DIY Stompboxes => Building your own stompbox => Topic started by: crawler486 on March 29, 2004, 03:33:16 AM
Title: Not getting enough FUZZ ?
Post by: crawler486 on March 29, 2004, 03:33:16 AM
I bought a "Fuzz Tone" kit and assembled the parts according
 to instructions. It seems to work BUT I aint getting enough Fuzz
 out of it.   How can I modify the circuit so it it gains more fuzz.
Post by: brett on March 29, 2004, 04:54:17 AM
Hi.  If it's one of those "pair of diodes" kits, then you'll get better results with humbucking pickups than single coil.  If you're stuck with single coil, you could use a booster than the fuzz unit.
But really, it's hard to get the quality of something like a fuzzface or RM axis fuzz from those kits.
good luck
Post by: crawler486 on March 29, 2004, 05:19:57 AM
Quote from: brettHi.  If it's one of those "pair of diodes" kits, then you'll get better results with humbucking pickups than single coil.  If you're stuck with single coil, you could use a booster than the fuzz unit.
good luck
yes, its a pair of diodes.
I came accross a webpage before saying if you put into series 2 pairs of diode, it will more gain? Is it true? if so, how will i do it
Post by: Gilles C on March 29, 2004, 07:00:49 AM
Add a Mosfet Booster before it, then drive it harder.
You'll be able to keep the original smoother sound...
Gilles
Post by: crawler486 on March 29, 2004, 07:33:25 AM
Quote from: Gilles CAdd a Mosfet Booster before it, then drive it harder.
Gilles
newbie in the house here! Please elaborate. How do I suppose to do that
Title: Start with an LPB-!?
Post by: petemoore on March 29, 2004, 09:28:55 AM
Just another hitch less tricky than the Mosfet.
 How newb are you...look at Skills you need, beginner forum, I used the Tweak-O article at Small Bear as my beginners pictorial/tutorial...easy to follow beginner info there can be applied to any project !!
Title: Re: Start with an LPB-!?
Post by: crawler486 on March 29, 2004, 09:36:28 AM
Quote from: petemooreJust another hitch less tricky than the Mosfet.
Can u pls show me the site?
Post by: Gilles C on March 29, 2004, 09:41:25 AM
Here it is:
http://www.muzique.com/schem/mosfet.htm
And it can be used as a very clean booster anytime...
A pcb layout is available on another site not far...
My favorite booster  :P
Post by: Gilles C on March 29, 2004, 09:43:57 AM
There:
http://www.tonepad.com/project.asp?id=30
