Hey, I was wondering about putting a line out to use the amp as a head (of sorts). So the question I have is, how would I wire up the final two wires (past the resistor and capacitor) to make the jack work?
If you're referring to the Little Gem Mk II amp, then you'd use a mono 1/4" jack. The jack replaces the speaker as shown in the schematic, with one wire connected to the tip lug and the other to the sleeve lug.
If you're putting the circuit in a metal enclosure, remember to use non-conductive washers to isolate the output jack.
thanks, thats just what I needed to know, sorry for the dumb questions, Im kinda new with diy (a coupla ods already done) and I want to make sure that I do things right the first time (as much as possible).
