DIY Stompboxes => Building your own stompbox => Topic started by: shawsofhell on March 08, 2004, 06:09:00 AM
Title: Pot controlled theremin
Post by: shawsofhell on March 08, 2004, 06:09:00 AM
Hi I'm looking for a nice theremin unit that can be controlled with a couple or more pots and switches. I don't want to build one of the normal hand waving ones. Any ideas? It would have to be able to plug into my guitar amp through my effects!
Post by: cedric on March 08, 2004, 06:11:56 AM
if you just want noise and a steady note once in a while, and not play melodies, i suggest you build a fuzz(face) (which you can add to your board as well) and add a feedback loop to it.
turn the fuzz on -> nice fuzz tone
turn the feedback loop on (using a simple SPST) -> theremin-ish action
Post by: cedric on March 08, 2004, 06:12:41 AM
or hey.. just build a feedback loop and put your existing pedals into that - that'll give your major control over the "theremin"-tones.
Post by: gez on March 08, 2004, 06:24:34 AM
Build a simple oscillator and control the rate, i.e. pitch, with a wah foot treadle.
Post by: sirkut on March 08, 2004, 09:01:52 AM
Look online for optical theremin, lumivox, or photo theremin. Also check out a 555 circuit that will generate tones. For the optical ones, replace the photocell with a pot, voila. Also if you can find an lm3909 led flasher chip which are not discontinued, you can build one using one of those as well.
Post by: Marcos - Munky on March 08, 2004, 10:07:38 AM
Just use a 555 sound generator and put a pot to control the pitch. I think in the 555 datasheet there's a schematic.
Post by: Jonas on March 08, 2004, 11:52:46 AM
I discovered that a dunlop crybaby acts somewhat like a theremin when you plug the guitar backwards... then the thread of the pedal aswell as the pot in the guitar control the pitch... wierd!
cheers!
jonas
Post by: Transmogrifox on March 08, 2004, 01:15:19 PM
Yeah, the crybaby also works well as a "theremin" if you put it in the feedback loop of an op amp.
Post by: Ansil on March 08, 2004, 05:40:50 PM
http://www.geocities.com/austenfantanio/hotdamen.wav
what about this..  it is easier to right click the link and click save target as
or open with a new window its a geocities thing
