DIY Stompboxes => Building your own stompbox => Topic started by: { antonio } on February 24, 2004, 11:11:56 PM
Title: Thing Modulator
Post by: { antonio } on February 24, 2004, 11:11:56 PM
I wanted to know if anyone has built the thing modulator.  I have had some trouble with.  I have let it sit for months unfinished.  its about time for me to get it done.  but as i looked at it again tonight i dont see what i have dont wrong.
i just wanted to see if anyone has finshed it and maybe they could give me some hints.
http://www.geocities.com/tpe123/folkurban/fuzz/thing.gif
thanks.
Post by: brett on February 24, 2004, 11:44:10 PM
Hi.  Sorry, but can't really help with the Thing Modulator.  But I can say that the Ring Frobnicator and most other modulators are less than ideal for guitar work (with the possible exception of the 1496-based designs).  With that in mind, I've been working on a simple modulator.  I've designed and tested the circuit, and have designed a PCB for the final version.  Sometime over the next few days I'll build it on the PCB to test the layout.  If all goes well, in a week or two I'll have the design on my web-page and a notice in this forum.  I'm thinking of calling it the "Modulatron".
Sorry that doesn't answer your question.
Post by: Tim Escobedo on February 25, 2004, 12:02:01 AM
What's the problem?
Post by: mattv on February 25, 2004, 10:31:01 AM
It works great for me. Double check your wiring and connections. Make sure your using the specified LMC567 chip and not the regular LM567.
Title: thing modulator
Post by: { antonio } on February 25, 2004, 12:30:14 PM
tim, could that be the proplem?
i am using an lm instead of the lmc.
i didnt know that would be a big deal.  but thanks for the help.  i will get myself a new chip today and see if that works.
thanks.
Post by: Tim Escobedo on February 25, 2004, 01:24:44 PM
Yes, the LMC567 is absolutely necessary if you want the circuit to behave. That includes a reasonable amount of carrier rejection.
The more common LM567 may not even work with the 100k resistor in series with the power pin, as it's much more of a power hog than the LMC567.
Keep in mind that this is no Blue Ringer. The internal oscillator is fairly limited in range and tone. There's no wet/dry mixing. Carrier rejection is fairly decent considering the simplicity. But any high gain effect after the device will audibly amplify the carrier to possibly annoying levels.
Title: thanks.
Post by: { antonio } on February 25, 2004, 01:29:14 PM
thanks so much for your help.  i am on my way to get the new chip.
thanks again.
Post by: mattv on February 25, 2004, 04:48:37 PM
Quote from: Tim Escobedo
...The more common LM567 may not even work with the 100k resistor in series with the power pin...
It doesn't.
Post by: mattv on February 26, 2004, 04:47:22 PM
Anyway, if you can't find a LMC567, just use the LM and remove the RC network from V+. It's noisier this way, but IMO also does weirder things.
Post by: nightingale on February 26, 2004, 05:40:52 PM
very cool~
thanks mattv!
