DIY Stompboxes => Building your own stompbox => Topic started by: onboard on February 04, 2004, 02:30:45 PM
Title: signal driven LED
Post by: onboard on February 04, 2004, 02:30:45 PM
I ran a few searches on this and am still confused. My idea is for a momentary switched loop box to feed a delay pedal in order to play along with the lingering delay. I posted a switching schem for it in A/B/Y momentary quasi phrase sampler (http://diystompboxes.com/sboxforum/viewtopic.php?t=18304&highlight=)
It was suggested to me that a signal driven LED would be a cool thing to add. You know, the LED will be a visual of the signal coming from the delay pedal as it decays.
I remembered a similar? circuit block in the Dr. Quack/Nurse Quacky. Is this specific to the rest of the envelope filter circuit or can I do the same with the pedal's loop return jack feeding the inverting input of any dual opamp and drive my LED off the non-inverting input?
Another idea is a NeoVibe mod suggestion using an NPN tranny's base tied to the LFO (or other signal) with the emitter grounded and the LED/R limit between the collector and +9V.
Man, I ought to just get an EE text book...
Post by: onboard on February 04, 2004, 03:53:44 PM
I guess I'll start with the NPN as a switch idea...
