has anyone built the pt-80 from ustomp? most of the schematic looks similar to the one at GGG but it seems the power section is different... it looks like it runs on 9 volts instead of 18-24 volts... would this effect the sound differently?
i built a 9v version of the GGG schematic,and it sounds incredible...i have a vintage memory man,and the pt80 is the preferred one on my pedalboard...
I built a PT-80 and tried to run it off a 9v battery. I ended up switching to the suggested power supply because after the battery drained down a littlle, the circuit started soundy crappy. I think that my compander was not happy running at a relatively low voltage. Other compandors may be content at lower voltages.
Best of luck
