DIY Stompboxes => Building your own stompbox => Topic started by: Somicide on February 18, 2004, 02:50:47 AM
Title: are tants....?
Post by: Somicide on February 18, 2004, 02:50:47 AM
are they weird chip thingies?  or are they more typically shaped?
Post by: downweverything on February 18, 2004, 03:00:04 AM
if by tant you mean tantalum capacitor they are usually this weird shape like an elongated ceramic cap and are usually epoxy coated, i think the best way to describe the shape is a perfect mix between the shape of a ceramic and a cone.  they also do come in chips but usually for surface mount aplications which for diyers is not very useful.
Post by: Somicide on February 18, 2004, 03:05:03 AM
oooooh, i see now.  I've been seeing them in the chip form recently, and just had to ask, rather than assume I know.  So is it ok to use a non Tant Cap instead if it calls for a tant (ie, the tonepad schem of the small clone says 2.2uF Tant, could I use a non tant?)
edit:  And before I forget, the square shaped film caps are okay to use throughout yes?
Post by: downweverything on February 18, 2004, 03:09:55 AM
yeah you can usually replace them with little to no problem, depends how critical they are, which usually the difference is not noticable (to me anyway, some might say otherwise)
Post by: Somicide on February 18, 2004, 03:13:26 AM
alright.  now what is it that makes tants so special then?
Post by: downweverything on February 18, 2004, 03:20:07 AM
usually have a low ESR and good temperature characteristics, not to mention they are usually nice and small.
Post by: Somicide on February 18, 2004, 03:21:51 AM
i see i see.  I'm trying to obtain a bit of knowledge from this, i doubt it'll help my physics grade, but it'll give me hands on, no doubt.  Thanks!
Title: tants
Post by: Rick on February 18, 2004, 09:36:51 PM
They're also very low leakage caps and for this reason often used in critical timing circuits. They have a much greater life span than electros also. I've heard that they can be grittier sounding in certain apps in music circuits tho'. They have their place - experiment !
