sounds really nice.
Doug
Title: RM AXIS FUZZ
Post by: brian wenz on February 06, 2004, 11:35:44 AM
Hello Hello Doug--
 Thanks for the heads-up on the 2222....gonna have to find some of those!
I think the reason alot of people DON'T like this pedal is 'cuz they try to play it through a clean amp.  This thing was made to match up with a Marshall!
Brian.
Title: RM AXIS FUZZ
Post by: Doug H on February 06, 2004, 12:42:35 PM
Quote from: brian wenzHello Hello Doug--
Brian.
Sounds great with my Firefly too (which is sort of like a micro-marshall :D ). It really does.
Also, I think people don't like it (and I didn't use to) because it's not the kind of thing where you just turn everything up to eleven and leave it there. You have to hang onto your volume control and season to taste IMO.
Doug
Title: RM AXIS FUZZ
Post by: nightingale on February 06, 2004, 01:06:36 PM
QuoteAlso, I think people don't like it (and I didn't use to) because it's not the kind of thing where you just turn everything up to eleven and leave it there. You have to hang onto your volume control and season to taste IMO.
Doug
sounds like my kinda fuzz~
especially because there really is anot ny clean on my blues deville i've been enjoying again lately... it breaks up super early... in a good way tho..
i am just geting together a BOM to breadboard this guy...
thanks doug
and brian~
i notive we have similiar tastee  as far as fuzz's, and guitars go... but i'm not a big marshall guy.. what kind of marshall do you play mostly?
maybe i'll have to give marshall another look.. the only snag is that i like to play smaller combo amps through house PA's... i lugged around twin reverbs for ever.. i'm kinda burnt on the 77lb amplifier.. are there any old jcm8 combos or anything worth looking at..
Title: RM AXIS FUZZ
Post by: brian wenz on February 06, 2004, 04:43:39 PM
Hello Hello Ryan--
     I only use Marshalls  [early 70's 50-watters]  every-now-and-then for big gigs.  I mostly use 30-watt, class  'A' , 4-EL84 Vox type amps  [with 1-12"  or 2-12" speakers] for club gigs .   The EL-84's  give me a good "grind" at lower volumes  [I don't miss the Marshalls as much!]
A Vox or Vox-style amp sounds GREAT with most of the fuzz and overdrive circuits we like!   I've always had trouble using English-designed circuits with Fender amps.
The Axis circuit works really well with a class 'A' amp.......there's lottsa variations to be had with those two knobs!
I switch guitars around from Fender Esquier to Les Paul Jr. to Fender Strat. to Hamer Sunburst Archtop [solid body] to Gibson Flying V....lotsa different sounds!
Brian.
Title: RM AXIS FUZZ
Post by: Hungeryhippie on February 09, 2004, 05:10:27 AM
Am now very happy  :D
I spent more time working on it this weekend and now i have it.
Everything that has been said on this pedal is true, turn it up and control it with the volume control on the guitar, its so good.
I ended up with a 470K where the 680K was and the 100k on the base of Q2 is now 180K. Voltages are Q1 e-5.2 b-3.7 c-3.24; Q2 e-3.75 b-3.23 c-6.15.
Thank you for your help and assistance with this project.
Title: Huge Amp Tone...
Post by: petemoore on February 09, 2004, 09:13:22 AM
I'm believing that one doesn't really need a 100w amp to have Huge amp tone.
 Make no mistake, a teeny amp won't 'shake' your strings and wood for you like a 100w [just going to say Plexi...to me the industry 'standard' by which amps are judged//[Hey J.M.]...causeing the hamonic feedback loop they're so famous for...but as far as tube/speaker loading, freqiemcy resposne,.. and overdrive characteristics...anything from 2000+watts to <.2 watts can get that...[.2watts is probably an overstatement, kinda hard to find the 'right' speaker for amp loading at that level].
 the Moral' is: a overdriven or not overdriven 'tube influencied tone' can be attained with a very small tube amp and speaker.
Title: RM AXIS FUZZ
Post by: brian wenz on February 09, 2004, 06:00:00 PM
    GOOD ONE!!    Looks like it was just a matter of biasing to the brand of tranny......
Brian.            [p.s.--what amp are you playing through??]
Title: RM AXIS FUZZ
Post by: brett on February 09, 2004, 07:10:07 PM
Thanks to everyone who contributed to this thread.  I'm building an RM Axis fuzz tomorrow (skipping off work AGAIN), and this thread has alerted me to many things, including the need to watch the biasing in this circuit.
On the topic of over-driven amps and wattage, I use an old MusicMan 65(kinda like a Twin Reverb).  It has a "Lo" and "Hi" power switch.  On "Lo" it runs at half voltage (= 1/4 wattage).  To be able to max out at 16 watts is great.  99% of the time I use the low power setting.  Turned up loud it still leaves a slight ringing in my ears afterwards.   :twisted:  I don't know how you guys with 100W of tube power and 4x12s manage to get heavily overdriven in a household setting without bleeding from the ears. :shock:
Title: RM AXIS FUZZ
Post by: Doug H on February 09, 2004, 07:19:18 PM
Quote from: brettThanks to everyone who contributed to this thread.  I'm building an RM Axis fuzz tomorrow (skipping off work AGAIN), and this thread has alerted me to many things, including the need to watch the biasing in this circuit.
I suspect they use attenuators and/or earplugs. I hope so anyway... :D
(I don't think it's a household situation either. :D )  But IMO you don't necessarily need a lot of wattage. I think it takes a tube amp that is breaking up on its own a little, IMO.
Doug
Title: RM AXIS FUZZ
Post by: brian wenz on February 09, 2004, 08:07:34 PM
Hello Hello--
  Houshold....???   What's that?!
Brian.
Title: RM AXIS FUZZ
Post by: aron on February 09, 2004, 08:22:09 PM
Quote from: Hungeryhippiei did try different transistors in Q1, all 2n3906's, but all the same results,
That is funnY! I hope it's funny to you.  :)
Title: Smaller Amp..
Post by: petemoore on February 09, 2004, 08:50:36 PM
I use the smallest Tube job I have, The RCA Victor.
 Sounds exactly like my Marshall [NOT}
 But I have been tuning with these two for long enough I know when it's sounding good on either amp, and can compensate for the EQ and Gain differences from experience now...moslty the Big amp has more gain and highs, but tuning them is a snap once I'm in the ballpark.
 I feel certain the earful I have gotten would have been greater in volume if I was doing mostall my tuning on the 50 watter.
Title: RM AXIS FUZZ
Post by: Hungeryhippie on February 10, 2004, 04:40:25 AM
this is my amp and axe for Brian cos he asked
http://www.geocities.com/hungeryhippie/Hungerhippiekit.html
aron, Yes it is funny, so funny i had to share it  :D but i have brought her a big bunch of flowers now and she couldnt be happyier
brett
good luck with your axis, i wish i was home
Peace
Title: RM AXIS FUZZ
Post by: brian wenz on February 11, 2004, 02:24:42 AM
Hello Hello HH--
Yeah , I remember that you posted a pic of your amp before......sorry for my bad memory!
Brian.
Title: RM AXIS FUZZ
Post by: Doug H on February 11, 2004, 08:55:50 AM
I went ahead and built the axis the other night. I had a pre-drilled box that was left over from something else and it took me about 3-1/2 hours. (Still have to paint it and install an LED but it is basically finished.) I used a fairchild 2n3906 for Q1, motorola metal-can 2n2222 for Q2, and the 27k feedback resistor mod that Brian suggested and it sounds great. I did it on perfboard, and if there is any interest I'll post the layout, it's pretty simple.
This will give me a fun toy to play with when I need a break during my amp build. :D
Doug
Title: RM AXIS FUZZ
Post by: brian wenz on February 11, 2004, 11:21:20 AM
Hello Hello-
  Yeah, that 27K helps reduce the "flab" in the low end.
I wonder how it sounds through a Fender amp with a master volume???
Brian.
Title: R value...?
Post by: petemoore on February 11, 2004, 11:52:35 AM
The 27k mentioned in the last post...that would be the far left resistor on the schematic?
Title: Dagnabbitt !!!
Post by: petemoore on February 11, 2004, 11:53:43 AM
Sorry the far RIGHT of the schematic...is that the R your referring to as being a good value of 27k?
Title: Re: Dagnabbitt !!!
Post by: Doug H on February 11, 2004, 12:25:03 PM
Quote from: petemooreSorry the far RIGHT of the schematic...is that the R your referring to as being a good value of 27k?
It's a sub for the 47k feedback resistor that ties into the 22uf above the gain control.
Doug
Title: RM AXIS FUZZ
Post by: Doug H on February 11, 2004, 12:26:39 PM
Quote from: brian wenzHello Hello-
Brian.
It also helps the gain control work a little better and it is easier to find some of the "in between" tones. With the 47k, it goes to the "over the top" swell sounds much more quickly.
Doug
Title: RM AXIS FUZZ
Post by: brian wenz on February 11, 2004, 12:29:27 PM
Hello Doug--
  Have you tried using a BS 170 for Q2??
Brian.
Title: RM AXIS FUZZ
Post by: Doug H on February 11, 2004, 01:29:34 PM
Quote from: brian wenzHello Doug--
Brian.
No, didn't consider using a mosfet. How does it sound?
Doug
Title: RM AXIS FUZZ
Post by: phillip on February 11, 2004, 02:17:00 PM
I tried using a 2N7000 MOSFET in place of Q2, but it had some biasing problems in there...had that "farty" gated sound.
Phillip
Title: RM AXIS FUZZ
Post by: brian wenz on February 11, 2004, 03:04:46 PM
Hello Doug--
 Mine sounds.......................real good!!
I haven't done a  shoot-out between the stock version and the mosfet version yet but  I think the mosfet may be a little clearer then the tranny.
Didn't have any bias problems but I'm wondering if it couldn't be "fine tuned" for the BS170 a little better  [???]
Brian.
