DIY Stompboxes => Building your own stompbox => Topic started by: petemoore on February 13, 2004, 04:58:07 PM
Title: Teac Double DPDT's
Post by: petemoore on February 13, 2004, 04:58:07 PM
Toggle, yes, but audio...
 They fit right in a large RACO hole, with a couple screws.
 After connecting the True Bypass and indicator R/LED to ground and through the switch  to the power There are still 5 untouched switch lugs, I haven't figured a useful application for.
 The other side of the LED could be used for a Bypass indicator and there would still be a whole SPDT left.
 It's a slide switch with two rows of six lugs.
 I countersunk it slightly and bluejean finished the box, so all you see is enough of the paddle for switching.
 Not as easy as a stomp, but not bad if the pedal is mounted, and I'm leaving the Mosfet Boost on, most all the time anyway.
