DIY Stompboxes => Building your own stompbox => Topic started by: Ansil on March 24, 2004, 02:05:50 AM
Title: ok i need to ask a stupid qusetion
Post by: Ansil on March 24, 2004, 02:05:50 AM
i dont' play with mosfets or jfets much and when i do i am usually cussing
so let me ask this.
if you have to adjust the drains to get 4.5v aprox on ti
right like in nearly every circuit i see
then tell me,, why not just make a vbias of 4.5.??? instead of all of the adjusting constantly
i mean i know i have to be missing somehting here
pardon my ignorance.  but i have read plenty of info on them but stil nothing explaining why we can't just do that
Post by: Brian Marshall on March 24, 2004, 03:25:24 AM
not sure where you want to connect the vbias...... the drain???
wont work, you need current, and voltage.
Post by: Ansil on March 24, 2004, 03:27:11 AM
ahh ok.. thanks
Post by: brett on March 24, 2004, 03:28:37 AM
Hi Ansil.  Not a dumb question at all.
If I'd thought about it more, I'd have an answer for you.  But I don't - quite.
Instead, what I did was work out the relationship between Vgs as per RG's JFET tester and the optimum drain resistance.  What I got was a curve from about 4k at Vgs -3V (mostly MPF102s) through about 7k at -2V (lots of different JFETs) to about 18k at -1V (things like 5N5457s).  Because I test the Vgs on all my JFETs (looking for pairs), I can use this relationship to estimate what resistor to put on the drain.
If I'd also measured the voltage on the drain, I'd be able to tell you whether 4.5 V was optimum for all of them or whether it varied with type or Vgs.
Sorry about my lack of insight into your original question.
Post by: Ge_Whiz on March 24, 2004, 06:31:00 AM
It's more a case of setting the drain at half the supply voltage in order to get the maximum swing (headroom) out of what is a class A amplifier stage. If you were running the circuit at 12V, you'd be setting the drains at 6V (which would be about the same trimmer setting as 4.5/9V).
Am I right? Anybody?
Post by: Jered on March 24, 2004, 07:36:41 AM
For the most part I do believe you are correct about 1/2 supply V for max swing, but source resistance is also a factor.
 Anybody seen Jay Doyle?
  Jered
