DIY Stompboxes => Building your own stompbox => Topic started by: jimbob on April 15, 2004, 08:40:15 PM
Title: Ibanez TS7 Tubescreamer= 39.99$
Post by: jimbob on April 15, 2004, 08:40:15 PM
This is they grey one..can this be easily converted to a ts-808 without much of a problem? Im thinking about buying it if thats the case--they want 169.00 for a ts-808 reissue--whatever!!
Post by: Peter Snowberg on April 15, 2004, 09:18:11 PM
Hmmm....
$39.99 + $0.04 = $169.00?
Must be new math. :D
Take care,
-Peter
Post by: brett on April 15, 2004, 09:32:52 PM
They are very similar.  You'd hardly be bothered changing it.  My TS-7 had a non-JRC chip in it.  But it sounded better with an NE5532 anyway.  The "hot" switch on the TS-7 is handy for bedroom heavy rock.
have fun
Post by: Fret Wire on April 15, 2004, 09:34:17 PM
It's basically a TS-9 with a boost switch. It can be modded just like one.
http://home.earthlink.net/~lens/p11-amp.htm
Post by: Brian Marshall on April 16, 2004, 02:28:45 AM
i have two of them, unfortunately the switches arent very good.  both of mine need to be kicked pretty hard to turn on.
they are not easy to rehouse either, because there are 5 pcbs in them and everything is pcb mounted.
component wise they are so close to the 808... most of them have the 4558 chip in them... both of mine do.
i used to gig with the two i had.  they were great.  one was set as a boost, with low gain, and one was set with the gain all the way up.  turn them both on for an awesoem lead tone
