DIY Stompboxes => Building your own stompbox => Topic started by: Ge_Whiz on April 30, 2004, 06:07:23 AM
Title: GGG Stratoblaster
Post by: Ge_Whiz on April 30, 2004, 06:07:23 AM
Anyone got any comments on the 'Stratoblaster' at GGG, please?
Post by: moosapotamus on April 30, 2004, 08:57:26 AM
I've found it to have lots of headroom, very clean, cleaner than most, IMO. Volume control starts off at ~unity gain and goes up from there. I put one in a smallstone for a friend to take care of the dreaded volume drop. Worked out great!
~ Charlie
Post by: Bill_F on April 30, 2004, 09:54:32 AM
Quote from: moosapotamusI put one in a smallstone for a friend to take care of the dreaded volume drop. Worked out great!
~ Charlie
Hey Charlie,
I've been thinking of doing this. Did you put it before or after the Small Stone circuit?
thanks,
Bill
Post by: Ge_Whiz on April 30, 2004, 12:56:51 PM
Thanks, Charlie.
Title: After...
Post by: petemoore on April 30, 2004, 01:14:56 PM
Putting it after lets you set higher headroom without distortion from the effect...course this may be what you want...a booster can always be chained to the front though.
 Putting it after the SS is what I'd do to cleanly fix the volume drop problem. You can always chain a booster to the front to get 'that combo effect.
Post by: moosapotamus on April 30, 2004, 08:22:58 PM
Yeah, I put it on the output. Worked out very nicely.
~ Charlie
Post by: jsleep on May 01, 2004, 05:42:06 AM
I like it better than an LPB.  When it does distort, it sounds pretty good!
JD Sleep
Post by: Chris Goodson on May 01, 2004, 11:09:34 AM
Why add this to your guitar?  If you don't have EMG's or something wouldn't it make it noisey as hell?
Actually I have one in the works I'm just waiting for a 201 from Small Bear.  Sure is an ultra simple build.
Post by: jsleep on May 01, 2004, 03:31:02 PM
Some people are really into on-board electronics and just have the cable from guitar straight to amp.  I'm the type of person who really thinks it makes more sense to have a pedal board (obviously :) ).  The modularity just makes good sense, especially in this day and age.
JD
Title: Stratoblaster resistors
Post by: Yazoo on November 16, 2004, 02:49:03 PM
In the Stratoblaster build instructions, it gives the option of using either a 100 Ohm resistor or a 68K. On the Parts Layout diagram, it shows the 100 Ohm option for R1.
What difference does this make? Should I go for the 100 Ohm or the 68K?
Title: ...
Post by: petemoore on November 16, 2004, 03:45:42 PM
I did two of these up for my brother, who's doing the 'frankenstien guitar thing.
 Great sound and excellent Jfet performance, just what the doctor orders in many cases. Similar to other Jfet Designs, I like it.
 Mine come out above unity at min vol., I 'tag' a 10k or 22k on top of the 100k output resistor to bring the effect output above/below unity at max/min volume settings. Setting that resistor value carefully makes the volume knob work more the way I want it to.
Title: Re: Stratoblaster resistors
Post by: petemoore on November 16, 2004, 04:58:18 PM
Quote from: YazooIn the Stratoblaster build instructions, it gives the option of using either a 100 Ohm resistor or a 68K. On the Parts Layout diagram, it shows the 100 Ohm option for R1.
>>>IIRC the 100R is series at the input. Increasing this ones value will increase the amount of resistance to any signal trying to get into the circuit. Larger values will attenuate more.
  Personally I've been liking having it tamed down a bit, tried a 220k at the input but like the 22k to ground on top of the 100k at the output....100k is superfluous but Ez leaves it in there,...in case I might want it stock someday.
Post by: jsleep on November 17, 2004, 01:09:49 PM
Hi Yazoo,
I have a hard time understanding Pete's posts, so please excuse me if I say something he already said without knowing it.
That input resistor is there to squelch rf and keep the circuit from being a radio receiver.  I am assuming that this would be more of a problem in an unshielded guitar cavity than it is in a metal stompbox enclosure.  I'm also assuming that the higher value might reduce more rf noise.   I picked a more standard value, by today's standards,  of 100 ohm.  According to a geo article, it's useless without the accompanying cap to ground, so I may have to look at this one again.  This is a little difficult for me to experiment with because I live in an area where radio waves seem to be very tame.
JD
Post by: Fernando Aguirre on November 17, 2004, 02:16:59 PM
Who designed this booster?
Post by: Paul Marossy on November 17, 2004, 03:04:55 PM
QuoteWho designed this booster?
If I'm not mistaken, that is a circuit that was originally made by Alembic.
Post by: Torchy on November 17, 2004, 07:24:20 PM
crp
Post by: B Tremblay on November 17, 2004, 07:43:34 PM
Quote from: TorchyNo input dc blocking cap?
Since the gate of the FET is tied to ground via the 2M2 resistor, there is no DC voltage present.  Therefore, a cap is not necessary.
Post by: Torchy on November 17, 2004, 08:11:48 PM
crp
Post by: guitarmonky55 on November 17, 2004, 10:33:30 PM
that stratoblaster looks intriguing to me(mainly because of its simplicity and the fact that im a total noob to pedals) but i must ask........what exactly is its effect on the sound?  the name seems to imply that it creates a strat like tone but i could be way off?
Post by: gtech on November 17, 2004, 10:40:44 PM
It was made to be added to a Strat and blast its output up...
But it doesn't change the sound.
Check this link.
http://shop.store.yahoo.com/alembic/blaster.html
and this one that shows how to install it.
http://www.alembic.com/support/blaster_photos.html
Gilles
Title: ...
Post by: petemoore on November 17, 2004, 11:32:38 PM
Can change the sound of what comes after. Just about right for driving your Fuzz over the top. This is a Great Booster...
 vol knob acts a little 'funny'...change the 100k value at output to ground and have it in the pocket 'your way.
Post by: jsleep on November 18, 2004, 08:30:02 AM
Hi Torchy,
Here's a link to my reference:
http://www.geofex.com/circuits/what_are_all_those_parts_for.htm
Rrf & Crf   I may have mis-spoken about this, the article doesn't say having just the resistor is bad, but says having just the cap is bad.  Anyway, I believe I've seen this setup with Crf as high as 470pf to ground.  Since I know practically nothing about electronics math, I don't really know how to calculate the "safe" value for that cap.
I'll be experimenting (playing around) with this in the near future, I'll post if I find anything interesting to share.
JD
Post by: gtech on November 18, 2004, 03:42:59 PM
Thanks for posting the link. I tried to find the info on Geo, but there is so much (interesting) stuff there that I didn't find it.
Before I read the article, I was about to ask if the cap was needed before or after the resistor. I never remember...  :oops:  But then, after I read the article, I remembered that it is the same than for the power supplies. Except that we filter the RF in place of the 60Hz ac.
That would also be a nice place for an RF bead. I wonder if the resistor would still be needded if we used a bead, or if it would be best to keep the resistor and add a bead???
About the use of a resistor without a capacitor with a FET, maybe it works because of the capacitance at the gate of the FET.
Gilles
Post by: Torchy on November 18, 2004, 05:38:12 PM
crp
Post by: jsleep on November 19, 2004, 04:26:02 AM
Hi Giles,
Have you had any luck with the ferrite beads?  I bought a couple different sizes from mouser but haven't tried them yet.  Any ideas how I can creat some RF so I can do some testing? :-) (weird request,huh?)
JD
Post by: Paul Marossy on November 19, 2004, 10:12:55 AM
QuoteAny ideas how I can creat some RF so I can do some testing?
If you have a RF signal generator, you could do what you want to do. You can probably get one pretty cheap thru ebay. I had one given to me but I have never used it, yet...
Post by: Yazoo on November 26, 2004, 03:30:22 PM
:D
I built the Stratoblaster as a pedal, with the 100 Ohm resistor as per schematic.
It seems fine, and works really well. It might be a Stratoblaster, but it's nice with a Les Paul as well - try it.
