I'm currently using piezo ceramic discs to amplify my acoustic guitars but there is an annoying bump at about 100-200 Hz. Also the output is quite low so I would like to build a Mosfet Boost with some sort of variable bass roll-off. What are some low part count suggestions.
Thanks,
Jun
Would a 'varitone' type circuit work for this?
Jun
Great build for those who have not yet.
Check out the links...Geo, AMZ, capacitors in the signal path can roll of lows, try different [smaller] values
Does it have to be MOSfet? If yes, i guess you could stick a variable low pass filter before the AMZ MOSfet booster. If no, there are tones of small BJT/FET boosters with low parts count.
Thanks for the tip Pete.
I would like to build the Mosfet Boost since I've read so much about it being a great non-coloring boost on this forum.
By 'low part count' I was referring to the tone section. I didn't want to add a parametric eq but something passive like this:
http://www.muzique.com/lab/tone3.htm
Would the version 2 AMZ control work after the Mosfet Boost?
Jun
I just found the filter calculator
http://www.muzique.com/schem/filter.htm
I'm gonna try a pot and cap after the Mos Boo.
Thanks,
Jun
