DIY Stompboxes => Building your own stompbox => Topic started by: fretbuzz2003 on March 30, 2004, 07:11:11 PM
Title: Neovibe Mod
Post by: fretbuzz2003 on March 30, 2004, 07:11:11 PM
Does anyone know how to increase the speed of the Neovibe? At full speed mine is vibing about 2 vibes per second.
Title: Neovibe Mod
Post by: RDV on March 30, 2004, 07:37:23 PM
I haven't built it yet, but was planning to. Did you do any subbing? Which layout? R.G.'s?
Regards
RDV
Title: Neovibe Mod
Post by: fretbuzz2003 on March 30, 2004, 07:41:52 PM
If I had to do it over again I would build the Easyvibe. The Neovibe has been a month long headache for me.
I used R.G.'s layout, and I added the input buffer per R.G.'s Technology of the Univibe article.
Title: Neovibe Mod
Post by: Chico on March 30, 2004, 07:48:15 PM
I just built a vibe (using my own layout) It was based upon the Neovibe and the vibe artile at JC's site, but the oscillator is straight from the Neovibe article.
I think that if you are getting only 2 vibes per second at max speed, something is wrong.  Recheck your values as mine has a nice range of speeds.
One mod worth checking out was discovered by JC.  It turns out that the old Shin-ei vibes had different cap values than the original Dynacord.
I replaced my caps with JC's suggested alternatives, and my vibe opened up nicely.
Right now it is my favorite build.
Anyone build both?
Title: Neovibe Mod
Post by: RDV on March 30, 2004, 07:48:50 PM
Oh, I got them mixed up :roll:
The easyvibe is the one I want to try, mostly cause it'll work @ 9v.
I think perhaps you're limited to how fast a bulb will light up and die down.
I'll still have a look.
RDV
Title: Neovibe Mod
Post by: Jose on March 31, 2004, 05:17:53 AM
Try lowering the value of the 4.7k (2.2k maybe good) resistors feeding the speed pot. That should speed it up. ;) Joe
Title: Neovibe Mod
Post by: zolee on March 31, 2004, 05:45:30 AM
hi,
I put variable resistors before the speed pot. This way I could fine tune the vibe. I also put variable resistors (trimmers) at the mixing stage, so that I could set a right proportion of the dry and wet signals. Changing the transistors in the lfo also might change the speed. I suggest that you use sockets for them for easy swap.
Title: Neovibe Mod
Post by: fretbuzz2003 on April 01, 2004, 07:35:44 PM
I replaced the 4.7k resistors before the speed pot with 2.4k resistors. That did the trick! Thanks!
